下面是我lvs出现的警告:
## C A L I B R E S Y S T E M ##
## C I R C U I T E X T R A C T I O N R E P O R T ##
REPORT FILE NAME: 810_ch9_break.lvs.report.ext
layout NAME: 810_ch9_break.calibre.db ('810_ch9_break')
CREATION TIME: Thu Jun 19 05:15:25 2014
CURRENT DIRECTORY: /home/fxwang/810/calibre
USER NAME: fxwang
CALIBRE VERSION: v2011.2_34.26 Wed Jul 6 05:20:56 PDT 2011
Extraction Errors and Warnings for cell "pwr_rails"
WARNING: Unattached label:
Name "DVDD" at location (67.47,47.92) on layer "Metal1_Text"
Name "VSS" at location (67.445,105.705) on layer "Metal1_Text
WARNING: Unattached port "VSS" at location (67.445,105.705) in cell "pwr_rails"
WARNING: Unattached port "DVDD" at location (67.47,47.92) in cell "pwr_rails"
Extraction Errors and Warnings for cell "gpio_oly"
Name "DVDD" at location (68.685,47.92) on layer "Metal1_Text"
WARNING: Unattached port "DVDD" at location (68.685,47.92) in cell "gpio_oly"
Extraction Errors and Warnings for cell "sc_capl"
Name "poff" at location (3.765,14.775) on layer "Metal1_Text"
WARNING: Unattached port "poff" at location (3.765,14.775) in cell "sc_capl"
Extraction Errors and Warnings for cell "ipplscp_vss"
Name "DVDD" at location (1.97,13.68) on layer "Metal4_Text"
Name "VDD" at location (1.96,79.39) on layer "Metal4_Text"
Name "VSS" at location (1.91,91.14) on layer "Metal4_Text"
Name "VSS" at location (1.945,55.92) on layer "Metal4_Text"
WARNING: Unattached port "VSS" at location (1.91,91.14) in cell "ipplscp_vss"
WARNING: Unattached port "VSS" at location (1.945,55.92) in cell "ipplscp_vss"
WARNING: Unattached port "VDD" at location (1.96,79.39) in cell "ipplscp_vss"
WARNING: Unattached port "DVDD" at location (1.97,13.68) in cell "ipplscp_vss"
Extraction Errors and Warnings for cell "ipplscp_vdd"
WARNING: Short circuit - Different names on one net:
Net Id: 1
(1) name "sdlow" at location (4.95,0) on layer "Metal1_Text"
(2) name "VSS" at location (1.925,55.92) on layer "Metal4_Text"
(3) name "VSS" at location (1.925,91.14) on layer "Metal4_Text"
The name "sdlow" was assigned to the net.
Extraction Errors and Warnings for cell "ICV_34"
WARNING: Stamping conflict in SCONNECT - Multiple source nets stamp one target net.
Use LVS REPORT OPTION S or LVS SOFTCHK statement to obtain detailed information.
Extraction Errors and Warnings for cell "ICV_31"
WARNING: Unattached port "DVDD" at location (0.26,109.165) in cell "dvss_oly"
WARNING: Unattached port "DVDD" at location (2.265,47.76) in cell "posc_oly_m6"
Extraction Errors and Warnings for cell "810_ch9_break"
lvs的rule是:
LAYOUT PATH "810_ch9_break.calibre.db"
LAYOUT PRIMARY "810_ch9_break"
LAYOUT SYSTEM GDSII
SOURCE PATH "/home/fxwang/810/calibre/810_APR_data/810_ch9_break.cdl"
SOURCE PRIMARY "design_top"
SOURCE SYSTEM SPICE
MASK SVDB DIRECTORY "svdb" QUERY
LVS REPORT "810_ch9_break.lvs.report"
LVS REPORT OPTION NONE
LVS FILTER UNUSED OPTION NONE SOURCE
LVS FILTER UNUSED OPTION NONE LAYOUT
LVS REPORT MAXIMUM 200
LVS RECOGNIZE GATES SIMPLE
LVS ABORT ON SOFTCHK NO
LVS ABORT ON SUPPLY ERROR YES
LVS IGNORE PORTS NO
LVS SHOW SEED PROMOTIONS NO
LVS SHOW SEED PROMOTIONS MAXIMUM 50
LVS ISOLATE SHORTS NO
VIRTUAL CONNECT COLON NO
VIRTUAL CONNECT REPORT NO
LVS EXECUTE ERC YES
ERC RESULTS DATABASE "810_ch9_break.erc.results"
ERC SUMMARY REPORT "810_ch9_break.erc.summary" REPLACE HIER
ERC MAXIMUM RESULTS 1000
ERC MAXIMUM VERTEX 4096
DRC ICSTATION YES |
