在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: earlyha
mentor graphics pyxis crack + license
发表于 2017-5-23 00:31:54 | 显示全部楼层
回复 47# snk88
Thanks for you prompt reply... please look into the matter...
I have generated a license.txt with all mentor features "mentorall_s". But still stuck somewhere.
If you can help please?
发表于 2017-5-23 19:00:06 | 显示全部楼层
回复 51# inderjit
  1. SERVER YOUR_HOSTNAME 000c2950fe43 5288
  2. DAEMON mgcld /PATH/TO/mgcld
  3. INCREMENT mgc_s mgcld 2029.040 23-may-2029 0 6EF8D967D909D3D2C8A6 \
  4.         VENDOR_STRING=5D1BA148 HOSTID=000c2950fe43 SN=29888136 \
  5.         SIGN2=73E4E98E785092B4
  6. INCREMENT mentorall_s mgcld 2029.040 23-may-2029 0 \
  7.         1E2819D7E5E05FB4A9DA VENDOR_STRING=5C3C5375 \
  8.         HOSTID=000c2950fe43 SN=29888137 SIGN2=8A6015BA7BE877B2
复制代码
or
  3. FEATURE mgc_s mgcld 2029.00 31-dec-2029 999 2E0A591722F217E0173B \
  4.         VENDOR_STRING=F23D52AA TS_OK SIGN=A71AB5E4698EC01C \
  5.         SIGN2=A71AB5E4698EC01C
  6. FEATURE mentorall_s mgcld 2029.00 31-dec-2029 999 \
  7.         3ECAC9877E8B1A42BCE1 VENDOR_STRING=9A6DECE1 TS_OK \
  8.         SIGN=C0B66FE854F04654 SIGN2=C0B66FE854F04654
复制代码
or
  1. SERVER YOUR_HOSTNAME 000c2950fe43 27001
  2. VENDOR mgcld /path/to/mgcld
  3. INCREMENT mgc_s mgcld 2027.040 23-may-2027 0 9E38F977A713C16260E5 VENDOR_STRING=C69FF3E1 HOSTID=000c2950fe43 SN=56981843 SIGN2="1561 94DA CA48 450C E864 9730 61D3 B2C8 E713 7EB7 9889 867A D15D 4B3E F8EA 0FA2 3E4B 898F 0502 8D29 D943 304D 8042 23DB C3F1 B640 7B51 C2F6 1282 1178"
  4. INCREMENT mentorall_s mgcld 2027.040 23-may-2027 0 CE48B97746A938812D76 VENDOR_STRING=DEE59711 HOSTID=000c2950fe43 SN=56981843 SIGN2="010B E844 515E 769D A2C0 F518 29DE CA63 B638 AC08 A1DC A00E 7743 0BDD 6558 1491 8256 98A2 82BF 009D EDC6 F616 6C35 7A24 8423 DD5A 7F7C 5A7F AA82 2CC1"
复制代码
发表于 2017-5-23 21:00:04 | 显示全部楼层
[Root @ localhost license] # ./mgls/bin/lmgrd -c license.txt
18:27:54 (lmgrd) ------------------------------------------ -----
18:27:54 (lmgrd) Please Note:
18:27:54 (lmgrd)
18:27:54 (lmgrd) This log is intended for debug purposes only
18:27:54 (lmgrd) In order to capture accurate license
18:27:54 (lmgrd) usage data into an organizational repository,
18:27:54 (lmgrd) please enable report logging. Use Flexera Software, Inc.'s
18:27:54 (lmgrd) software license administration solution,
18:27:54 (lmgrd) FLEXnet Manager, to readily gain visibility
18:27:54 (lmgrd) into license usage data and to create
18:27:54 (lmgrd) insightful reports on critical information like
18:27:54 (lmgrd) license availability and usage. FLEXnet Manager
18:27:54 (lmgrd) can be fully automated to run these reports on
18:27:54 (lmgrd) schedule and can be used to track license
18:27:54 (lmgrd) servers and usage across a heterogeneous
18:27:54 (lmgrd) network of servers including Windows NT, Linux
18:27:54 (lmgrd) and UNIX. Contact Flexera Software, Inc. at
18:27:54 (lmgrd) www.flexerasoftware.com for more details on how to
18:27:54 (lmgrd) an answer copy of FLEXnet Manager
18:27:54 (lmgrd) for your enterprise.
18:27:54 (lmgrd)
18:27:54 (lmgrd)
18:27:54 (lmgrd)
18:27:54 (lmgrd) The license server manager (lmgrd) running as root:
18:27:54 (lmgrd) This is a potential security problem
18:27:54 (lmgrd) and is not recommended.
18:27:54 (lmgrd) FLEXnet Licensing (v11.10.0.3 build 96543 i86_lsb) started on localhost.localdomain (linux) (5/23/2017)
18:27:54 (lmgrd) Copyright (c) 1988-2011 Flexera Software, Inc. All Rights Reserved.
18:27:54 (lmgrd) US Patents 5,390,297 and 5,671,412.
18:27:54 (lmgrd) World Wide Web: http://www.flexerasoftware.com
18:27:54 (lmgrd) License file (s): license.txt
18:27:54 (lmgrd) lmgrd tcp-port 27001
18:27:54 (lmgrd) Starting vendor daemons ...
18:27:54 (lmgrd) Started mgcld (internet tcp_port 56843 pid 4934)
[Root @ localhost license] # 18:27:54 (mgcld) FLEXnet Licensing version v11.10.0.3 build 96543 i86_lsb
18:27:54 (mgcld) License server system started on localhost.localdomain
18:27:54 (mgcld) No features to serve, exiting
18:27:54 (mgcld) EXITING DUE TO SIGNAL 36 Exit reason 4
18:27:54 (lmgrd) mgcld exited with status 36 (No features to serve)
18:27:54 (lmgrd) mgcld daemon found no features. Please correct
18:27:54 (lmgrd) license file and re-start daemons.
18:27:54 (lmgrd)
18:27:54 (lmgrd) This may be due to the fact that you are using
18:27:54 (lmgrd) a different license file from the one you expect.
18:27:54 (lmgrd) Check to make sure that:
18:27:54 (lmgrd) license.txt
18:27:54 (lmgrd) is the license file you want to use
18:27:54 (lmgrd)
发表于 2017-5-23 21:03:56 | 显示全部楼层
回复 52# snk88
I suppose it is needed to generate license for all the features.
MentorKG.exe -h 000c2950fe43 -all -o license.txt
发表于 2017-5-23 21:26:17 | 显示全部楼层
Reply 9 # earlyha
can you help it out please.
发表于 2017-6-20 14:30:19 | 显示全部楼层
有0in吗
发表于 2017-7-5 19:50:12 | 显示全部楼层
thanks for informative post
发表于 2017-11-28 02:51:44 | 显示全部楼层
thanks
发表于 2017-11-28 05:28:07 | 显示全部楼层
thanks
发表于 2017-11-28 05:35:32 | 显示全部楼层
thanks
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-17 07:24 , Processed in 0.034848 second(s), 6 queries , Gzip On, Redis On.
