在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: earlyha
mentor graphics pyxis crack + license
发表于 2017-2-8 01:57:53 | 显示全部楼层
please help me in installing this software, Mentor Graphics pyxis
发表于 2017-2-27 23:28:05 | 显示全部楼层
Reply 2 # snk88
-Successfully installed calibre, pyxis, ams.
-Generated mentor license for my hostid.
1. Caliber - patched - successfully running: tons of thanks to you and community
2. Pyxis (see below)
[Root @ localhost ~] # da_ic &
[1] 3037
[Root @ localhost ~] # / home / software / ams / ixl / bin / vacom: error while loading shared libraries: /home/software/ams/modeltech/linux/libuinfo.so: can not restore segment prot after reloc: Permission denied
// Pyxis Schematic v10.2_0.0 Mon Aug 13 21:08:00 PDT 2012
// Copyright Mentor Graphics Corporation 1982
// All Rights Reserved.
// THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
// WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION OR
// ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
// Mentor Graphics software executive under x86_64 Linux.
// Note: Default ripper symbol pathname for auto-ripper instantiation set to $ MGC_IC_GENERIC_LIB / rip / 1X1 (from: Capture / gdc / note 98)
// Note: Activated Variant hotkeys. (From: Uims / base_toolkit / ui_session_tk 81)
// Fail:
// license request for icarch feature failed (from: Core / licensing / MGLS_run 03)
// license request for Pyxis Schematic failed.
Is there any patch for Pyxis too?
Please reply, I hope you can help, please.
发表于 2017-3-14 22:21:05 | 显示全部楼层
1. [Done] MentorKG:
wine MentorKG.exe -patch <install_path> -pkg <path_to_lib/mgc.pkginfo>  -o license.dat
2. ERROR:
Executed 'lmgrd':
  1. root@root# ../pyxis/v10.2_linux_x86_64/pyxis_home/bin/lmgrd -c license.dat
  2. 19:19:18 (mgcld)        ==>INCREMENT cesautomation2 mgcld 2027.020 14-mar-2027 uncounted \
  3.         3EF8F4AE1C1C43FC185A VENDOR_STRING=F54FCFAA \
  4.         HOSTID=000c2950fe43 SN=08708193 SIGN2="1873 EB2B AD08 0E59 \
  5.         BD22 ED5E B0AC C0C7 2796 9A04 2841 9B18 3AF8 A542 230A 115C \
  6.         E37B A4E6 CAB3 9144 05B9 D471 86C2 398D 8F91 7B68 758B 2171 \
  7.         C4F5 E12E"
  8. 19:19:18 (mgcld) Invalid license key (inconsistent authentication code)[/color]
复制代码
Please Help, over two months of torture...
发表于 2017-5-12 12:33:18 | 显示全部楼层
thank you
发表于 2017-5-19 01:06:22 | 显示全部楼层
Reply 8 # snk88
snk88, I hope only you can help me, I have same problem: license request failed.
Do pyxis also needs to patched? where the patch is?
Reply
发表于 2017-5-19 01:27:24 | 显示全部楼层
Reply 8 # snk88
[root@localhost license]# //  Pyxis Schematic  v10.2_2.0   Tue Mar 26 10:59:53 PDT 2013
//  Mentor Graphics software executing under x86_64 Linux.
//  Note: Default ripper symbol pathname for auto-ripper instantiation set to $MGC_IC_GENERIC_LIB/rip/1X1 (from: Capture/gdc/note 98)
//  Note: Activated Variant hotkeys. (from: Uims/base_toolkit/ui_session_tk 81)
//  Fail:
//  mgc_s
//  License server does not support this feature (icarch). (from: Core/licensing/MGLS_run 0A)
//  License request for Pyxis Schematic failed.
[1]    Exit 1                        da_ic
发表于 2017-5-19 18:37:54 | 显示全部楼层
回复 46# inderjit
   http://bbs.eetop.cn/viewthread.php?tid=311773patch
give me your lmhostid.
发表于 2017-5-22 16:06:55 | 显示全部楼层
[root@localhost bin]# ./lmhostid
lmhostid - Copyright (c) 1989-2011 Flexera Software, Inc. All Rights Reserved.
The FLEXnet host ID of this machine is "000c2950fe43"
发表于 2017-5-22 16:56:56 | 显示全部楼层
1. Calibre is running fine. Patched.
2. Problem in Pyxis:
    Here is the log:
[root@localhost bin]# ./lmgrd -c /home/software/license/license.txt
13:50:27 (lmgrd) -----------------------------------------------
13:50:27 (lmgrd)   Please Note:
13:50:27 (lmgrd)
13:50:27 (lmgrd)   This log is intended for debug purposes only.
13:50:27 (lmgrd)   In order to capture accurate license
13:50:27 (lmgrd)   usage data into an organized repository,
13:50:27 (lmgrd)   please enable report logging. Use Flexera Software, Inc.'s
13:50:27 (lmgrd)   software license administration  solution,
13:50:27 (lmgrd)   FLEXnet Manager, to  readily gain visibility
13:50:27 (lmgrd)   into license usage data and to create
13:50:27 (lmgrd)   insightful reports on critical information like
13:50:27 (lmgrd)   license availability and usage. FLEXnet Manager
13:50:27 (lmgrd)   can be fully automated to run these reports on
13:50:27 (lmgrd)   schedule and can be used to track license
13:50:27 (lmgrd)   servers and usage across a heterogeneous
13:50:27 (lmgrd)   network of servers including Windows NT, Linux
13:50:27 (lmgrd)   and UNIX. Contact Flexera Software, Inc. at
13:50:27 (lmgrd)   www.flexerasoftware.com for more details on how to
13:50:27 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
13:50:27 (lmgrd)   for your enterprise.
13:50:27 (lmgrd)
13:50:27 (lmgrd)
13:50:27 (lmgrd)
13:50:27 (lmgrd) The license server manager (lmgrd) running as root:
13:50:27 (lmgrd)         This is a potential security problem
13:50:27 (lmgrd)         and is not recommended.
13:50:27 (lmgrd) FLEXnet Licensing (v11.10.0.3 build 96543 i86_lsb) started on localhost.localdomain (linux) (5/22/2017)
13:50:27 (lmgrd) Copyright (c) 1988-2011 Flexera Software, Inc. All Rights Reserved.
13:50:27 (lmgrd) US Patents 5,390,297 and 5,671,412.
13:50:27 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
13:50:27 (lmgrd) License file(s): /home/software/license/license.txt
13:50:27 (lmgrd) lmgrd tcp-port 1717
13:50:27 (lmgrd) Starting vendor daemons ...
13:50:27 (lmgrd) Started mgcld (internet tcp_port 44019 pid 9792)
13:50:27 (mgcld) FLEXnet Licensing version v11.10.0.3 build 96543 i86_lsb
13:50:27 (mgcld) Server started on localhost.localdomain for:        acctree
13:50:27 (mgcld) aditspice        aditturbo        admsrfic
13:50:27 (mgcld) amsicacc        autocells_s        backann
13:50:27 (mgcld) caldesignrev        caldfmproperty        caldrclvseve
13:50:27 (mgcld) caleuv                calfractureall        calfracturec
13:50:27 (mgcld) calfractureh        calfracturej        calfracturem
13:50:27 (mgcld) calfracturet        calfracturev        calibreadp
13:50:27 (mgcld) calibreilo        calibreinroute        calibrelfd
13:50:27 (mgcld) calibrelv        calibremt2cpu        calibreorc
13:50:27 (mgcld) calibreperc        calibrepercsp        calibrepvs_s
13:50:27 (mgcld) calibreqdb        calibrexact        calibrexact3d
13:50:27 (mgcld) calibrexactsoc        calibrexl        calibrexrc
13:50:27 (mgcld) calibrexrcadms        calibrexrccb        calinteractive
13:50:27 (mgcld) calmaskopt        calmdpesvrf        calmdpmapi
13:50:27 (mgcld) calmdpmerge        calmdpview        calmpcpro
13:50:27 (mgcld) calmtopcpro        calmultipattern calnmdpc
13:50:27 (mgcld) calnmmpc        calnmopc        calnmopcddl
13:50:27 (mgcld) calnmsraf        calopcpro        calopcsbar
13:50:27 (mgcld) calopcverify        calpixbar        calpmatch
13:50:27 (mgcld) calprintimage        calpsmgate        calpxopc
13:50:27 (mgcld) calrealtime        caltdopc        calwaiver
13:50:27 (mgcld) calworkbench        calyieldanalyze calyieldenhance
13:50:27 (mgcld) calyieldserver        echeck                edifdb
13:50:27 (mgcld) eldokernel_c        eldopsf                eldorfic
13:50:27 (mgcld) falconfw_s        falconfwnt_s        genieartist
13:50:27 (mgcld) hpplot                hypcpf                hyptransformer
13:50:27 (mgcld) hyptsview        icassemble        icbendmos
13:50:27 (mgcld) icdpmana_c        icdpmdig_c        icgraphcde
13:50:27 (mgcld) icrules                ictrace                ie3dcpucore
13:50:27 (mgcld) ie3ddm_c        ie3dsi_c        ie3dsi0
13:50:27 (mgcld) mgenread        mgniread        mgniwrite
13:50:27 (mgcld) mgsiread        mgsiwrite        mgsread
13:50:27 (mgcld) mgswrite        msimcdebug        msimcompare
13:50:27 (mgcld) msimcoverage        msimdataflow        msimhdlmix
13:50:27 (mgcld) msimhdlsim        msimprofile        msimviewer
13:50:27 (mgcld) mtiverification psprint                pyximplement_c
13:50:27 (mgcld) pyxschematic_c        sg_c                timeit
13:50:27 (mgcld) verifdataport        verilogacomp        verilogart
13:50:27 (mgcld) vhamsdev        vhamsmod        vhamsrt
13:50:27 (mgcld) xcalibrate        xelga_c
13:50:27 (mgcld)
13:50:27 (mgcld) Licenses are case sensitive for mgcld
13:50:27 (mgcld)
13:50:27 (mgcld) EXTERNAL FILTERS are OFF
13:50:27 (lmgrd) mgcld using TCP-port 44019
13:51:02 (mgcld) TCP_NODELAY NOT enabled
Flexible License Manager status on Mon 5/22/2017 13:51
[root@localhost bin]# ./lmstat -c /home/software/license/license.txt
License server status: 1717@localhost.localdomain
    License file(s) on localhost.localdomain: /home/software/license/license.txt:
localhost.localdomain: license server UP (MASTER) v11.10
Vendor daemon status (on localhost.localdomain):
     mgcld: UP v11.10
[root@localhost bin]# da_ic &
[1] 9885
[root@localhost bin]# //  Pyxis Schematic  v10.2_2.0   Tue Mar 26 10:59:53 PDT 2013
//  Fail:
//  pyxschematic_c
发表于 2017-5-22 16:58:24 | 显示全部楼层
1. Calibre patched. Running successfully.
2. Pyxis giving an error:
See the log below:
13:50:27 (lmgrd)
13:50:27 (lmgrd)
13:50:27 (lmgrd)
13:50:27 (lmgrd)
13:50:27 (mgcld)
13:50:27 (mgcld)
     mgcld: UP v11.10
[1] 9885
//  Fail:
//  pyxschematic_c
GMT+8, 2024-4-25 23:42 , Processed in 0.027745 second(s), 6 queries , Gzip On, Redis On.
