在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: snk88
ads2014.01 linux patch+systemvue2013.08 patch
发表于 2014-4-11 10:48:14 | 显示全部楼层
老大,systemvue能放一个32bit的吗。多谢了。
发表于 2014-4-11 11:48:48 | 显示全部楼层
回复 1# snk88
老大,是不是还要用后面的两个文件?我把前面两个文件解压为ads_patch,然后在Linux下解压覆盖后,修改主机名和网卡号后,ADS启动后找License,还是说“License file signature is Invalid ”
 楼主| 发表于 2014-4-11 12:05:03 | 显示全部楼层
回复 22# YULONGUTK
不需要的
发表于 2014-4-11 13:46:19 | 显示全部楼层
回复 23# snk88
after I open your patch directory, for example if I check the files under the lib,which has much few files than the original one ( installed automatelly by the installation processs)
, my question is :
1.  should I replace the original one ( which is big) by the patched one ( which is small)
or
2.  should I just add the patched one into the original one
thanks ?
 楼主| 发表于 2014-4-11 15:57:05 | 显示全部楼层
回复 24# dandeng
   要确保 是ads2014.01 linux x86——64  for rhel6 版本,其他版本我不确定可以用
发表于 2014-4-11 16:58:51 | 显示全部楼层
Reply 25 # snk88
could you please tell me from where i could download RHEL 6
 楼主| 发表于 2014-4-11 17:01:46 | 显示全部楼层
回复 26# chris2013
   centos 6.5 ~~google
 楼主| 发表于 2014-4-11 19:32:02 | 显示全部楼层
回复 22# YULONGUTK
   忘了说,覆盖之后需要运行 Licensing/2014.01/linux_x86_64/bin/aglmmgr
来配置license,如果不做这个这一步就会出错
发表于 2014-4-11 20:56:42 | 显示全部楼层
多谢了
发表于 2014-4-11 20:57:27 | 显示全部楼层
多谢了
GMT+8, 2024-4-25 23:28 , Processed in 0.030277 second(s), 7 queries , Gzip On, Redis On.
