在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: zhule
ADS2014.01已经发布可以下载了,期待破解~~~~~~~~~~~~~~~~~
发表于 2014-3-25 10:45:03 | 显示全部楼层
回复 42# snk88
    下载不了,能传到那个网盘上吗?
发表于 2014-3-25 10:50:25 | 显示全部楼层
回复 51# tony_tin
    官网去下载
发表于 2014-3-25 11:00:21 | 显示全部楼层
回复 48# snk88
   hpeesofsim (*) 410.shp Mar 17 2014 (64-bit built: 03/17/14 17:33:40)
Copyright Agilent Technologies, 1989-2014.
Error detected by hpeesofsim during AC analysis `ZcGammaExt'.
    An attempt to use the Controlled Impedance Line Designer feature was made, and a valid
    Controlled Impedance Line Designer license is not available.  This software is not licensed for
    use with Controlled Impedance Line Designer.
        FlexLM error message:
        Tool_that_analyzes_the_substrate_and_dimensions_of_multilayer_transmission_lines
        You do not have a license to run this feature.
        Below is a list of products that contain this feature:
        W2250BT ADS Inclusive
        W2250BP ADS Inclusive
        W2030UT EEsof University Bundle time-based  license
        E8900ECS Emergency Codeword System (ECS) ADS RFDE EMDS GG AMDS
        E8900PE ADS Premier Student License
        W2130UT EEsof University Bundle with EMPro
        W2130UE EEsof University Bundle with EMPro Student License
        W2030UE EEsof University Bundle time-based Student License
        E8900PN ADS Premier Network University
        E8900P ADS Premier University
        W2200F ADS All Inclusive
        W2130UX AGILENT UNIVERSITY DONATION (EESOF INCLUSIVE)
        W2030UX EESOF EDA MULTI-PRODUCT DONATION BUNDLE
        E8900PX AGILENT UNIVERSITY DONATION(ADS/PREMIER)
        E8900PP ADS Premier University Donation
        W2307EP Controlled impedance Line Designer
        W2307ET Controlled impedance Line Designer
        Possible Causes:
        1. A license for the feature was not purchased.
        2. The feature could not be found in the license file or on the server or is invalid.
        3. You are pointing to the wrong license file or server.
        4. You are not specifying a port number with the server in "port@host" format.
        5. The distributed simulation on the remote computer(s) does not use the same license server(s) as the local computer.
        Troubleshooting Tips:
        1. Check the license file or server you are trying to use contains the right licenses for this product.
        2. Verify that you are pointing to the correct server and license file using the wizard.
        3. Verify that you do not have a license preference set to a feature that has been removed on the server.
        4. Use the License Manager's Licenses tab to view your licenses and available features.
        License path:  D:\Agilent\License\license.lic
发表于 2014-3-25 11:03:43 | 显示全部楼层
回复 52# snk88
    就是在官网下,到了接受我的申请后,就没反映了
发表于 2014-3-25 11:10:10 | 显示全部楼层
回复 52# snk88
   老大 看哪里的License log
发表于 2014-3-25 12:10:38 | 显示全部楼层
回复 55# ap0305322
   ctrl+alt+del 任务管理器里面,找lmgrd 后面对应的命令行就知道了
发表于 2014-3-25 12:32:01 | 显示全部楼层
回复 56# snk88
   老大,你的可以正常使用吗?帮我分析一下我贴上去的信息。
发表于 2014-3-25 13:22:46 | 显示全部楼层
感谢楼主的分享
前版本的ADS2013.06﹍agls.dll分别有x64 & x32是分开的, 但是楼主给的有点奇怪, 貌似还有不足!?
看来还不成熟...还是在等一会吧
发表于 2014-3-25 15:17:33 | 显示全部楼层
回复 56# snk88
   大神~~~ 帮忙解决一下
发表于 2014-3-25 15:38:29 | 显示全部楼层
可能是因为ADS 2014.01从安装程序上就分开为32位和64位版本的缘故
GMT+8, 2024-4-25 15:08 , Processed in 0.027569 second(s), 6 queries , Gzip On, Redis On.
