在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 3477|回复: 6
[原创] What are filler cells?
发表于 2014-3-7 10:47:48 | 显示全部楼层 |阅读模式
Filler cells  are just cells which do nothing..
If any changes are required in the layout after the whole layout process is complete(say u encounter a hardware bug), one can remove the filler cells and place actual logic instead of that.
Typical use is when ECOs occur in the design.
 楼主| 发表于 2014-3-7 10:52:25 | 显示全部楼层
回复 1# xialishui1987
FIller Cell are empty Cells with only Power and Ground Rails. After Place and Route there will be enpty areas left in the row and hence the power will not reach all the cells due this discontinuity. After adding filler cells this discontinuity will go away. Also few people make use of filler cell for increasing the metal density and poly density by using the empty space in filler Cell.
发表于 2014-3-7 11:01:36 | 显示全部楼层
filler cells also have two types : with cap or not. please add the cap first
 楼主| 发表于 2014-3-9 20:27:06 | 显示全部楼层
回复 3# david1121
    thx,i have google the detailed info here http://asic.ams.com/hitkit/hk410/edi/flow.html
发表于 2014-3-10 09:52:51 | 显示全部楼层
E文交流综合征~ 哈哈,
 楼主| 发表于 2014-3-12 09:10:37 | 显示全部楼层
回复 5# gnoc
   thx for focus, hei hei...
发表于 2015-12-10 08:09:01 | 显示全部楼层
it is very hard question
GMT+8, 2024-4-26 01:27 , Processed in 0.031663 second(s), 9 queries , Gzip On, Redis On.
