在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1504|回复: 2
[求助] compile -no_design_rule
发表于 2014-2-20 12:49:00 | 显示全部楼层 |阅读模式
请问compile的时候,加上-no_design_rule,目的是干嘛呢?
发表于 2014-3-8 10:56:43 | 显示全部楼层
-no_design_rule
              Determines, along with the -only_design_rule and -only_hold_time
              options, whether the command fixes design-rule violations before
              exiting.  The -no_design_rule option specifies for  the  command
              to  exit before fixing design-rule violations, thus allowing you
              to check the results in a constraint report  before  fixing  the
              violations.    The   -no_design_rule,   -only_design_rule,   and
              -only_hold_time options are mutually  exclusive.   You  can  use
              only one of the options.  The default is to perform both design-
              rule fixing and mapping optimizations before exiting.
 楼主| 发表于 2014-3-10 15:22:35 | 显示全部楼层
回复 2# david1126
如果加上no_design_rule,那么不就没有优化design_rule的东西了。
比如我前面已经设置了,
set_max_transition 3.0 [current_design]set_max_capacitance 1 [current_design]
set_max_fanout 32 [current_design]
还起作用吗?
谢谢
GMT+8, 2024-4-25 15:40 , Processed in 0.020305 second(s), 6 queries , Gzip On, Redis On.
