在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 17310|回复: 47
RSoft_System_suite_2013.12 (license)
发表于 2014-2-7 12:29:09 | 显示全部楼层 |阅读模式
thanks baluba for uploaded  RSoft_System_suite_2013.12
i create license for this tool
this license has modesys feature for multi-mode simulation
发表于 2014-2-7 14:43:49 | 显示全部楼层
回复 1# mabas.masood
so , where's the license?
 楼主| 发表于 2014-2-8 03:16:47 | 显示全部楼层
回复 2# yaoguaiws
    you must generate with new licgen
Synopsys.src.rar
10.62 KB, 下载次数: 473 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2014-2-8 20:47:14 | 显示全部楼层
回复 3# mabas.masood
oh, that's great, really appreciating, guy~
发表于 2014-2-15 16:52:07 | 显示全部楼层
Hi,mabas.masood friend,please give me a install notes,thank you .
after i install the software ,it isn't working .
 楼主| 发表于 2014-2-15 17:40:03 | 显示全部楼层
回复 5# zxdr5
hi,
0- install scl, Rsoft and generate license
1-  add this line into .bashrc
SNPSLMD_LICENSE_FILE=27000@mabas; export SNPSLMD_LICENSE_FILE
/opt/synopsys/10.9.3/linux/bin/lmgrd -c /usr/local/flexlm/licenses/license.dat -l /var/log/dc_debug.log
export RSOFT_PROGRAMPATH=/opt/synopsys/RSoft.Component.Design.suite.2013.12/bin
export LD_LIBRARY_PATH=/opt/synopsys/RSoft.Component.Design.suite.2013.12/bin
export PATH=/opt/synopsys/RSoft.Component.Design.suite.2013.12/binPATH
export PATH=/opt/synopsys/RSoft.System.suite.2013.12/binPATH
2- open terminal and run this line
             rsmld &
3- run Optsim
发表于 2014-2-15 18:28:55 | 显示全部楼层
Tnank you,i install the software on win7,it isn't working .
the license also has RSOFT_LMGRD_CHECK feature,i unknow why the software don't work .
Please tell me how to do ?
发表于 2014-4-17 22:47:49 | 显示全部楼层
goooooooooooooooooooooooood
发表于 2014-4-18 02:53:34 | 显示全部楼层
多谢多谢了!
发表于 2014-5-8 18:02:15 | 显示全部楼层
回复 9# YULONGUTK
    hello . i installed and cracked Rsoft v9
    but its crack did not worke correctly.
    for example : in the non-linear  photonic crystal did not work its Kerr Effect but Kerr Effect worked correctly on rsoft v8 and v5
     Kerr Effect didnot worked in this version with this crack (v9).
     Kerr Effect is  very important for designing the non-linear photonic devices.
     can you helpe me ??
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-25 05:21 , Processed in 0.029938 second(s), 7 queries , Gzip On, Redis On.
