查看: 6688|回复: 18
裂纹 medicine(лекарство) Aldec.Riviera-PRO-2013.06-x64
发表于 2014-1-4 19:29:56 | 显示全部楼层 |阅读模式
裂纹 medicine(лекарство) for Aldec.Riviera-PRO-2013.06-x64 :
KOREb_crk_Riviera-2013.06x64.part01.rar (10 MB , 下载次数: 86 )
KOREb_crk_Riviera-2013.06x64.part02.rar (10 MB , 下载次数: 78 )
KOREb_crk_Riviera-2013.06x64.part03.rar (7.42 MB , 下载次数: 78 )
get setup files from weigaozu :
http://bbs.eetop.cn/viewthread.php?tid=414994&extra=&page=1
发表于 2014-1-6 00:18:08 | 显示全部楼层
patch is not working, application closed after some minutes, How should I use it
发表于 2014-1-6 02:08:39 | 显示全部楼层
check that patched files last modification time is the same as for original ones. :
advanced_dataflow_plugin.dll        3 734 016        21.06.2013 14:06        -a--
asdbcompare.exe        3 660 288        21.06.2013 13:30        -a--
ccviewer.exe        4 700 672        21.06.2013 13:46        -a--
comp96.dll        4 884 480        21.06.2013 12:31        -a--
connector.dll        2 200 064        21.06.2013 13:48        -a--
events_listener.dll        1 869 312        21.06.2013 11:46        -a--
licensediagnose.exe        2 082 816        21.06.2013 14:11        -a--
protectip.exe        2 881 024        21.06.2013 13:35        -a--
simulation_controller.dll        12 982 784        21.06.2013 14:02        -a--
simulation_controller_commands.dll        4 832 256        21.06.2013 13:44        -a--
tbpviewer.exe        2 783 744        21.06.2013 13:46        -a--
tcviewer.exe        2 283 008        21.06.2013 13:46        -a--
vca.dll        49 703 424        21.06.2013 12:30        -a--
vcdcompare.exe        2 072 064        21.06.2013 13:34        -a--
wwbsystem.dll        2 287 616        21.06.2013 13:51        -a--
that may help.
发表于 2014-1-6 08:44:19 | 显示全部楼层
回复 1# zxw227ekat
    感谢分享,呵呵。
 楼主| 发表于 2014-1-14 19:01:23 | 显示全部楼层
回复 2# mfn
problem found:
it is wrong license syntax !
if anybody find valid expired license from aldec for 2010-2013 years i make the working crk.
发表于 2014-1-16 06:52:29 | 显示全部楼层
great post
发表于 2014-1-16 16:51:48 | 显示全部楼层
 楼主| 发表于 2014-1-19 23:24:55 | 显示全部楼层
Riviera shut down after a couple of minutes, because license file from EFA-team,
comes with Riviera-2009 does not fit  to  Riviera-2013.!!!!!
Anybody have original(expired) license file for Riviera-2013???
 楼主| 发表于 2014-1-23 00:54:59 | 显示全部楼层
Found the cause of Riviera termination:
There are the FEATURE-terminator: RIVIERAPRO_ALL_FEATURES.
If delete this FEATURE from EFA-team license the soft start work OK.
The patch is worked as I say earlier.
 楼主| 发表于 2014-1-23 01:34:36 | 显示全部楼层
worked license file from brother ald_syn_cad,
just rename it to license_riviera.dat and copy to c:\flexlm\ :
License_riviera_ald_syn_cad.rar (3.83 KB , 下载次数: 41 )
GMT+8, 2025-12-14 09:19 , Processed in 0.030445 second(s), 9 queries , Gzip On, Redis On.
