楼主 |
发表于 2013-12-18 21:53:14
显示全部楼层
回复 2# onepieceligen
But Many papers use this techniques.
Such as
Han-Jian Lee, Che-Sheng Chen, etc. A mismatch Compensation Circuit for CMOS Quadrature VCO Phase Error.
Pietro Andreani, etc. Analysis and Design of a 1.8-GHz CMOS LC Quadrature VCO, JSSC.
QVCO output is just single tone with phase shift of 0,90,180,270 degree.
And I intend to use some Baseband Quadrature Signal to mix it,
the circuit was designed so as to eliminate the f1+f2 part, if QVCO is perfectly quadrature.
You mentioned the input IR, do you mean the deviation of Baseband Test Signal?
As QVCO output is already considered as imperfect. |
