在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: sme-ic
Verdi 2013.07和nLint 2011.10 license 生成方法
发表于 2013-12-29 19:11:04 | 显示全部楼层
回复 11# sme-ic
    我準備下載,是看能否使用。謝謝提供資源。
发表于 2013-12-29 19:27:30 | 显示全部楼层
snslmgrd 已下載,明日下載 package 後,再試安裝!
发表于 2014-1-1 23:54:15 | 显示全部楼层
./lmgrd -c /usr/synopsys/verdi3/license/license.dat
[asic@localhost bin]$ 21:44:54 (lmgrd) -----------------------------------------------
21:44:54 (lmgrd)   Please Note:
21:44:54 (lmgrd)
21:44:54 (lmgrd)   This log is intended for debug purposes only.
21:44:54 (lmgrd)   In order to capture accurate license
21:44:54 (lmgrd)   usage data into an organized repository,
21:44:54 (lmgrd)   please enable report logging. Use Acresso Software Inc.'s
21:44:54 (lmgrd)   software license administration  solution,
21:44:54 (lmgrd)   FLEXnet Manager, to  readily gain visibility
21:44:54 (lmgrd)   into license usage data and to create
21:44:54 (lmgrd)   insightful reports on critical information like
21:44:54 (lmgrd)   license availability and usage. FLEXnet Manager
21:44:54 (lmgrd)   can be fully automated to run these reports on
21:44:54 (lmgrd)   schedule and can be used to track license
21:44:54 (lmgrd)   servers and usage across a heterogeneous
21:44:54 (lmgrd)   network of servers including Windows NT, Linux
21:44:54 (lmgrd)   and UNIX. Contact Acresso Software Inc. at
21:44:54 (lmgrd)   www.acresso.com for more details on how to
21:44:54 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
21:44:54 (lmgrd)   for your enterprise.
21:44:54 (lmgrd)
21:44:54 (lmgrd)
21:44:54 (lmgrd)
21:44:54 (lmgrd) FLEXnet Licensing (v11.6.0.0 build 60117 i86_re3) started on asic (linux) (1/1/2014)
21:44:54 (lmgrd) Copyright (c) 1988-2008 Acresso Software Inc. All Rights Reserved.
21:44:54 (lmgrd) US Patents 5,390,297 and 5,671,412.
21:44:54 (lmgrd) World Wide Web:  http://www.acresso.com
21:44:54 (lmgrd) License file(s): /usr/synopsys/verdi3/license/license.dat
21:44:54 (lmgrd) lmgrd tcp-port 14451
21:44:54 (lmgrd) Starting vendor daemons ...
21:44:54 (lmgrd) Started snslmgrd (internet tcp_port 47539 pid 14463)
21:44:54 (snslmgrd) FLEXnet Licensing version v11.6.0.0 build 60117 i86_re3
21:44:54 (snslmgrd) Server started on asic for: DataExpansion
21:44:54 (snslmgrd) DataExpansionCoverage DataExpansionSim DataReplay
21:44:54 (snslmgrd) DataReplaySim       Debussy         Debussy_shared
21:44:54 (snslmgrd) EssentialSignalAnalysis Extraction  FLE_main
21:44:54 (snslmgrd) FL_cosim_run        FL_ice_run      FL_multichip_partition
21:44:54 (snslmgrd) FL_recalc   Gaia            Gate2LayoutCorrelation
21:44:54 (snslmgrd) Gate2RTLCorrelation Gsim_dump_advance Gsim_dump_basic
21:44:54 (snslmgrd) Gsim_framework_basic Gsim_snapshot  Gsim_wave
21:44:54 (snslmgrd) GuidedTraceAnalysis HDL2SC_mixed    HDL2SC_verilog
21:44:54 (snslmgrd) HDL2SC_vhdl Laker_AMS       Laker_L1
21:44:54 (snslmgrd) Laker_L2    Laker_L3        Laker_T1
21:44:54 (snslmgrd) Laker_T1_LE Laker_iDRC      Laker_iLVS
21:44:54 (snslmgrd) Reusner             RtlGateCorrelation SKDB_Import
21:44:54 (snslmgrd) SilVE               Siloti          Siloti_fe
21:44:54 (snslmgrd) Siloti_o2   SimVE           TLM_Synthesis
21:44:54 (snslmgrd) TestDesignCorrelation TestVE                TimingAnalysis
21:44:54 (snslmgrd) WhatIfAnalysis      hdlin           hdlin_mixed
21:44:54 (snslmgrd) hdlin_verilog       hdlin_vhdl      nAnalyzer
21:44:54 (snslmgrd) nBench              nClock          nCompare
21:44:54 (snslmgrd) nECO                nESL            nMonitor
21:44:54 (snslmgrd) nProp               nSchema         nSchemaOnly
21:44:54 (snslmgrd) nState              nTiming         nTrace
21:44:54 (snslmgrd) nTree               nWave           nlcc
21:44:54 (snslmgrd) tSchema             turboSchema     turboState
21:44:54 (snslmgrd) turboWave
21:44:54 (snslmgrd) EXTERNAL FILTERS are OFF
21:44:54 (snslmgrd) Vendor daemon can't talk to lmgrd (License server machine is down or not responding. (-96,7:2 "No such file or directory"))
21:44:54 (snslmgrd) EXITING DUE TO SIGNAL 37 Exit reason 5
21:44:54 (lmgrd) snslmgrd exited with status 37 (Communications error)
21:44:54 (lmgrd) Please correct problem and restart daemons
这个怎么回事  大侠
发表于 2014-1-1 23:55:21 | 显示全部楼层
21:44:54 (lmgrd)
21:44:54 (lmgrd)
21:44:54 (lmgrd)
21:44:54 (lmgrd)
这个怎么回事
发表于 2014-1-2 21:05:29 | 显示全部楼层
19:34:31 (lmgrd) The TCP port number in the license, 14451, is already in use.
19:34:31 (lmgrd) Possible causes:
19:34:31 (lmgrd)    1) The license server manager (lmgrd) is already running for this license.
19:34:31 (lmgrd)    2) The OS has not "cleared" this port since lmgrd died.
19:34:31 (lmgrd)    3) Another process is using this port number (unlikely).
19:34:31 (lmgrd) Solutions:
19:34:31 (lmgrd)    1) Make sure lmgrd and all vendor daemons for this license are not running.
19:34:31 (lmgrd)
19:34:31 (lmgrd)    2) You may have to wait for the OS to clear this port.
19:34:31 (lmgrd) Retrying for about 5 more minutes
19:35:07 (lmgrd) Still trying...
19:35:25 (lmgrd) Still trying...
19:35:43 (lmgrd) Still trying...
19:36:01 (lmgrd) Still trying...
19:36:19 (lmgrd) Still trying...
19:36:37 (lmgrd) Still trying...
19:36:55 (lmgrd) Still trying...
19:37:13 (lmgrd) Still trying...
19:37:31 (lmgrd) Still trying...
19:37:49 (lmgrd) Still trying...
19:38:04 (lmgrd) Failed to open the TCP port number in the license.
发表于 2014-1-4 01:32:24 | 显示全部楼层
謝謝無私分享,辛苦了,謝謝
发表于 2014-1-10 16:19:39 | 显示全部楼层
感谢分享,谢谢。
发表于 2014-1-11 09:59:11 | 显示全部楼层
好東西 感恩
发表于 2014-1-11 10:53:02 | 显示全部楼层
回复 1# sme-ic
   这个license是单机版,还是服务器版?
发表于 2014-1-11 17:54:50 | 显示全部楼层
invalid license key??
GMT+8, 2024-4-26 13:13 , Processed in 0.028283 second(s), 5 queries , Gzip On, Redis On.
