在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 12453|回复: 52
[原创] VLSI,SOC,processor,verilog等资料打包放送,识货的进
发表于 2013-8-26 18:31:33 | 显示全部楼层 |阅读模式
不多说,直接上附件。这些都是我经过精心挑选的资料
VLSI资料如下:
A Designer\'s Guide to Asynchronous VLSI.pdf (4.04 MB, 下载次数: 93 )
Algorithms And Data Structures In Vlsi Design.pdf (2.92 MB, 下载次数: 161 )
An Efficient VLSI Architecture of Fractional Motion Estimation in H.264 for HDTV.pdf (3.54 MB, 下载次数: 83 )
Clocking in Modern VLSI Systems.pdf (12.01 MB, 下载次数: 139 )
abbr_15520f3188a7fd64ecc2a89163082a6a.pdf (12.51 MB, 下载次数: 80 )
McGraw Hill - Fundamentals of Digital Logic with Verilog Design(2nd Edition).pdf (6.29 MB, 下载次数: 87 )
Mead Conway - Introduction to VLSI Systems.pdf (13.32 MB, 下载次数: 89 )
microprocessor design_a practical guide from desgin planning to manufacturing.pdf (6.13 MB, 下载次数: 94 )
Modern VLSI Design IP-Based Design, Fourth Edition.pdf (6.71 MB, 下载次数: 108 )
power_distribution_network_design_for_vlsi_.pdf (4.88 MB, 下载次数: 85 )
Principles of VLSI RTL Design A Practical Guide.pdf (6.98 MB, 下载次数: 96 )
The Design of an Asynchronous Microprocessor.pdf (861.91 KB, 下载次数: 55 )
VLIW Microprocessor Hardware Design.pdf (2.12 MB, 下载次数: 76 )
VLSI Implementation of an Adaptive Multiuser Detector for Multirate WCDMA Systems.pdf (842.91 KB, 下载次数: 36 )
VLSI Programmable Digital Filter for Video Signal Processing.pdf (1.51 MB, 下载次数: 102 )
VLSI Test Principles and Architectures Design for Testability.pdf (5.66 MB, 下载次数: 78 )
VLSI数字信号处理——设计与实现.pdf (3.82 MB, 下载次数: 99 )
verilog资料如下:
[★Sunburst]The Fundamentals of Efficient Synthesizable Finite State Machine.pdf (1.98 MB, 下载次数: 70 )
A SystemC Primer.pdf (6.27 MB, 下载次数: 74 )
Digital System Design with SystemVerilog.pdf (2.95 MB, 下载次数: 65 )
esnug06_abiliss_article.pdf (165.15 KB, 下载次数: 24 )
FPGAs 101 Everything you need to know to get started.pdf (7.4 MB, 下载次数: 80 )
Nonblocking Assignments in Verilog Synthesis, Coding Styles That Kill.pdf (69.84 KB, 下载次数: 34 )
abbr_9c2d5ca2df7b3a11bf20354761cf4d41.pdf (596.7 KB, 下载次数: 23 )
Principles of Verifiable RTL Design.2nd.Edition.pdf (3.95 MB, 下载次数: 67 )
SNUG2000非阻塞赋值.pdf (67.34 KB, 下载次数: 27 )
system verilog.pdf (2.51 MB, 下载次数: 48 )
The Verilog Hardware Description Language课件.pdf (294.37 KB, 下载次数: 31 )
The_Simple_Art_of_SoC_Design_Closing_the_Gap_between_RTL_and_ESL.pdf (5.06 MB, 下载次数: 54 )
Verilog.HDL.A.Guide.To.Digital.Design.And.Synthesis.2nd.Edition.chm (1.66 MB, 下载次数: 56 )
VerilogTutorial.pdf (4.87 MB, 下载次数: 66 )
基于Verilog HDL语言的32X8 FIFO设计.PDF (90.48 KB, 下载次数: 43 )
高速异步FIFO的实现.PDF (99.39 KB, 下载次数: 47 )
soc
资料在此:
Chip Multiprocessor Architecture Techniques to Improve Throughput and Latency.pdf (5.56 MB, 下载次数: 76 )
Chip Multiprocessor Architecture Techniques to Improve Throughput and Latency.pdf (5.56 MB, 下载次数: 32 )
Chip Multiprocessor Architecture_ Techniques to Improve Throughput and Latency.pdf (5.51 MB, 下载次数: 36 )
Co-design for System Acceleration.pdf (2.65 MB, 下载次数: 64 )
Communication Architecture Synthesis for Multi-bus SoC.pdf (379.75 KB, 下载次数: 44 )
Embedded Software Design and Programming of Multiprocessor System-on-Chip.pdf (3.18 MB, 下载次数: 63 )
HiBRID-SoC A Multi-Core SoC Architecture for Multimedia Signal Processing.pdf (569.41 KB, 下载次数: 33 )
Instruction Level Power Analysis and Optimization of Software.pdf (1.53 MB, 下载次数: 32 )
Low Power Methodology Manual For System-On-Chip Design.pdf (3.91 MB, 下载次数: 77 )
Low_Power_Methodology_Manual_for_Soc_Design.pdf (7.46 MB, 下载次数: 55 )
Metamodeling-Driven_IP_Reuse_for_SoC_Integration_and_Microprocessor_Design.pdf (1.73 MB, 下载次数: 56 )
Morgan Kaufmann - Multiprocessor Systems-on-Chips [SoC] - 2004 - (By Laxxus.pdf (2.9 MB, 下载次数: 47 )
abbr_9c2d5ca2df7b3a11bf20354761cf4d41.pdf (596.7 KB, 下载次数: 22 )
Rapid Prototyping of Digital Systems - 2008.pdf (8.68 MB, 下载次数: 41 )
RapidIO - The Embedded System Interconnect.pdf (5.75 MB, 下载次数: 47 )
Reuse Methodology Manual for SoC_3rd.pdf (6.42 MB, 下载次数: 42 )
Reuse Methodology Manual Third Edition.pdf (6.42 MB, 下载次数: 38 )
Springer.System.Level.Design.of.Reconfigurable.Systems.on.Chip.Nov.2005.eBook-DDU.pdf (6.53 MB, 下载次数: 45 )
SURVIVING THE DESIGN OF MICROPROCESSOR and mutiprocessor design_lesson learned.pdf (1.34 MB, 下载次数: 37 )
The Odd Couple hardware and software.pdf (408.15 KB, 下载次数: 28 )
The_Simple_Art_of_SoC_Design_Closing_the_Gap_between_RTL_and_ESL.pdf (5.06 MB, 下载次数: 53 )
XukePhD_Power-efficient Design Methodology for Video Decoding .pdf (7.85 MB, 下载次数: 47 )
片上系统源代码.zip (4.54 MB, 下载次数: 116 )
abbr_a0ebf6561213830ea1d452f780992a99.pdf (3.99 MB, 下载次数: 37 )
processor资料在此:
56-The Future of Microprocessors.pdf (329.7 KB, 下载次数: 31 )
A Multi-Shared Register File Structure for VLIW processors.pdf (842.78 KB, 下载次数: 30 )
Addressing GPU On-Chip Shared Memory Bank using elastic pipeline.pdf (1.24 MB, 下载次数: 33 )
AMD Opteron.Northbridge.pdf (1.53 MB, 下载次数: 32 )
Application-specific Processor Architecture Then and Now.pdf (518.9 KB, 下载次数: 36 )
ARM_Cortex-A8微处理器的架构和实现.pdf (1.03 MB, 下载次数: 82 )
CPU GPU.pdf (898.58 KB, 下载次数: 41 )
Digital.Logic.And.Microprocessor.Design.With.VHDL.pdf (5.63 MB, 下载次数: 39 )
FREESCALE’S LOW-POWER MUTITHREAD PROCESSOR.pdf (1.03 MB, 下载次数: 51 )
From Bit Level Systolic Arrays to HDTV Processor Chips.pdf (433.03 KB, 下载次数: 24 )
High-Performance Energy-Efficient Microprocessor Design.pdf (5.98 MB, 下载次数: 44 )
Instruction Shuffle Achieving MIMD like Performance on SIMD Architectures.pdf (613.46 KB, 下载次数: 26 )
Intel\'s Next Generation Microarchitecture.pdf (241.76 KB, 下载次数: 30 )
ISSC session3 processor.pdf (12.55 MB, 下载次数: 50 )
McGraw.Hill.VLIW.Microprocessor.Hardware.Design.Aug.2007.pdf (1.92 MB, 下载次数: 64 )
Microprocessor Architecture - From Simple Pipelines to Chip Multiprocessors.pdf (12.64 MB, 下载次数: 64 )
MIPS Assembly Language Programming Robert Britton.pdf (561.51 KB, 下载次数: 26 )
MIPS instruction set.pdf (1.22 MB, 下载次数: 51 )
MIPS 处理器的SystemC 实现_孙伟斌.pdf.pdf (305.09 KB, 下载次数: 34 )
mips32 architecture.pdf (495.96 KB, 下载次数: 44 )
Processor Architectures For Multimedia.. A Survey.pdf (60.57 KB, 下载次数: 27 )
Processor Design System-On-Chip Computing for ASICs and FPGAs.pdf (14.93 MB, 下载次数: 70 )
REDEFINING THE ROLE OF THE CPU IN GPU.pdf (898.58 KB, 下载次数: 25 )
See_MIPS_Run-2nd_edition-Chinese-All-20071231.pdf (6.23 MB, 下载次数: 52 )
stream processor.pdf (1.13 MB, 下载次数: 40 )
大话处理器.pdf (6.33 MB, 下载次数: 168 )
后端资料:
[M.Keating]Low Power Methodology Manual For System-on-Chip Design.pdf (3.66 MB, 下载次数: 78 )
Clocking in Modern VLSI Systems.pdf (12.01 MB, 下载次数: 79 )
Clocking in Modern VLSI Systems.zip (9.95 MB, 下载次数: 39 )
[M.Keating]Low Power Methodology Manual For System-on-Chip Design.pdf (3.66 MB, 下载次数: 35 )
Clocking in Modern VLSI Systems.pdf (12.01 MB, 下载次数: 43 )
Clocking in Modern VLSI Systems.zip (9.95 MB, 下载次数: 27 )
CMOS VLSI Design A Circuits and Systems Perspective 4th Edition.pdf (10.78 MB, 下载次数: 75 )
CMOS_Transistor_Layout.pdf (2.12 MB, 下载次数: 66 )
eetop.cn_CMOS VLSI Design A Circuits and Systems Perspective 4th Edition.pdf (10.78 MB, 下载次数: 30 )
digital cmos.pdf (10.33 MB, 下载次数: 72 )
High-Performance Energy-Efficient Microprocessor Design.pdf (5.98 MB, 下载次数: 83 )
Power-efficient System Design.pdf (9 MB, 下载次数: 82 )
TCL培训教程(华为内部资料).pdf (403.81 KB, 下载次数: 63 )
Timing (2004 Kluwer).pdf (7.29 MB, 下载次数: 88 )
Verilog典型电路设计_华为.pdf (283.6 KB, 下载次数: 69 )
北京大学电路设计实习.pdf (5.57 MB, 下载次数: 73 )
陈涛后端面试总结_v1.doc (564 KB, 下载次数: 30 )
模拟电路版图设计中的匹配艺术.pdf (179.48 KB, 下载次数: 27 )
数字集成电路(设计透视).pdf (14.42 MB, 下载次数: 93 )
asic:
Nonblocking Assignments in Verilog Synthesis, Coding Styles That Kill - 副本.pdf
69.84 KB, 下载次数: 26 , 下载积分: 资产 -2 信元, 下载支出 2 信元
可重构SOC专利.pdf
3.38 MB, 下载次数: 48 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Multilevel Cache Modeling for Chip mutiprocessor systems.pdf
424.42 KB, 下载次数: 34 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2013-8-26 21:32:29 | 显示全部楼层
VERY GOOD,3X
发表于 2013-8-27 09:13:16 | 显示全部楼层
资料很多
发表于 2013-8-27 12:42:54 | 显示全部楼层
thanks
发表于 2013-8-27 13:21:14 | 显示全部楼层
楼主太强大
发表于 2013-8-27 13:36:09 | 显示全部楼层
有些是重复的..
发表于 2013-8-27 13:44:37 | 显示全部楼层
楼主牛x啊!
发表于 2013-8-27 14:15:50 | 显示全部楼层
下个先
发表于 2013-8-27 16:01:28 | 显示全部楼层
总算信源不足,唉
发表于 2013-8-27 16:39:14 | 显示全部楼层
信源不足,你呢
GMT+8, 2024-3-29 13:43 , Processed in 0.045655 second(s), 10 queries , Gzip On, Redis On.
