在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 24312|回复: 12
[求助] 综合时总是出现Warning: Output pins are stuck at VCC or GND
发表于 2013-7-11 14:59:51 | 显示全部楼层 |阅读模式
verilog程序时始终出现下面的警告:
        Warning (13410): Pin "rx_data0[1]" is stuck at GND
        Warning (13410): Pin "rx_data0[2]" is stuck at GND
        Warning (13410): Pin "rx_data0[3]" is stuck at GND
        Warning (13410): Pin "rx_data0[4]" is stuck at GND
        Warning (13410): Pin "rx_data0[5]" is stuck at GND
        Warning (13410): Pin "rx_data0[6]" is stuck at GND
        Warning (13410): Pin "rx_data0[7]" is stuck at GND
        Warning (13410): Pin "rx_data1[1]" is stuck at GND
        Warning (13410): Pin "rx_data1[2]" is stuck at GND
        Warning (13410): Pin "rx_data1[3]" is stuck at GND
        Warning (13410): Pin "rx_data1[4]" is stuck at GND
        Warning (13410): Pin "rx_data1[5]" is stuck at GND
        Warning (13410): Pin "rx_data1[6]" is stuck at GND
        Warning (13410): Pin "rx_data1[7]" is stuck at GND
        Warning (13410): Pin "rx_data2[1]" is stuck at GND
        Warning (13410): Pin "rx_data2[2]" is stuck at GND
        Warning (13410): Pin "rx_data2[3]" is stuck at GND
        Warning (13410): Pin "rx_data2[4]" is stuck at GND
        Warning (13410): Pin "rx_data2[5]" is stuck at GND
        Warning (13410): Pin "rx_data2[6]" is stuck at GND
        Warning (13410): Pin "rx_data2[7]" is stuck at GND
        Warning (13410): Pin "rx_data3[1]" is stuck at GND
        Warning (13410): Pin "rx_data3[2]" is stuck at GND
        Warning (13410): Pin "rx_data3[3]" is stuck at GND
        Warning (13410): Pin "rx_data3[4]" is stuck at GND
        Warning (13410): Pin "rx_data3[5]" is stuck at GND
        Warning (13410): Pin "rx_data3[6]" is stuck at GND
        Warning (13410): Pin "rx_data3[7]" is stuck at GND
        Warning (13410): Pin "rx_data4[1]" is stuck at GND
        Warning (13410): Pin "rx_data4[2]" is stuck at GND
        Warning (13410): Pin "rx_data4[3]" is stuck at GND
        Warning (13410): Pin "rx_data4[4]" is stuck at GND
        Warning (13410): Pin "rx_data4[5]" is stuck at GND
        Warning (13410): Pin "rx_data4[6]" is stuck at GND
        Warning (13410): Pin "rx_data4[7]" is stuck at GND
不知道究竟哪里出问题了,寻高人指点,代码如下:
module data(
                                clk,rst_n,
                                rx_data_r,
                                 rx_data0,rx_data1,rx_data2,rx_data3,rx_data4,
                                 DATA_ready,DATA_EN,
                                 reg_num
input clk;                // 50MHz主时钟
input rst_n;        //低电平复位信号
input DATA_ready;
input rx_data_r;
  output[7:0] rx_data0;        //接收数据寄存器,保存直至下一个数据来到
  output[7:0] rx_data1;        //接收数据寄存器,保存直至下一个数据来到
  output[7:0] rx_data2;        //接收数据寄存器,保存直至下一个数据来到
  output[7:0] rx_data3;        //接收数据寄存器,保存直至下一个数据来到
  output[7:0] rx_data4;        //接收数据寄存器,保存直至下一个数据来到
  output DATA_EN;
  output[5:0] reg_num;
     reg[7:0] rx_data0;
          reg[7:0] rx_data1;
          reg[7:0] rx_data2;
          reg[7:0] rx_data3;
          reg[7:0] rx_data4;
          reg[5:0] reg_num;
          reg DATA_EN;
always @ (posedge clk or negedge rst_n) begin
        if(!rst_n) DATA_EN <= 1'b0;
   else begin
                if(((rx_data_r == 8'b1) && (reg_num == 5'b0))|| (reg_num == 5'b00001) || (reg_num == 5'b00010)|| (reg_num == 5'b00011)|| (reg_num == 5'b00100)|| (reg_num == 5'b00101)) begin
                DATA_EN <= 1'b1; //监测上位机是否发来控制信息
                end
                else DATA_EN <= 1'b0;
    end
end
always @ (posedge DATA_ready or negedge rst_n) begin
         if(!rst_n) reg_num <= 5'b0;
         else begin
          if(DATA_EN) begin
                                    reg_num <= reg_num+1'b1;
             if(reg_num == 5'b00110)begin
                                        reg_num <= 5'b00000;
                                  end
      end
   end
end
         if(!rst_n) begin
                   rx_data0 <= 8'b0;
            rx_data1 <= 8'b0;
            rx_data2 <= 8'b0;
            rx_data3 <= 8'b0;
            rx_data4 <= 8'b0;
          end
         else begin
           if(DATA_EN) begin
                case (reg_num)
                                                5'b00001 :rx_data0 <= rx_data_r ;        //锁存第一个数据
                                                5'b00010 :rx_data1 <= rx_data_r ;        //锁存第二个数据
                                                5'b00011 :rx_data2 <= rx_data_r ;        //锁存第三个数据
                                                5'b00100 :rx_data3 <= rx_data_r ;        //锁存第四个数据
                                                5'b00101 :rx_data4 <= rx_data_r ;        //锁存第五个数据
                                                default: ;
                     endcase
           end
        end
end
        endmodule
发表于 2013-7-11 15:05:58 | 显示全部楼层
rx_data_r只有1bit
rx_data是8bit
开头加一句
wire [7:0] rx_data_r;
 楼主| 发表于 2013-7-11 15:28:50 | 显示全部楼层
我知道了,已经成功解决了,就一个小错误折腾了好多天啊!我qq是2314048725,欢迎大家交流
 楼主| 发表于 2013-7-12 15:32:47 | 显示全部楼层
回复 2# jack888518
    是的,就是这么解决的,就这么一个小漏洞,折腾了半天
发表于 2013-7-12 17:34:03 | 显示全部楼层
这种错误其实可以在modelsim中仿真就可以发现的,不用等到综合才去看那么大一堆警告。
 楼主| 发表于 2013-7-23 15:16:12 | 显示全部楼层
回复 5# tangkuan660
是啊,应该先modelsim仿真一下的,现在出现问题了,我现在用MegaWizard_Plug-in调用的PLL IP核,怎么用modelsim仿真啊?
发表于 2013-7-23 15:36:15 | 显示全部楼层
回复 6# 江南炊烟
当然可以仿真的,在quartus安装目录下有对应的仿真库的,PLL也是有的。先编译好库到modelsim中,仿真钢钢的。
 楼主| 发表于 2013-7-24 16:31:13 | 显示全部楼层
回复 7# tangkuan660
    可是我已经折腾两天了,还是没有仿真出来,库文件也添加了,就是没有波形出来。这是testbench代码:
  1. `timescale 1 ns/ 10 ps
  2. module PLL_vlg_tst();
  3. reg eachvec;
  4. reg areset;
  5. reg inclk0;
  6. reg pllena;
  7. // wires
  8. wire c0;
  9. wire locked;
  10. PLL i1 (
  11. .areset(areset),
  12. .c0(c0),
  13. .inclk0(inclk0),
  14. .locked(locked),
  15. .pllena(pllena)
  16. );
  17. always #10 inclk0=~inclk0;
  18. initial
  19. begin
  20. inclk0 =0;
  21. areset = 1'b1;
  22. pllena = 1'b0;
  23. #30 areset = 0;
  24. #30 areset = 1;
  25. #50 pllena = 1;
  26. end
  27. endmodule
复制代码
modelsim仿真library列表:
library列表
library列表
生成的文件列表:
生成文件列表
生成文件列表
仿真结果图:
仿真结果
仿真结果
求指教。还有如果我要实例化这个锁相环的话,是不是只要把生成的PLL.v加入我的工程中,并实例化这个文件就行了么?
发表于 2013-7-24 16:40:47 | 显示全部楼层
我需要信元而已,kanakn
发表于 2013-7-25 10:55:51 | 显示全部楼层
回复 8# 江南炊烟
大哥,它的areset是高电平复位,你一直给高电平,PLL一直复位着,怎么出波形哦?
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-25 06:08 , Processed in 0.028397 second(s), 6 queries , Gzip On, Redis On.
