在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 8111|回复: 11
Cadence Allegro SPB 16.6 Hotfix S009
发表于 2013-5-22 12:44:52 | 显示全部楼层 |阅读模式
安装了cadence软件之后,已经破解好了的童鞋往下看:
1、首先把spb_16.6文件夹命名为spb_16.6old(反正和spb_16.6不一样就行了)。
2、在cadence目录里面建立一个新的空文件夹命名为spb_16.6,并把spb_16.6old的compnts.dat拷贝到空的spb_16.6中
3、安装HOTFIX补丁到空的spb_16.6中;
4、复制ToolsPubkey.bat pubkey1.30.exe pubkey 三个文件到spb_16.6\tools中并运行ToolsPubkey.bat
5、把spb_16.6里面的文件全部复制到spb_16.6old替换旧文件
6、删除spb_16.6文件夹并把spb_16.6old改回spb_16.6
你可以正常使用了
DATE: 05-9-2013    HOTFIX VERSION: 009
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
961420  ALLEGRO_EDITOR PLACEMENT        Regardless of the aspect ratio for room of side The QuickPlace by room command could be placed comp
1079862 ALLEGRO_EDITOR SKILL            Ability to create IPC2581 layer mapping file by Allegro Skill function
1080734 CONCEPT_hdl    CORE             Repainting of grid lines during pan or by moving window show as solid white lines instead of gray da
1104145 ALLEGRO_EDITOR SCHEM_FTB        User defined properties do not appear in PCB
1107547 SCM            OTHER            v15.5.1 tcl/tk code not recognised in 16.6
1110209 CONCEPT_HDL    OTHER            We can move symbols and wires off grid despite the site.cpm grid lock
1117825 CONCEPT_HDL    OTHER            SHOW_CONSOLE_ON_LAUNCH throws an unrecognized directive warning in the schematic editor
1118874 ALLEGRO_EDITOR INTERFACES       Oblong pad shapes are not shown with correct orientation after DXF export from Allegro
1121873 ALLEGRO_EDITOR INTERFACE_DESIGN Importing Bundles from Net Groups does not allow any further editing.
1122933 CONCEPT_HDL    CORE             Newly added Toolbars are getting invisible after re-staring Concepthdl
1124587 ALLEGRO_EDITOR INTERACTIV       The Shape Expansion/Contraction command should also be available in EE mode.
1125895 SIP_layout     LEFDEF_IF        Tool crash while moving the slider in the Filter options Macro tab form of the co-design die library manager
1125962 F2B            DESIGNVARI       Custom Text in Variant Details dialog box is inconsistent
1126096 SCM            REPORTS          Two nets missing in report
1126134 SIG_INTEGRITY  GEOMETRY_EXTRACT Attempting to extract topology hangs APD
1126182 ALLEGRO_EDITOR DRC_CONSTR       Shape fillet DRC in same net thru via to thru via was removed after update DRC.
1130280 ALLEGRO_EDITOR MANUFACT         stream_out command in 16.6 seems hard coded to look for a design called stream_out.brd
1130737 F2B            PACKAGERXL       Error - pxl.exe has stopped working
1131650 ALLEGRO_EDITOR PLOTTING         PDF Publisher doesnot display few component defination properties in Property parameters
1131764 ALLEGRO_EDITOR EDIT_ETCH        Line segment will not slide using the New Slide.
1132638 ALLEGRO_EDITOR DFA              'dfa_update' crashes when running the utility on the attached foder.
1133311 ALLEGRO_EDITOR SKILL            ?origin switch is not working correctly with axlTransformObject while rotating shapes
1133893 SIP_LAYOUT     IMPORT_DATA      netlist-In Wizard crashes
Hotfix_SPB16.60.009_wint_1of1.part12.rar
14.31 MB, 下载次数: 104 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part13.rar
14.31 MB, 下载次数: 99 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part14.rar
14.31 MB, 下载次数: 81 , 下载积分: 资产 -5 信元, 下载支出 5 信元
 楼主| 发表于 2013-5-22 15:31:47 | 显示全部楼层
續傳完成
Hotfix_SPB16.60.009_wint_1of1.part39.rar
2.57 MB, 下载次数: 56 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Hotfix_SPB16.60.009_wint_1of1.part01.rar
14.31 MB, 下载次数: 60 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part02.rar
14.31 MB, 下载次数: 73 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part03.rar
14.31 MB, 下载次数: 65 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part04.rar
14.31 MB, 下载次数: 64 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part05.rar
14.31 MB, 下载次数: 58 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part06.rar
14.31 MB, 下载次数: 53 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part07.rar
14.31 MB, 下载次数: 44 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part08.rar
14.31 MB, 下载次数: 63 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part09.rar
14.31 MB, 下载次数: 48 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part10.rar
14.31 MB, 下载次数: 43 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part11.rar
14.31 MB, 下载次数: 42 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part15.rar
14.31 MB, 下载次数: 41 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part16.rar
14.31 MB, 下载次数: 46 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part17.rar
14.31 MB, 下载次数: 49 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part18.rar
Hotfix_SPB16.60.009_wint_1of1.part19.rar
Hotfix_SPB16.60.009_wint_1of1.part20.rar
Hotfix_SPB16.60.009_wint_1of1.part21.rar
Hotfix_SPB16.60.009_wint_1of1.part22.rar
14.31 MB, 下载次数: 57 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part23.rar
14.31 MB, 下载次数: 51 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part24.rar
Hotfix_SPB16.60.009_wint_1of1.part25.rar
14.31 MB, 下载次数: 40 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part26.rar
14.31 MB, 下载次数: 39 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part27.rar
Hotfix_SPB16.60.009_wint_1of1.part28.rar
Hotfix_SPB16.60.009_wint_1of1.part29.rar
14.31 MB, 下载次数: 35 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part30.rar
14.31 MB, 下载次数: 36 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part31.rar
14.31 MB, 下载次数: 37 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part32.rar
Hotfix_SPB16.60.009_wint_1of1.part33.rar
14.31 MB, 下载次数: 38 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.009_wint_1of1.part34.rar
Hotfix_SPB16.60.009_wint_1of1.part35.rar
Hotfix_SPB16.60.009_wint_1of1.part36.rar
Hotfix_SPB16.60.009_wint_1of1.part37.rar
Hotfix_SPB16.60.009_wint_1of1.part38.rar
发表于 2013-5-27 09:49:43 | 显示全部楼层
花了好多money
发表于 2013-6-5 16:51:24 | 显示全部楼层
谢谢分享!
发表于 2013-6-6 09:38:09 | 显示全部楼层
你这个安装不了 说是确少base文件?
发表于 2013-6-14 14:58:00 | 显示全部楼层
回复 1# scottt
   非常好啊,只需要!
发表于 2013-7-16 07:29:34 | 显示全部楼层
要花那么多钱,下载了一半,钱花光了,又用不了。
发表于 2013-7-16 07:30:27 | 显示全部楼层
应该不错,找了半天才找到这。
发表于 2013-8-15 21:48:40 | 显示全部楼层
好像下不起了
发表于 2014-11-2 16:00:54 | 显示全部楼层
谢谢楼主!
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-16 14:15 , Processed in 0.034126 second(s), 10 queries , Gzip On, Redis On.
