在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 38873|回复: 219
[原创] High-Speed Signaling: Jitter Modeling, Analysis, and Budgeting
发表于 2013-4-25 09:41:22 | 显示全部楼层 |阅读模式
Kyung Suk (Dan) Oh (Author), Xing Chao (Chuck) Yuan (Author)
Hardcover: 528 pages
Publisher: Prentice Hall; 1 edition (October 16, 2011)
Language: English
ISBN-10: 0132826917
ISBN-13: 978-0132826914
本书当然是扫瞄版......
基于爱护地球及环保 , 本书不欢迎列印 , 仅供阅读.....
基于爱护辛勤劳动者 , 不欢迎转贴.....
更不欢迎流出EETOP又流回EETOP.....
PH_Jitter_Modeling_Analysis_Budgeting.part1.rar (14 MB, 下载次数: 2185 )
PH_Jitter_Modeling_Analysis_Budgeting.part2.rar (14 MB, 下载次数: 1857 )
PH_Jitter_Modeling_Analysis_Budgeting.part3.rar (14 MB, 下载次数: 1845 )
PH_Jitter_Modeling_Analysis_Budgeting.part4.rar (14 MB, 下载次数: 1802 )
PH_Jitter_Modeling_Analysis_Budgeting.part5.rar (14 MB, 下载次数: 1863 )
PH_Jitter_Modeling_Analysis_Budgeting.part6.rar (12.85 MB, 下载次数: 1834 )
Table of Contents
Chapter 1: Introduction
    Section 1.1. Signal Integrity Analysis Trends
    Section 1.2. Challenges of High-Speed Signal Integrity Design
    Section 1.3. Organization of This Book
Chapter 2: High-Speed Signaling Basics
    Section 2.1. I/O Signaling Basics and Components
    Section 2.2. Noise Sources
    Section 2.3. Jitter Basics and Decompositions
    Section 2.4. Summary
Part I: Channel Modeling and Design
Chapter 3: Channel Modeling and Design Methodology
    Section 3.1. Channel Design Methodology
    Section 3.2. Channel Modeling Methodology
    Section 3.3. Modeling with Electromagnetic Field Solvers
    Section 3.4. Backplane Channel Modeling Example
    Section 3.5. Summary
Chapter 4: Network Parameters
    Section 4.1. Generalized Network Parameters for Multi-Conductor Systems
    Section 4.2. Preparing an Accurate S-Parameter Time-Domain Model
    Section 4.3. Passivity Conditions
    Section 4.4. Causality Conditions
    Section 4.5. Summary
Chapter 5: Transmission Lines
    Section 5.1. Transmission Line Theory
    Section 5.2. Forward and Backward Crosstalk
    Section 5.3. Time-Domain Simulation of Transmission Lines
    Section 5.4. Modeling Transmission Line from Measurements
    Section 5.5. On-Chip Wire Modeling
    Section 5.6. Comparison of On-Chip, Package, and PCB Traces
    Section 5.7. Summary
Part II: Analyzing Link Performance
Chapter 6: Channel Voltage and Timing Budget
    Section 6.1. Timing Budget Equation and Components
    Section 6.2. Fibre Channel Dual-Dirac Model
    Section 6.3. Component-Level Timing Budget
    Section 6.4. Pitfalls of Timing Budget Equation
    Section 6.5. Voltage Budget Equations and Components
    Section 6.6. Summary
Chapter 7: Manufacturing Variation Modeling
    Section 7.1. Introduction to the Taguchi Method
    Section 7.2. DDR DRAM Command/Address Channel Example
    Section 7.3. Backplane Link Modeling Example
    Section 7.4. Summary
Chapter 8: Link BER Modeling and Simulation
    Section 8.1. Historical Background and Chapter Organization
    Section 8.2. Statistical Link BER Modeling Framework
    Section 8.3. Intersymbol Interference Modeling
    Section 8.4. Transmitter and Receiver Jitter Modeling
    Section 8.5. Periodic Jitter Modeling
    Section 8.6. Summary
Chapter 9: Fast Time-Domain Channel Simulation Techniques
    Section 9.1. Fast Time-Domain Simulation Flow Overview
    Section 9.2. Fast System Simulation Techniques
    Section 9.3. Simultaneous Switching Noise Example
    Section 9.4. Comparison of Jitter Modeling Methods
    Section 9.5. Peak Distortion Analysis
    Section 9.6. Summary
Chapter 10: Clock Models in Link BER Analysis
    Section 10.1. Independent and Common Clock Jitter Models
    Section 10.2. Modeling Common Clocking Schemes
    Section 10.3. CDR Circuitry Modeling
    Section 10.4. Passive Channel JIF and Jitter Amplification
    Section 10.5. Summary
Part III: Supply Noise and Jitter
Chapter 11: Overview of Power Integrity Engineering
    Section 11.1. PDN Design Goals and Supply Budget
    Section 11.2. Power Supply Budget Components
    Section 11.3. Deriving a Power Supply Budget
    Section 11.4. Supply Noise Analysis Methodology
    Section 11.5. Steps in Power Supply Noise Analysis
    Section 11.6. Summary
Chapter 12: SSN Modeling and Simulation
    Section 12.1. SSN Modeling Challenges
    Section 12.2. SI and PI Co-Simulation Methodology
    Section 12.3. Signal Current Loop and Supply Noise
    Section 12.4. Additional SSN Modeling Topics
    Section 12.5. Case Study: DDR2 SSN Analysis for Consumer Applications
    Section 12.6. Summary
Chapter 13: SSN Reduction Codes and Signaling
    Section 13.1. Data Bus Inversion Code
    Section 13.2. Pseudo Differential Signaling Based on 4b6b Code
    Section 13.3. Summary
Chapter 14: Supply Noise and Jitter Characterization
    Section 14.1. Importance of Supply Noise Induced Jitter
    Section 14.2. Overview of PSIJ Modeling Methodology
    Section 14.3. Noise and Jitter Simulation Methodology
    Section 14.4. Case Study
    Section 14.5. Summary
Chapter 15: Substrate Noise Induced Jitter
    Section 15.1. Introduction
    Section 15.2. Modeling Techniques
    Section 15.3. Measurement Techniques
    Section 15.4. Case Study
    Section 15.5. Summary
Chapter 16: On-Chip Link Measurement Techniques
    Section 16.1. Shmoo and BER Eye Diagram Measurements
    Section 16.2. Capturing Signal Waveforms
    Section 16.3. Link Performance Measurement and Correlation
    Section 16.4. On-Chip Supply Noise Measurement Techniques
    Section 16.5. Advanced Power Integrity Measurements
    Section 16.6. Summary
Chapter 17: Signal Conditioning
    Section 17.1. Single-Bit Response
    Section 17.2. Equalization Techniques
    Section 17.3. Equalization Adaptation Algorithms
    Section 17.4. CDR and Equalization Adaptation Interaction
    Section 17.5. ADC-Based Receive Equalization
    Section 17.6. Future of High-Speed Wireline Equalization
    Section 17.7. Summary
Chapter 18: Applications
    Section 18.1. XDR: High-Performance Differential Memory System
    Section 18.2. Mobile XDR: Low Power Differential Memory System
    Section 18.3. Main Memory Systems beyond DDR3
    Section 18.4. Future Signaling Systems
发表于 2013-4-25 13:22:12 | 显示全部楼层
謝謝分享
发表于 2013-4-26 11:47:37 | 显示全部楼层
真是不便宜啊,希望物有所值,呵呵呵。
发表于 2013-4-29 20:04:50 | 显示全部楼层
多谢楼主的分享了,再次感谢了!
发表于 2013-4-29 22:48:36 | 显示全部楼层
感谢楼主的分享了
发表于 2013-4-30 20:58:11 | 显示全部楼层
多谢楼主的分享了,再次感谢了!
发表于 2013-5-2 12:27:45 | 显示全部楼层
Jesus christ! Wonderful materials
发表于 2013-5-2 15:33:47 | 显示全部楼层
内容相当详细~
发表于 2013-5-2 15:37:07 | 显示全部楼层
不小心重覆按~会重覆扣吗
发表于 2013-5-4 21:28:53 | 显示全部楼层
謝謝大大的分享唷~~
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-17 07:51 , Processed in 0.032742 second(s), 10 queries , Gzip On, Redis On.
