在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 8063|回复: 2
[求助] 为什么IBS文件转换不成DML文件?
发表于 2013-3-23 22:27:58 | 显示全部楼层 |阅读模式
我在转TI的一个USB收发器的IBIS文件是,Parse没有问题。但是在转换成IBIS文件是却不OK,我现在将Log File 粘贴在下面:
RUNNING IBISCHK COMMAND: ibischk4 "E:\tusb.ibs"
IBISCHK4 V4.2.0
Checking E:\tusb.ibs for IBIS 4.2 Compatibility...
WARNING - Model FZP18_PD_PI_10P_3P3 Pulldown Minimum data is non-monotonic
WARNING - Model FZP18_PD_PI_5P_3P3 Pulldown Minimum data is non-monotonic
WARNING - Model FZP18_PU_PI_10P_3P3 Pulldown Minimum data is non-monotonic
WARNING - Model FZP18_PU_PI_5P_3P3 Pulldown Minimum data is non-monotonic
WARNING - Model HYPBFZP18_PI_10P_3P3 Pulldown Minimum data is non-monotonic
WARNING - Model HYPBFZP18_PI_5P_3P3 Pulldown Minimum data is non-monotonic
WARNING - Model usb3_WODE: The [Rising Waveform]
       with [R_fixture]=50 Ohms and [V_fixture_max]=1.155V
       has MAX column DC endpoints of  0.60V and  1.12v, but
       an equivalent load applied to the model's I-V tables yields
       different voltages ( 0.61V and  1.12V),
       a difference of  2.74% and  0.09%, respectively.
WARNING - Model usb3_WODE: The [Falling Waveform]
       a difference of  2.66% and  0.06%, respectively.
WARNING - Model usb2_LS_RC Pullup Minimum data is non-monotonic
WARNING - Model usb2_LS_R Pullup Minimum data is non-monotonic
Errors  : 0
Warnings: 10
File Passed
END OF IBISCHK COMMAND OUTPUT
READING IBIS FILE E:\tusb.ibs
ERROR @line 44: Syntax error after parsing the token <Driver Schedule> :
     The previous token began on line 44 and was <[>
RUNNING DMLCHECK for E:\tusb.dml
Translation failed due to IBIS2DML errors.
Output saved as E:\tusb.dml.txt.
Run ibis2signoise -d, a DML will be generated.
Examine it with line numbers from the log message.
希望大家能帮我看看这个问题到底是怎么回事!!!
上面说 Line 44 有语法问题,我把 Line 44 的内容页粘贴如下,谢谢!! 下面第一行就是Line 44 !!
[Driver Schedule] keyword. For example, using HSPICE, refer DE_hspice.sp
                 in the correlation report
                 - To test USB2/USB3 IBIS models using HSPICE look for spice set up files
                 inside the TUSB8040 correlation report        \
                 - Digital Buffer models are from SR60 standard cell library for TUSB8040
                 - Non-Monotonic pulldown warnings related to digital buffers is per
                 simulations
谢谢
发表于 2013-4-6 16:29:48 | 显示全部楼层
IBIS有问题,换一个好的IBIS文件看看。
发表于 2013-5-17 09:49:51 | 显示全部楼层
楼主,我也遇到和你一样的问题,希望你已经搞定。可否给小弟一些提示。 谢谢!
我的邮箱是:huole.zhao@hotmail.com
GMT+8, 2024-3-29 21:34 , Processed in 0.022025 second(s), 9 queries , Gzip On, Redis On.
