在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2893|回复: 0
[资料] [OTHER] StreamGuru MPEG2 TS Analyzer 2.60
发表于 2013-2-17 19:03:22 | 显示全部楼层 |阅读模式
[CENTER][B][SIZE="5"]StreamGuru MPEG2 TS Analyzer 2.60[/SIZE][/COLOR][/B]
[/CENTER]
The analyzer combines the most important MPEG analyzer features into one single product:
[LIST]
Decode all MPEG and DVB service information down to the descriptor level. Current/Next table versions are listed separately. SI information for "other" transport streams is decoded as well. The full range of descriptors defined in MPEG2 and DVB are supported !
Record the entire stream or only selected elementary streams to the harddisk.
Wide range of input device options:
   [LIST]
   Standard DVB-S, DVB-C, DVB-T receiver cards and dongles
   Professional DVB-ASI & DVB-SPI Receiver hardware
   .TS/.TRP/.MPG Files
   [/LIST]
Monitor PCR intervals and accuracy
Teletext level 1.5 decoder
Monitor and export DSM-CC object and data carousels, as they are used by MHEG-5, HBBTV, MHP and a wide range of other interactive services.
IPTV Relay. Incoming streams can be relayed as DVB-IP compatible IPTV stream for further processing.
Monitor the bitrate of individual PIDs and or services
Monitor the overall stream bitrate and the stuffing (wasted bandwidth) bitrate for the stream
Identify AC3/Dolby Digital, DTS and MPEG4 AAC/AVC streams
Hunt for unreferenced/hidden streams in the PID Grid
Conditional Access ECM/EMM Monitoring feature
MPEG2 standard definition and high definition A/V playback (MPEG2 DirectShow codec required)
Support for DVB string encoding type 1F 01/02, as used by BBC/Freesat
[/LIST]
Specification Compliance:
[LIST]
ISO/IEC 13818-1 (MPEG2 - Systems)
ISO/IEC 13818-6 (MPEG2 - DSM-CC)
EN 300 468 V1.7.1 (DVB - Core specification 05/2006)
TR 101 211 V1.7.1 (Guidelines on Implementation and usage of Service Information)
TR 101 290 (Measurement guidelines for DVB Systems)
EN 301 192 (Specification for data broadcasting)
TR 102 033,  TS 102 034, TS 102 814 (DVB-IP, IPTV)
ES 201 812 V1.1.1 (Multimedia Home Platform 1.0.3)
ISO/IEC 13522-5 (MHEG-5)
MHEG-5 UK Profile 1.06
[/LIST]
Home page :
  1. http://www.streamguru.de/mpeg-analyzer/
复制代码
Download links:
  1. http://www.multiupload.nl/QQNS9LFJMO
  2. http://uploadmirrors.com/download/RRHGNMSD/StreamGuru_MPEG2_TS_Analyzer_2.60.rar
  3. http://rapidgator.net/file/78576905/StreamGuru_MPEG2_TS_Analyzer_2.60.rar.html
  4. https://mega.co.nz/#!UpMnDL7I!RFl2in43fq0pApYwfz_KNDL8gE8BE7QrFjhXQj_2DJ4
复制代码
debugasm ;D
GMT+8, 2024-3-29 16:45 , Processed in 0.020888 second(s), 11 queries , Gzip On, Redis On.
