楼主: jevei01
悬赏求synplify2012 linux版可用的license制作
发表于 2013-4-13 11:11:56 | 显示全部楼层
回复 1# jevei01
  你试试这个吧 Synopsys_Licmaker.zip (1.73 MB , 下载次数: 222 )
发表于 2013-4-15 23:04:56 | 显示全部楼层
感謝無私分享
发表于 2013-4-20 09:38:10 | 显示全部楼层
回复 2# mousezhong
按照你的破解方法 我不能用 在Linux(redhat)系统下 总是启动不了license
发表于 2013-4-22 09:34:50 | 显示全部楼层
回复 13# goalyoung
上传一个log吧。
发表于 2013-4-22 10:49:45 | 显示全部楼层
回复 14# mousezhong
启动synplify后产生的log如下:
Starting:    /home/lishaoxin/synplify2012/synplify/linux_a_64/mbin/synplify
Install:     /home/lishaoxin/synplify2012/synplify
Date:        Mon Apr 22 10:50:13 2013
Version:     F-2012.03
Arguments:   -product synplify
ProductType: synplify
License for feature synplify is not available.
Node-locked Host ID:  848f69e33e46
Please contact support at https://solvnet.synopsys.com/ManageCase?ccf=1
显示:License for feature synplify is not available.  这个license根本没用啊,这种方法破解不行啊
发表于 2013-4-22 10:55:28 | 显示全部楼层
回复 14# mousezhong
启动license出现的部分信息:
10:49:46 (lmgrd) FLEXnet Licensing (v11.9.1.0 build 89952 i86_lsb) started on localhost.localdomain (linux) (4/22/2013)
10:49:46 (lmgrd) Copyright (c) 1988-2010 Flexera Software, Inc. All Rights Reserved.
10:49:46 (lmgrd) US Patents 5,390,297 and 5,671,412.
10:49:46 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
10:49:46 (lmgrd) License file(s): /home/lishaoxin/synplify2012/synplify/license/synopsys.dat
10:49:46 (lmgrd) lmgrd tcp-port 27000
10:49:46 (lmgrd) Starting vendor daemons ...
10:49:46 (lmgrd) Started snpslmd (internet tcp_port 54882 pid 8016)
10:49:46 (snpslmd) FLEXnet Licensing version v11.9.1.1 build 93024 i86_lsb
10:49:46 (snpslmd) Feature synplify superseded by synplify
04/22/2013 10:49:46 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_11.3
10:50:01 (snpslmd) Feature synplify superseded by synplify
10:50:01 (snpslmd) Using options file: "/home/lishaoxin/syplify2012/scl_v11.3/linux/bin/snpslmd"
10:50:01 (snpslmd) Server started on localhost.localdomain for: SSS
10:50:01 (snpslmd) synplify synplifypro synplifyasic
10:50:01 (snpslmd) synplifypremier synplifypremierdp synplifydspsl
10:50:01 (snpslmd) synplifydspoption amplify  amplifyissp
10:50:01 (snpslmd) amplifyasic amplifyrapidchip certify
10:50:01 (snpslmd) certifysc identify_tps identifyinstrumentor
10:50:01 (snpslmd) identifyinstrumentor_actel identifyinstrumentor_altera identifyinstrumentor_xilinx
10:50:01 (snpslmd) identifyinstrumentor_encrypt identifydebugger identifydebugger_actel
10:50:01 (snpslmd) identifydebugger_altera identifydebugger_xilinx identifydebugger_encrypt
10:50:01 (snpslmd) identproinstrumentor identproinstrumentor_actel identproinstrumentor_altera
10:50:01 (snpslmd) identproinstrumentor_encrypt indentproinstrumentor_xilinx identprodebugger
10:50:01 (snpslmd) indentprodebugger_actel indentprodebugger_altera indentprodebugger_encrypt
10:50:01 (snpslmd) identprodebugger_xilinxA3200DX
10:50:01 (snpslmd)
10:50:01 (snpslmd) Licenses are case sensitive for TE_CATS
10:50:01 (snpslmd)
10:50:01 (snpslmd) EXTERNAL FILTERS are OFF
10:50:01 (snpslmd) CANNOT OPEN options file "/home/lishaoxin/syplify2012/scl_v11.3/linux/bin/snpslmd"
10:50:01 (lmgrd) snpslmd using TCP-port 54882
10:50:01 (snpslmd) Serving features for the following vendor names:
snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  arcd  archprod  avantd  chrysalisd  cowared  everest  hscd  innologd  la_dmon  leda  metasoftd  mwflexd  nassd  numeritchd  pdld  saber_dmn  sandwork  sigmacd  slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  snpsOEM5  snpsOEM6  snpsOEM7  snpsOEM8  snpsOEM9  ssilmd  synforad  synopsysd  synplctyd  tmald  vastlmd  vcsd
04/22/2013 10:50:01 (snpslmd) ------------------------------------------------------------------
04/22/2013 10:50:01 (snpslmd) Checking the integrity of the license file....
04/22/2013 10:50:01 (snpslmd) Valid SSS feature found.
04/22/2013 10:50:01 (snpslmd) The feature is needed to enable the other keys in your license file.
04/22/2013 10:50:01 (snpslmd) Licensed to mammoth//ZWT 2006
04/22/2013 10:50:01 (snpslmd) Siteid: 19688, Server Hostid: 848f69e33e46, Issued on: 12/28/2012
10:50:01 (lmgrd) snpslmd exited with status 0 signal = 17
10:50:01 (lmgrd) Since this is an unknown status, license server
10:50:01 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:50:01 (lmgrd) REStarted snpslmd (internet tcp_port 43156 pid 8025)
10:50:01 (snpslmd) FLEXnet Licensing version v11.9.1.1 build 93024 i86_lsb
04/22/2013 10:50:01 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_11.3
10:50:16 (snpslmd) Feature synplify superseded by synplify
10:50:16 (snpslmd) Using options file: "/home/lishaoxin/syplify2012/scl_v11.3/linux/bin/snpslmd"
10:50:16 (snpslmd) Server started on localhost.localdomain for: SSS
10:50:16 (snpslmd) synplify synplifypro synplifyasic
10:50:16 (snpslmd) synplifypremier synplifypremierdp synplifydspsl
10:50:16 (snpslmd) synplifydspoption amplify  amplifyissp
10:50:16 (snpslmd) amplifyasic amplifyrapidchip certify
10:50:16 (snpslmd) certifysc identify_tps identifyinstrumentor
10:50:16 (snpslmd) identifyinstrumentor_actel identifyinstrumentor_altera identifyinstrumentor_xilinx
10:50:16 (snpslmd) identifyinstrumentor_encrypt identifydebugger identifydebugger_actel
10:50:16 (snpslmd) identifydebugger_altera identifydebugger_xilinx identifydebugger_encrypt
10:50:16 (snpslmd) identproinstrumentor identproinstrumentor_actel identproinstrumentor_altera
10:50:16 (snpslmd) identproinstrumentor_encrypt indentproinstrumentor_xilinx identprodebugger
10:50:16 (snpslmd) indentprodebugger_actel indentprodebugger_altera indentprodebugger_encrypt
10:50:16 (snpslmd) identprodebugger_xilinxA3200DX
10:50:16 (snpslmd)
10:50:16 (snpslmd) Licenses are case sensitive for TE_CATS
10:50:16 (snpslmd)
10:50:16 (snpslmd) EXTERNAL FILTERS are OFF
10:50:16 (snpslmd) CANNOT OPEN options file "/home/lishaoxin/syplify2012/scl_v11.3/linux/bin/snpslmd"
10:50:16 (lmgrd) snpslmd using TCP-port 43156
10:50:16 (snpslmd) Serving features for the following vendor names:
04/22/2013 10:50:16 (snpslmd) ------------------------------------------------------------------
04/22/2013 10:50:16 (snpslmd) Checking the integrity of the license file....
04/22/2013 10:50:16 (snpslmd) Valid SSS feature found.
04/22/2013 10:50:16 (snpslmd) The feature is needed to enable the other keys in your license file.
04/22/2013 10:50:16 (snpslmd) Licensed to mammoth//ZWT 2006
04/22/2013 10:50:16 (snpslmd) Siteid: 19688, Server Hostid: 848f69e33e46, Issued on: 12/28/2012
10:50:16 (lmgrd) snpslmd exited with status 0 signal = 17
10:50:16 (lmgrd) Since this is an unknown status, license server
10:50:16 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:50:16 (lmgrd) REStarted snpslmd (internet tcp_port 49159 pid 8107)
10:50:16 (snpslmd) FLEXnet Licensing version v11.9.1.1 build 93024 i86_lsb
04/22/2013 10:50:16 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_11.3
10:50:31 (snpslmd) Feature synplify superseded by synplify
10:50:31 (snpslmd) Using options file: "/home/lishaoxin/syplify2012/scl_v11.3/linux/bin/snpslmd"
10:50:31 (snpslmd) Server started on localhost.localdomain for: SSS
10:50:31 (snpslmd) synplify synplifypro synplifyasic
10:50:31 (snpslmd) synplifypremier synplifypremierdp synplifydspsl
10:50:31 (snpslmd) synplifydspoption amplify  amplifyissp
10:50:31 (snpslmd) amplifyasic amplifyrapidchip certify
10:50:31 (snpslmd) certifysc identify_tps identifyinstrumentor
10:50:31 (snpslmd) identifyinstrumentor_actel identifyinstrumentor_altera identifyinstrumentor_xilinx
10:50:31 (snpslmd) identifyinstrumentor_encrypt identifydebugger identifydebugger_actel
10:50:31 (snpslmd) identifydebugger_altera identifydebugger_xilinx identifydebugger_encrypt
10:50:31 (snpslmd) identproinstrumentor identproinstrumentor_actel identproinstrumentor_altera
10:50:31 (snpslmd) identproinstrumentor_encrypt indentproinstrumentor_xilinx identprodebugger
10:50:31 (snpslmd) indentprodebugger_actel indentprodebugger_altera indentprodebugger_encrypt
10:50:31 (snpslmd) identprodebugger_xilinxA3200DX
10:50:31 (snpslmd)
10:50:31 (snpslmd) Licenses are case sensitive for TE_CATS
10:50:31 (snpslmd)
10:50:31 (snpslmd) EXTERNAL FILTERS are OFF
10:50:31 (snpslmd) CANNOT OPEN options file "/home/lishaoxin/syplify2012/scl_v11.3/linux/bin/snpslmd"
10:50:31 (lmgrd) snpslmd using TCP-port 49159
10:50:31 (snpslmd) Serving features for the following vendor names:
04/22/2013 10:50:31 (snpslmd) ------------------------------------------------------------------
04/22/2013 10:50:31 (snpslmd) Checking the integrity of the license file....
04/22/2013 10:50:31 (snpslmd) Valid SSS feature found.
04/22/2013 10:50:31 (snpslmd) The feature is needed to enable the other keys in your license file.
04/22/2013 10:50:31 (snpslmd) Licensed to mammoth//ZWT 2006
04/22/2013 10:50:31 (snpslmd) Siteid: 19688, Server Hostid: 848f69e33e46, Issued on: 12/28/2012
不知道是什么原因,请大侠指点一二,谢谢!
发表于 2013-4-22 12:59:19 | 显示全部楼层
回复 16# goalyoung
~~ 路径对吗???
我的lic 前几行:
SERVER asicserver16 00219b3c62ec 27000
DAEMON snpslmd /home/hz08374/usr/synopsys/11.3/linux/bin/snpslmd
USE_SERVER
我的log文件
04/18/2013 13:03:01 (snpslmd) ------------------------------------------------------------------
04/18/2013 13:03:01 (snpslmd) Checking the integrity of the license file....
04/18/2013 13:03:01 (snpslmd) Valid SSS feature found.
04/18/2013 13:03:01 (snpslmd) The feature is needed to enable the other keys in your license file.
04/18/2013 13:03:01 (snpslmd) Licensed to mammoth//ZWT 2006
04/18/2013 13:03:01 (snpslmd) Siteid: <No Site Id>, Server Hostid: 00219b3c62ec, Issued on: N/A
我的synplify_pro:
14:06:22 (snpslmd) OUT: "synplifypro" hz08374@asicserver16
14:06:39 (snpslmd) IN: "synplifypro" hz08374@asicserver16
发表于 2013-4-22 14:24:28 | 显示全部楼层
回复 17# mousezhong
路径没问题,有问题的话,会提示路径不对,或找不到license文件
发表于 2013-4-23 09:45:10 | 显示全部楼层
synplify_lic.rar (5.92 KB , 下载次数: 48 )
回复 18# goalyoung
按照你的信息,帮你generate了一个license, feature只有synplify_pro的,你试试吧。
发表于 2013-7-19 18:21:42 | 显示全部楼层
我的似乎还不行啊,而且这行feature只能用于snplify_pro版本的。
我的也是这种情况!
GMT+8, 2025-11-3 05:03 , Processed in 0.531858 second(s), 4 queries , Gzip On, Redis On.
