楼主: alexbaby
[2013-02-03][软件][CADENCE][iScape 04.21-p004 x86_64]
发表于 2014-4-9 02:34:43 | 显示全部楼层
是64位的吗??????
发表于 2014-4-17 13:59:01 | 显示全部楼层
证在下载中。谢谢。试试
发表于 2014-4-30 22:31:09 | 显示全部楼层
good good
发表于 2014-5-12 03:51:11 | 显示全部楼层
有人可以证实,如果这实际上是64?
发表于 2014-5-20 05:29:43 | 显示全部楼层
非常感谢
发表于 2014-5-20 05:30:49 | 显示全部楼层
我需要它
发表于 2014-6-4 22:55:08 | 显示全部楼层
谢谢分享
发表于 2014-6-7 22:18:15 | 显示全部楼层
回复 61# homeboy1
    您好!我也是用ubuntu 64安装iscape,但有错误提示;
Initializing InstallScape using JVM at /eda/Cadence/iscape/iscape.04.21-p004/runtime/LNX86/bin/java. This might take some time...
Exception in thread "main" java.lang.UnsatisfiedLinkError: /eda/Cadence/iscape/iscape.04.21-p004/runtime/LNX86/lib/i386/xawt/libmawt.so: libXtst.so.6: cannot open shared object file: No such file or directory
    at java.lang.ClassLoader$NativeLibrary.load(Native Method)
    at java.lang.ClassLoader.loadLibrary0(Unknown Source)
    at java.lang.ClassLoader.loadLibrary(Unknown Source)
    at java.lang.Runtime.load0(Unknown Source)
    at java.lang.System.load(Unknown Source)
    at java.lang.Runtime.loadLibrary0(Unknown Source)
    at java.lang.System.loadLibrary(Unknown Source)
    at sun.security.action.LoadLibraryAction.run(Unknown Source)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.awt.Toolkit.loadLibraries(Unknown Source)
    at java.awt.Toolkit.<clinit>(Unknown Source)
    at com.khanpur.installer.gui.InstallerUI.main(InstallerUI.java:107)
不知您遇到没有,怎样解决呢??谢谢!
发表于 2014-6-9 15:21:41 | 显示全部楼层
回复 70# chanon
sudo apt-get install ksh build-essential openjdk-7-jre vim aptitude csh ssh lsb-core libstdc++6 xfonts-100dpi xfonts-75dpi xfonts-100dpi-transcoded xfonts-75dpi-transcoded ttf-freefont
If installscape does not work showing a java error message, you need to link the java, java_vm y javaws binaries in
/etc/alternatives maintaining the same names. You can also update the java references by executing:
sudo update-alternatives --config java
sudo update-alternatives --config javac
sudo update-alternatives --config javws
iscape.sh: 219: exec: /home/administrador/cadence_install_files/iscape.04.21-s003/runtime/LNX86/bin/java: not found
If you get the above error, you need to edit iscape.sh and change
if [ "X$java_vm" = "X" ]; then
java_vm=`FindJavaInPath`;
fi;
with
fi;
java_vm=Path_to_your_java_bin_folder // in this case, /usr/lib/jvm/java-7-openjdk-amd64/bin/java
发表于 2014-6-9 21:05:11 | 显示全部楼层
thanks!!!
GMT+8, 2025-12-15 20:42 , Processed in 0.019567 second(s), 3 queries , Gzip On, Redis On.
