在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2954|回复: 4
[转贴] 程序员的进化——从学生到首席执行官
发表于 2013-1-25 16:38:05 | 显示全部楼层 |阅读模式
    程序员的进化——从学生到首席执行官
翻译 2002 王咏刚 http://www.contextfree.net/
转译自 Omri's Computer Humor Page
http://www.cs.bgu.ac.il/~omri/Humor/
中学阶段
          10 PRINT "HELLO WORLD"
          20 END
大学一年级
          program Hello(input, output)
            begin
              writeln('Hello World')
            end.
大学高年级
          (defun hello
            (print
              (cons 'Hello (list 'World))))
初级程序员
          #include <stdio.h>;
          void main(void)
            char *message[] = {"Hello ", "World"};
            int i;
            for(i = 0; i < 2; ++i)
              printf("%s", message[i]);
            printf("\n");
编程老鸟
          #include <iostream.h>;
          #include <string.h>;
          class string
          private:
            int size;
            char *ptr;
          public:
            string() : size(0), ptr(new char('\0')) {}
            string(const string &s) : size(s.size)
              ptr = new char[size + 1];
              strcpy(ptr, s.ptr);
            ~string()
              delete [] ptr;
            friend ostream &operator <<(ostream &, const string &);
            string &operator=(const char *);
          ostream &operator<<(ostream &stream, const string &s)
            return(stream << s.ptr);
          string &string:perator=(const char *chrs)
            if (this != &chrs)
              delete [] ptr;
             size = strlen(chrs);
              strcpy(ptr, chrs);
            return(*this);
          int main()
            string str;
            str = "Hello World";
            cout << str << end
            return(0);
编程高手
          uuid(2573F8F4-CFEE-101A-9A9F-00AA00342820)
          library LHello
              // bring in the master library
              importlib("actimp.tlb");
              importlib("actexp.tlb");
              // bring in my interfaces
              #include "pshlo.idl"
              uuid(2573F8F5-CFEE-101A-9A9F-00AA00342820)
              cotype THello
           interface IHello;
           interface IPersistFile;
          exe,
          uuid(2573F890-CFEE-101A-9A9F-00AA00342820)
          module CHelloLib
              // some code related header files
              importheader(<windows.h>;);
              importheader(<ole2.h>;);
              importheader(<except.hxx>;);
              importheader("pshlo.h");
              importheader("shlo.hxx");
              importheader("mycls.hxx");
              // needed typelibs
              importlib("thlo.tlb");
              uuid(2573F891-CFEE-101A-9A9F-00AA00342820),
              aggregatable
              coclass CHello
           cotype THello;
          #include "ipfix.hxx"
          extern HANDLE hEvent;
          class CHello : public CHelloBase
          public:
              IPFIX(CLSID_CHello);
              CHello(IUnknown *pUnk);
              ~CHello();
              HRESULT  __stdcall PrintSz(LPWSTR pwszString);
          private:
              static int cObjRef;
          #include <windows.h>;
          #include <ole2.h>;
          #include <stdio.h>;
          #include <stdlib.h>;
          #include "thlo.h"
          #include "pshlo.h"
          #include "shlo.hxx"
          #include "mycls.hxx"
          int CHello::cObjRef = 0;
          CHello::CHello(IUnknown *pUnk) : CHelloBase(pUnk)
              cObjRef++;
              return;
          HRESULT  __stdcall  CHello:rintSz(LPWSTR pwszString)
              printf("%ws\n", pwszString);
              return(ResultFromScode(S_OK));
          CHello::~CHello(void)
          // when the object count goes to zero, stop the server
          cObjRef--;
          if( cObjRef == 0 )
              PulseEvent(hEvent);
          return;
          #include <ole2.h>;
          #include "pshlo.h"
          #include "shlo.hxx"
          HANDLE hEvent;
           int _cdecl main(
          int argc,
          char * argv[]
          ULONG ulRef;
          DWORD dwRegistration;
          CHelloCF *pCF = new CHelloCF();
          hEvent = CreateEvent(NULL, FALSE, FALSE, NULL);
          // Initialize the OLE libraries
          CoInitializeEx(NULL, COINIT_MULTITHREADED);
          CoRegisterClassObject(CLSID_CHello, pCF, CLSCTX_LOCAL_SERVER,
              REGCLS_MULTIPLEUSE, &dwRegistration);
          // wait on an event to stop
          WaitForSingleObject(hEvent, INFINITE);
          // revoke and release the class object
          CoRevokeClassObject(dwRegistration);
          ulRef = pCF->;Release();
          // Tell OLE we are going away.
          CoUninitialize();
          return(0);
          extern CLSID CLSID_CHello;
          extern UUID LIBID_CHelloLib;
          CLSID CLSID_CHello = { /* 2573F891-CFEE-101A-9A9F-00AA00342820 */
              0x2573F891,
              0xCFEE,
              0x101A,
              { 0x9A, 0x9F, 0x00, 0xAA, 0x00, 0x34, 0x28, 0x20 }
          UUID LIBID_CHelloLib = { /* 2573F890-CFEE-101A-9A9F-00AA00342820 */
              0x2573F890,
              0xCFEE,
              0x101A,
          #include <ole2.h>;
          #include <stdio.h>;
          #include "pshlo.h"
          #include "shlo.hxx"
          #include "clsid.h"
          int _cdecl main(
          int argc,
          char * argv[]
          HRESULT  hRslt;
          IHello        *pHello;
          ULONG  ulCnt;
          IMoniker * pmk;
          WCHAR  wcsT[_MAX_PATH];
          WCHAR  wcsPath[2 * _MAX_PATH];
          // get object path
          wcsPath[0] = '\0';
          wcsT[0] = '\0';
          if( argc >; 1) {
              mbstowcs(wcsPath, argv[1], strlen(argv[1]) + 1);
              wcsupr(wcsPath);
          else {
              fprintf(stderr, "Object path must be specified\n");
              return(1);
          // get print string
          if(argc >; 2)
              mbstowcs(wcsT, argv[2], strlen(argv[2]) + 1);
          else
              wcscpy(wcsT, L"Hello World");
          printf("Linking to object %ws\n", wcsPath);
          printf("Text String %ws\n", wcsT);
          hRslt = CoInitializeEx(NULL, COINIT_MULTITHREADED);
          if(SUCCEEDED(hRslt)) {
              hRslt = CreateFileMoniker(wcsPath, &pmk);
           hRslt = BindMoniker(pmk, 0, IID_IHello, (void **)&pHello);
           // print a string out
           pHello->rintSz(wcsT);
           Sleep(2000);
           ulCnt = pHello->;Release();
              else
           printf("Failure to connect, status: %lx", hRslt);
              CoUninitialize();
          return(0);
黑客初阶
          #!/usr/local/bin/perl
          $msg="Hello, world.\n";
          if ($#ARGV >;= 0) {
            while(defined($arg=shift(@ARGV))) {
              $outfilename = $arg;
              open(FILE, ">;" . $outfilename) || die "Can't write $arg: $!\n";
              print (FILE $msg);
              close(FILE) || die "Can't close $arg: $!\n";
          } else {
            print ($msg);
          1;
黑客有成
          #include <stdio.h>;
          #define S "Hello, World\n"
          main(){exit(printf(S) == strlen(S) ? 0 : 1);}
黑客高手
          % cc -o a.out ~/src/misc/hw/hw.c
          % a.out
黑客大虾
          % cat
          Hello, world.
          ^D
初级经理
          20 END
中级经理
          mail -s "Hello, world." bob@b12
          Bob, could you please write me a program that prints "Hello, world."?
          I need it by tomorrow.
          ^D
高级经理
          % zmail jim
          I need a "Hello, world." program by this afternoon.
首席执行官
          % letter
          letter: Command not found.
          % mail
          To: ^X ^F ^C
          % help mail
          help: Command not found.
          % damn!
          !: Event unrecognized
          % logout
发表于 2013-1-25 23:55:16 | 显示全部楼层
这个很形象啊
发表于 2013-1-26 17:36:44 | 显示全部楼层
Well! It evolves. Does any one know what languages they are using in each stage?
发表于 2013-1-27 18:51:37 | 显示全部楼层
这个经典
发表于 2013-1-28 08:54:52 | 显示全部楼层
笑死我了
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-16 15:55 , Processed in 0.025503 second(s), 9 queries , Gzip On, Redis On.
