在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 22576|回复: 140
[资料] 华为内部的tcl教程
发表于 2013-1-24 00:02:46 | 显示全部楼层 |阅读模式
2  语法............................................................................................................................... .............................. 7
2.1  脚本、命令和单词符号............................................................................................................... 7
2.2  置换 (substitution) ......................................................................................................................... 7
2.2.1  变量置换(variable subtitution) ............................................................................................. 8
2.2.2  命令置换(command substitution) ......................................................................................... 8
2.2.3  反斜杠置换(backslash substitution) ..................................................................................... 9
2.2.4  双引号和花括号 ................................................................................................................. 10
2.3  注释 ............................................................................................................................... ............. 10
3  变量............................................................................................................................... ............................ 10
3.1  简单变量............................................................................................................................... ..... 10
3.2  数组 ............................................................................................................................... ............. 11
3.3  相关命令............................................................................................................................... ..... 12
3.3.1   set............................................................................................................................... ......... 12
3.3.2  unset............................................................................................................................... ..... 12
3.3.3  append 和incr ....................................................................................................................... 12
4  表达式............................................................................................................................... ........................ 13
4.1  操作数............................................................................................................................... ......... 13
4.2  运算符和优先级 ......................................................................................................................... 13
1.1  数学函数............................................................................................................................... ..... 14
2  List............................................................................................................................... ............................ 15
2.1  list命令 ............................................................................................................................... ......... 15
2.2  concat 命令: ............................................................................................................................... .. 16
2.3  lindex 命令 ............................................................................................................................... ... 16
2.4  llength 命令 ............................................................................................................................... .. 16
2.5  linsert 命令 ............................................................................................................................... ... 16
2.6  lreplace命令:...............................................................................................................................16
2.8  lappend命令 :...............................................................................................................................17
2.9  lsearch 命令: ...............................................................................................................................17
2.10  lsort 命令 : .................................................................................................................................... 17
2.11  split 命令: .................................................................................................................................... 18
2.12  join 命令 ............................................................................................................................... ....... 18
控制流............................................................................................................................... ........................ 18
3.1  if 命令 ............................................................................................................................... ........... 18
3.2  循环命令: while 、for、 foreach ............................................................................................. 19
3.2.1  while命令 ............................................................................................................................ 19
3.2.2  for命令 ............................................................................................................................... .19
3.2.3  foreach 命令 ......................................................................................................................... 20
3.2.4  break和continue命令.......................................................................................................... 20
3.2.5  switch  命令 ......................................................................................................................... 21
3.3  eval 命令 ............................................................................................................................... ....... 21
3.4  source 命令 ............................................................................................................................... ... 21
过程(procedure).................................................................................................................... ..................... 21
4.1  过程定义和返回值 ..................................................................................................................... 22
4.2  局部变量和全局变量................................................................................................................. 22
4.3  缺省参数和可变个数参数......................................................................................................... 23
4.4  引用: upvar ............................................................................................................................... 24
字符串操作............................................................................................................................... ............... 25
5.1  format 命令............................................................................................................................... ... 25
5.2  scan 命令 ............................................................................................................................... ...... 25
5.3  regexp 命令 ............................................................................................................................... ... 26
1.1  regsub 命令............................................................................................................................... ... 28
1.2  string命令 ............................................................................................................................... .... 28
1.2.1  string  compare  ? -nocase?  ?-length int? string1 string2................................................... 28
1.2.2  string   equal  ? -nocase?  ?-length    int?  string1  string2 ..................................................... 28
1.2.3  string    first  string1   string2  ? startindex ? ............................................................................ 29
1.2.4  string    index  string  charIndex........................................................................................... 29
1.2.5  string     last    string1 string2   ?startindex? ....................... ....................... .......................... 29
1.2.6  string     length      string....................................................................................................... 29
1.2.7  string  match ? -nocase?  pattern  string ............................................................................... 29
1.2.8  string     range    string  first     last ........................................................................................ 30
1.2.9  string     repeat    string    count ............................................................................................. 30
1.2.10  string     replace      string    first     last  ? newstring ?............................................................. 30
1.2.11  string     tolower    string  ? first ?   ? last ? .............................................................................. 30
1.2.12  string     toupper    string   ?first ?    ? last ?............................................................................. 30
1.2.13  string     trim      string   ?chars? ........................................................................................... 30
1.2.14  string   trimleft    string ? chars?........................................................................................... 31
1.2.15  string     trimright     string   ?chars? ................................................................................... 31
2  文件访问............................................................................................................................... ................... 31
2.1  文件名............................................................................................................................... ......... 31
2.2  基本文件输入输出命令............................................................................................................. 31
2.3  随机文件访问............................................................................................................................. 33
2.4  当前工作目录............................................................................................................................. 33
2.5  文件操作和获取文件信息......................................................................................................... 34
3  错误和异常............................................................................................................................... ............... 38
3.1  错误 ............................................................................................................................... ............. 38
3.2  从TCL 脚本中产生错误............................................................................................................. 40
3.3  使用 catch捕获错误.................................................................................................................... 40
3.4  其他异常............................................................................................................................... ..... 41
1  深入TCL............................................................................................................................... ..................... 43
1.1  查询数组中的元素 ..................................................................................................................... 43
1.2  info 命令............................................................................................................................... ....... 45
1.2.1  变量信息............................................................................................................................. 45
1.1.1  过程信息............................................................................................................................. 46
1.1.2  命令信息............................................................................................................................. 47
1.1.3  TCL 的版本和库................................................................................................................. 48
1.1.4  命令的执行时间 ................................................................................................................. 48
1.1.5  跟踪变量............................................................................................................................. 48
1.1.6  命令的重命名和删除 ......................................................................................................... 51
1.1.7  unknown 命令 ...................................................................................................................... 52
1.1.8  自动加载............................................................................................................................. 53
TCL培训教程(华为内部资料).pdf
409.25 KB, 下载次数: 1852 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2013-1-24 08:52:29 | 显示全部楼层
好东西,谢谢分享。
发表于 2013-1-24 10:28:13 | 显示全部楼层
好用的資料, 感謝~~推.....
发表于 2013-1-25 09:21:01 | 显示全部楼层
华为内部的tcl教程
发表于 2013-4-16 22:39:06 | 显示全部楼层
我去,这也可以搞到  牛逼!
发表于 2013-4-20 19:43:22 | 显示全部楼层
谢谢分享~
发表于 2013-8-20 11:35:04 | 显示全部楼层
刚好在学这个
发表于 2013-8-22 15:40:58 | 显示全部楼层
回复 1# lgxian
内部资料,好东西
发表于 2013-9-25 16:23:48 | 显示全部楼层
谢谢分享
发表于 2013-9-25 18:15:47 | 显示全部楼层
赞~~~~学习了
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-19 18:21 , Processed in 0.052759 second(s), 9 queries , Gzip On, Redis On.
