在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: snk88
cadence x64_patch
 楼主| 发表于 2013-2-18 13:24:04 | 显示全部楼层
回复 29# jack313
   需要什么feature可以自己添加
发表于 2013-2-18 15:49:41 | 显示全部楼层
破10.13的没问题,刚试完
发表于 2013-2-18 23:25:17 | 显示全部楼层
thanks!
发表于 2013-2-19 14:20:43 | 显示全部楼层
回复 1# snk88
Dear LZ,
Do you run for ams_aps co-sim flow?
There is a case on "../../INCISIV12.20.003/tools.lnx86/amsd/samples/aium/ams_aps".
After using you provided patch script, the formal license "Virtuoso_Multi_mode_Simulation" still needed.
Could you help to check which programs are not cracked yet?
Thanks,
 楼主| 发表于 2013-2-19 20:12:37 | 显示全部楼层
回复 34# wilson168
   FEATURE Virtuoso_Multi_mode_Simulation cdslmd 1000.000 permanent \
uncounted EDA49D4CFD7FC33CCAF7 VENDOR_STRING=Team_EFA_2006 \
HOSTID=ANY ck=155 SIGN2="0903 43E5 A364 445B FD8F 0DC3 8200 \
A4FC 1304 208F D107 6537 6CF3 B4F9 CCC0 00DF 2015 75E8 FDB6 \
C557 FA11 6DBC B5B2 2C7F 4E3A 73B7 9872 91DB 49BF 1FE8"
发表于 2013-2-19 22:55:12 | 显示全部楼层
好东西 收下了
发表于 2013-2-20 05:07:38 | 显示全部楼层
eetop good
发表于 2013-2-20 08:48:13 | 显示全部楼层
Amazing share! Thanks a lot for this great file.
发表于 2013-2-20 09:45:42 | 显示全部楼层
回复 35# snk88
It seems don't work by using you provided license @#35.The detailed message is shown below:
"Fatal error found by spectre.
    FATAL (SPECTRE-209): No license available to run Virtuoso(R) Spectre.
        Please check your license server or use the license queuing
        feature(e.g. spectre +lqt 0)."
Could you post cadence licgen , which has SIGN2 key, to this subject?
(due to my owned licgen that can't generate SIGN2 key)
I will re-generate license and try it again.
Thank you very much.
 楼主| 发表于 2013-2-20 11:26:36 | 显示全部楼层
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-18 08:10 , Processed in 0.029938 second(s), 6 queries , Gzip On, Redis On.
