楼主: jiawei2426
64位centos6.2安装encounter缺少libXm.so.3,谁有资源求提供。谢谢
 楼主| 发表于 2012-12-28 10:31:52 | 显示全部楼层
Checking out Encounter license ...
SOC_Encounter_GXL 8.1 license checkout succeeded.
This Encounter release has been compiled with OA version 22.04-p032.
sourcing /home/cad/layout/encounter/encounter/etc/fe/rdaDSL.tcl
@(#)CDS: First Encounter v08.10-p004_1 (32bit) 11/04/2008 14:34 (Linux 2.6)
@(#)CDS: NanoRoute v08.10-p008 NR081027-0018/USR58-UB (database version 2.30, 67.1.1) {superthreading v1.11}
@(#)CDS: CeltIC v08.10-p002_1 (32bit) 10/23/2008 22:04:14 (Linux 2.6.9-67.0.10.ELsmp)
@(#)CDS: CTE v08.10-p016_1 (32bit) Oct 26 2008 15:11:51 (Linux 2.6.9-67.0.10.ELsmp)
@(#)CDS: CPE v08.10-p009
--- Starting "First Encounter v08.10-p004_1" on Fri Dec 28 05:25:35 2012 (mem=62.2M) ---
--- Running on localhost (x86_64 w/Linux 2.6.32-220.el6.x86_64) ---
This version was compiled on Tue Nov 4 14:34:21 PST 2008.
Set DBUPerIGU to 1000.
Set Default Mode Total Cap Scale Factor to 1.00
Set Detail Mode Total Cap Scale Factor to 1.00
Set Coupling Total Cap Scale Factor to 1.00
Set Total Res Scale Factor to 1.00
Set net toggle Scale Factor to 1.00
Set Shrink Factor to 1.00000
<CMD_INTERNAL> uiSetTool ruler
Encounter terminated by internal (SEGV) error/signal...
*** Stack trace:
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(syStackTrace+0x146)[0xd1c3d2f]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter[0x8bc653e]
[0xf77cc410]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(_Z14winTextExtentsP7winsWinP9winsLayerPcPiS4_S4_+0x75)[0xc571c0d]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(_Z12winDrawRulerP7winsWinP9winsRulerP9winsLayeri+0x408)[0xc5b23c0]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(_Z21winEventDrawEditRulerP7winsWinP14winsEventQueue+0x47)[0xc5b2af5]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(_Z15winEventDrawRubP7winsWin+0x50)[0xc5abba4]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(_Z10winDisplayP7winsWin+0x1c2)[0xc57091c]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter[0xc57323a]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(TclServiceIdle+0x59)[0xe0e74f9]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(Tcl_DoOneEvent+0x16e)[0xe0d7e8e]
/home/cad/layout/encounter/encounter/tools/lib/libtq.so(_ZN17TqEventDispatcher13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE+0xb6)[0xf635207a]
/home/cad/layout/encounter/encounter/tools/Qt/32bit/lib/libQtCore.so.4(_ZN10QEventLoop13processEventsE6QFlagsINS_17ProcessEventsFlagEE+0x31)[0xf672d981]
/home/cad/layout/encounter/encounter/tools/Qt/32bit/lib/libQtCore.so.4(_ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE+0x7a)[0xf672da8a]
/home/cad/layout/encounter/encounter/tools/Qt/32bit/lib/libQtCore.so.4(_ZN16QCoreApplication4execEv+0xa6)[0xf6730016]
/home/cad/layout/encounter/encounter/tools/Qt/32bit/lib/libQtGui.so.4(_ZN12QApplication4execEv+0x27)[0xf694b587]
/home/cad/layout/encounter/encounter/tools/lib/libtq.so(_ZN13TqApplication4execEv+0x320)[0xf6354568]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(_Z7fe_mainiPPc+0x33c)[0x8ba95f0]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(main+0x79)[0x8ba96b7]
/lib/libc.so.6(__libc_start_main+0xe6)[0x8b1ce6]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(_ZN7QDialog13keyPressEventEP9QKeyEvent+0x2b5)[0x8ba8cc1]
               pstack
Thread 4 (Thread 0xf4a06b70 (LWP 5699)):
#0  0xf77cc430 in __kernel_vsyscall ()
#1  0xf7799c26 in nanosleep () from /lib/libpthread.so.0
#2  0x093790de in rdaiLicRecheck(void*) ()
#3  0xf7792a09 in start_thread () from /lib/libpthread.so.0
#4  0x0097800e in clone () from /lib/libc.so.6
Thread 3 (Thread 0xf4005b70 (LWP 5700)):
#1  0x009704f1 in select () from /lib/libc.so.6
#2  0x0e0fa66c in NotifierThreadProc ()
Thread 2 (Thread 0xf3604b70 (LWP 5701)):
#1  0xf779a590 in sigwait () from /lib/libpthread.so.0
#2  0x08bc69b7 in ctrlCHandle(void*) ()
Thread 1 (Thread 0xf61fc700 (LWP 5652)):
#1  0x00937d3b in waitpid () from /lib/libc.so.6
#2  0x008d4293 in do_system () from /lib/libc.so.6
#3  0x008d4622 in system () from /lib/libc.so.6
#4  0xf779a7ad in system () from /lib/libpthread.so.0
#5  0x0d1c3d96 in syStackTrace ()
#6  0x08bc653e in rdaiErrorHandler(int, siginfo*, void*) ()
#7  <signal handler called>
#8  0x0058f751 in XTextExtents () from /usr/lib/libX11.so.6
#9  0x0c571c0d in winTextExtents(winsWin*, winsLayer*, char*, int*, int*, int*) ()
#10 0x0c5b23c0 in winDrawRuler(winsWin*, winsRuler*, winsLayer*, int) ()
#11 0x0c5b2af5 in winEventDrawEditRuler(winsWin*, winsEventQueue*) ()
#12 0x0c5abba4 in winEventDrawRub(winsWin*) ()
#13 0x0c57091c in winDisplay(winsWin*) ()
#14 0x0c57323a in winiTkDisplay(void*) ()
#15 0x0e0e74f9 in TclServiceIdle ()
#16 0x0e0d7e8e in Tcl_DoOneEvent ()
#17 0xf635207a in TqEventDispatcher::processEvents(QFlags<QEventLoop:rocessEventsFlag>) () from /home/cad/layout/encounter/encounter/tools/lib/libtq.so
#18 0xf672d981 in QEventLoop::processEvents(QFlags<QEventLoop:rocessEventsFlag>) () from /home/cad/layout/encounter/encounter/tools/Qt/32bit/lib/libQtCore.so.4
#19 0xf672da8a in QEventLoop::exec(QFlags<QEventLoop:rocessEventsFlag>) () from /home/cad/layout/encounter/encounter/tools/Qt/32bit/lib/libQtCore.so.4
#20 0xf6730016 in QCoreApplication::exec() () from /home/cad/layout/encounter/encounter/tools/Qt/32bit/lib/libQtCore.so.4
#21 0xf694b587 in QApplication::exec() () from /home/cad/layout/encounter/encounter/tools/Qt/32bit/lib/libQtGui.so.4
#22 0xf6354568 in TqApplication::exec() () from /home/cad/layout/encounter/encounter/tools/lib/libtq.so
#23 0x08ba95f0 in fe_main(int, char**) ()
#24 0x08ba96b7 in main ()
                gdb
Using: gdb
[Thread debugging using libthread_db enabled]
[New Thread 0xf3604b70 (LWP 5701)]
[New Thread 0xf4005b70 (LWP 5700)]
[New Thread 0xf4a06b70 (LWP 5699)]
#17 0xf635207a in TqEventDispatcher::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /home/cad/layout/encounter/encounter/tools/lib/libtq.so
#18 0xf672d981 in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /home/cad/layout/encounter/encounter/tools/Qt/32bit/lib/libQtCore.so.4
#19 0xf672da8a in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /home/cad/layout/encounter/encounter/tools/Qt/32bit/lib/libQtCore.so.4
A debugging session is active.
        Inferior 1 [process 5652] will be detached.
Quit anyway? (y or n) [answered Y; input not from terminal]
*** INTERRUPTED *** [signal 1]
5652: No such process
发表于 2013-4-14 09:52:27 | 显示全部楼层
我的9.1只能用32位,不知道为啥
发表于 2013-4-14 16:04:22 | 显示全部楼层
搞不懂,我所有的Encounter都试了,所有 -64 运行都报License错?
发表于 2014-1-17 15:44:12 | 显示全部楼层
幫頂一下
學習
发表于 2014-1-23 17:12:12 | 显示全部楼层
學習
感謝
发表于 2014-1-23 22:35:50 | 显示全部楼层
好东西~~
发表于 2014-7-16 11:35:10 | 显示全部楼层
问题解决了没有啊?怎么解决的,谢谢了
回复 11# jiawei2426
发表于 2014-8-25 11:22:16 | 显示全部楼层
通常大家都装的32位吗
发表于 2015-3-12 15:00:45 | 显示全部楼层
我也遇到这个问题,encounter: error while loading shared libraries: libXm.so.3: cannot open shared object file: No such file or directory
发表于 2015-3-12 15:01:26 | 显示全部楼层
如果不能联网yum,下载不到相应的rpm包,都是版本太新,不能支持。。。
GMT+8, 2025-12-30 05:36 , Processed in 0.021213 second(s), 3 queries , Gzip On, Redis On.
