在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 6601|回复: 2
[讨论] 请问一下F28335ADC模块的采样时间窗
发表于 2012-11-21 09:30:42 | 显示全部楼层 |阅读模式
在ADC模块reference guide中
ADC时钟由ADCCLKPS和CPS寄存器确定,但是后面有一个ACQ_PS寄存器是控制扩展采样保持器的脉冲?
请问这究竟是什么意思?采样时间窗究竟起什么作用?
In addition, the ADC can be
tailored to accommodate variations in source impedances by widening the sampling/acquisition period.
This is controlled by the ACQ_PS[3:0] bits in the ADCTRL1 register. These bits do not affect the
conversion portion of the S/H and conversion process, but do extend the length of time in which the
sampling portion takes by extending the start of the conversion pulse
 楼主| 发表于 2012-11-21 09:30:49 | 显示全部楼层
采样窗口的大小确定ADC模块中采样电容的充电时间。
 楼主| 发表于 2012-11-21 09:30:56 | 显示全部楼层
ADC的时钟周期由ADCCLKPS和CPS决定,而ACQ_PS寄存器决定采样窗口的时间是几个ADCCLK,采样窗的作用是对输入的模拟信号进行采样转换。
如外设时钟是150MHz,ADCCLKPS=(0011b),CPS=(0b),ACQ_PS=(0111b),则计算后ADCCLK=25MHz,采样窗口为8个(1/ADCLK).
GMT+8, 2024-3-29 07:26 , Processed in 0.023576 second(s), 9 queries , Gzip On, Redis On.
