在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1629|回复: 0
[资料] 对24C02的读&写
发表于 2012-11-1 21:39:25 | 显示全部楼层 |阅读模式
#include <reg51.h>
// 对24C02的读、写
// extern void DelayMs(unsigned int);
// extern void Read24c02(unsigned char *RamAddress,unsigned char RomAddress,unsigned char bytes);
// extern void Write24c02(unsigned char *RamAddress,unsigned char RomAddress,unsigned char bytes);
#define WriteDeviceAddress 0xa0
#define ReadDviceAddress 0xa1
sbit SCL=P1^4;
sbit SDA=P1^3;
sbit DOG=P3^7;
void DelayMs(unsigned int number) {
unsigned char temp;
for(;number!=0;number--,DOG=!DOG) {
for(temp=112;temp!=0;temp--) {
void Start() {
SDA=1;
SCL=1;
SDA=0;
SCL=0;
void Stop() {
SCL=0;
SDA=0;
SCL=1;
SDA=1;
void Ack() {
SDA=0;
SCL=1;
SCL=0;
SDA=1;
void NoAck() {
SDA=1;
SCL=1;
SCL=0;
bit TestAck() {
bit ErrorBit;
SDA=1;
SCL=1;
ErrorBit=SDA;
SCL=0;
return(ErrorBit);
bit Write8Bit(unsigned char input) {
unsigned char temp;
for(temp=8;temp!=0;temp--) {
SDA=(bit)(input&0x80);
SCL=1;
SCL=0;
input=input<<1;
void Write24c02(unsigned char *Wdata,unsigned char RomAddress,unsigned char number) {
Start();
Write8Bit(WriteDeviceAddress);
TestAck();
Write8Bit(RomAddress);
TestAck();
for(;number!=0;number--) {
Write8Bit(*Wdata);
TestAck();
Wdata++;
Stop();
DelayMs(10);
unsigned char Read8Bit() {
unsigned char temp,rbyte=0;
SCL=1;
rbyte=rbyte<<1;
rbyte=rbyte|((unsigned char)(SDA));
SCL=0;
return(rbyte);
void Read24c02(unsigned char *RamAddress,unsigned char RomAddress,unsigned char bytes) {
unsigned char temp,rbyte;
Start();
TestAck();
TestAck();
Start();
Write8Bit(ReadDviceAddress);
TestAck();
while(bytes!=1) {
*RamAddress=Read8Bit();
Ack();
RamAddress++;
bytes--;
NoAck();
Stop();
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-20 05:44 , Processed in 0.018936 second(s), 8 queries , Gzip On, Redis On.
