在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 30880|回复: 33
recovery time 和 removal time 是什么呀?
发表于 2006-12-16 21:36:11 | 显示全部楼层 |阅读模式
发表于 2006-12-17 00:10:44 | 显示全部楼层
异步信号的时序概念
Recovery time is the minimum length of time an asynchronous control signal, for example, and preset, must be stable before the next active clock edge. The recovery slack time calculation is similar to the clock setup slack time calculation, but it applies asynchronous control signals.
Removal time is the minimum length of time an asynchronous control signal must be stable after the active clock edge. The TimeQuest analyzer removal time slack calculation is similar to the clock hold slack calculation, but it applies asynchronous control signals.
发表于 2006-12-17 00:23:48 | 显示全部楼层
多谢...
 楼主| 发表于 2006-12-30 10:54:38 | 显示全部楼层
谢谢大牛!!
发表于 2008-2-29 18:06:35 | 显示全部楼层
谢谢指点,感觉和setup/hold本质一样!
发表于 2008-3-2 02:27:46 | 显示全部楼层
是时钟对复位的setup and hold
发表于 2010-8-4 21:16:53 | 显示全部楼层
求图!
发表于 2010-10-6 09:01:05 | 显示全部楼层
学习了!谢谢
发表于 2010-10-6 12:00:06 | 显示全部楼层
那这样说来的话,和setup/hold time的区别是不是setup/hold time是用于同步信号的?
发表于 2010-10-9 09:06:58 | 显示全部楼层
recovery time 和 removal time看起来和data信号对时钟信号的setup和hold up时间相似,但是实际意义是不一样的,记得当初看一本老外的书上讲的道理很明白。这两个时间是为了处理异步复位信号与时钟信号在芯片内部延时,可能造成的错误来处理的!
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-24 11:46 , Processed in 0.026785 second(s), 6 queries , Gzip On, Redis On.
