查看: 4751|回复: 8
ic6151用hspice仿真出错
发表于 2012-8-22 18:50:00 | 显示全部楼层 |阅读模式
RT,我是用按照HSPICE集成在IC5141的方法集成进去的,启动6151都没报错,但是仿真的时候hspice给报错了,如图 HSPICE-error.png ,我可以确定我的hspice没有license的问题,我直接用命令行测试过。
不知道这个是如何一回事?望求解,多谢! 5141集成hspice.rar (2.21 KB , 下载次数: 89 ) 这个是我在eetop上找到的那个方法
发表于 2012-8-24 15:26:09 | 显示全部楼层
syntax error ?  I could not understand it.
 楼主| 发表于 2012-8-24 15:57:05 | 显示全部楼层
回复 2# phoenixson
   please watch carefully,it is not syntax error, it says some about unexpected value for seed, i can's understand what the output file mean
发表于 2012-8-27 18:21:15 | 显示全部楼层
it seems that sth is wrong with the configuration file ?
 楼主| 发表于 2012-8-27 22:40:36 | 显示全部楼层
回复 4# phoenixson
   i don't know what cause the error, i just integrated the hspice into ic615 in the same way of into ic5141
发表于 2012-9-21 20:51:26 | 显示全部楼层
I am not sure if there is sth wrong with the file path/to/hspice/meta.cfg,
pls dump it there,
you can check hspice_integ.pdf for the specific way to integrate hsp into ic61
 楼主| 发表于 2012-9-22 09:06:44 | 显示全部楼层
回复 6# shujixyz
   I did not modified the meta.cfg file, and just integrated it as the brochure says. And if I run the netlist by spectre once, then I can run it by hsp in second without any errors, so it really confused me.
发表于 2012-11-30 00:58:16 | 显示全部楼层
what the 4uck i just downloaded?
Cmon man youre wasting people's time with such threads.
发表于 2017-7-3 16:09:50 | 显示全部楼层
woyeshi zhege wenti
GMT+8, 2025-12-27 19:23 , Processed in 0.023176 second(s), 8 queries , Gzip On, Redis On.
