在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1073|回复: 0
TMS320C6000 TMS320C6000DSP外设概览
发表于 2012-7-11 14:56:19 | 显示全部楼层 |阅读模式
1 概述.................................................................... 6
2 引导模式和配置........................................................... 10
3 增强直接存储器存取(EDMA)控制器............................................. 10
4 以太网媒体接入控制器(EMAC)/管理数据输入/输出(MDIO)模块........................ 10
5 扩展总线(XBUS)........................................................... 10
6 外部存储器接口(EMIF)...................................................... 11
7 通用输入/输出(GPIO) ...................................................... 11
8 主机端口接口(HPI)........................................................ 12
9 内部集成电路(I2C)模块.................................................... 12
10 中断选择器.............................................................. 13
11 多通道音频串行端口(McASP) ................................................. 13
12 多通道缓冲串行端口(McBSP) ................................................. 14
13 外设组件互连(PCI)........................................................ 14
14 锁相环(PLL)控制器........................................................ 15
15 程序和数据存储器控制器/直接存储器存取(DMA)控制器.............................. 15
16 计时器.................................................................. 16
17 Turbo解码器协处理器(TCP).................................................. 16
18 两级内部存储器........................................................... 17
19 ATM的通用测试和操作PHY接口(UTOPIA) ........................................ 17
20 视频端口/VCXO内插控制(VIC)端口............................................ 17
21 Viterbi解码器协处理器(VCP)................................................ 18
附录A 修订历史记录....................................................... 19
zhcu001.pdf (316.1 KB, 下载次数: 3 )
GMT+8, 2024-3-29 14:57 , Processed in 0.031622 second(s), 11 queries , Gzip On, Redis On.
