发表于 2009-12-31 12:24:39
显示全部楼层
1# fcc124
RTL is only a subset of behavior syntax.
For behavior code:
You can use all syntax of verilog/vhdl.
For RTL:
You can only use transfer type syntax of verilog.
Basically, there is a rule, "draw your circuit" first, then
follow circuit to write code, then result should be rtl code.
But, if you cannot draw the circuit, then it means your
idea should be "behavior". |
