在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: liu1875
ic615测试完全可用的patch和license
发表于 2012-3-15 09:47:49 | 显示全部楼层
Thanks for your kindly sharing !
发表于 2012-3-15 10:03:19 | 显示全部楼层
同求,不知道怎样才能成功使用
发表于 2012-3-16 20:51:42 | 显示全部楼层
回复 1# liu1875
    Thank for sharing
发表于 2012-3-16 22:50:21 | 显示全部楼层
回复 36# corinnayang
" Download ic615-> Installation -> the patch-> Configuration -> start virtuoso &"
Should we break the installscape operation between installation and configuration and apply the patch? Then continue to configure? Does it make difference if we install -> Configure -> Patch  or install -> configure -> Patch -> re-configure?
So far I am able to get 111 license and with MMSIM 10.1, I only able to use ADS-L but not ADS-XL and ADS-GXL.
Also only 32 bit works for me but not 64 bit, 64 bit hangs waiting license.
Please advice.  Thank you.
发表于 2012-3-18 21:07:03 | 显示全部楼层
看看!!!!!!!!!!!
发表于 2012-3-19 17:51:15 | 显示全部楼层
Thank you very much !!
发表于 2012-3-20 02:38:03 | 显示全部楼层
thanks sir looking very eagerlyyyyyyyyyyyyyyyyy
发表于 2012-3-20 02:39:58 | 显示全部楼层
thanksssssssssssssssssssssssssssssssssssssss
发表于 2012-3-20 02:42:59 | 显示全部楼层
thanks very much sirrrrrrrrrr
发表于 2012-3-20 02:44:22 | 显示全部楼层
GMT+8, 2024-5-11 02:16 , Processed in 0.028753 second(s), 7 queries , Gzip On, Redis On.
