在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
芯片精品文章合集(500篇!)    创芯人才网--重磅上线啦!
查看: 8237|回复: 18
请问IC招聘公司对应届生是否安排实习
发表于 2006-11-23 14:59:29 | 显示全部楼层 |阅读模式
大家好,我是华中科技大学在读研究生,想请教各位大虾:
一般的IC设计公司在和我们学生签了协议后,会不会在开年后安排我们去公司实习,完成毕业论文。
因为对我们来说,这样可以尽早适应公司的环境,然后毕业论文的题目更有挑战性,能给我们的学生生涯划上一个完美的句号,当然,我们也能早拿工资嘛。
谢谢各位指点。
发表于 2006-11-24 14:44:41 | 显示全部楼层
It depends on the company
Hello,
You have asked a good qeustion. In fact, it is a case-by-case question. Normally, the company will expect you get on board after you get your degree. However, quite a lot of IC companies welcome students, either signed an offer or not, negotiate with the company on the possibility of starting your work earlier. It will be a good attempt if you propose to do a small project for the company, typically 4~6 months long, and the company will be happy to see your motivation. In the worst case, if the company does not offer you a chance, you can still propose to other companies, then you will have even more chances.
Just my two cents.
 楼主| 发表于 2006-11-25 10:24:02 | 显示全部楼层
回复 #2 jingli888ca 的帖子
Thanks  a   lot !
发表于 2006-11-25 15:45:08 | 显示全部楼层
no english,please
发表于 2006-11-25 18:26:27 | 显示全部楼层
英文说的好像也不地道,是中国人的话,还是讲中文吧。
发表于 2007-1-14 16:17:10 | 显示全部楼层
shui pin hao gao a
发表于 2007-1-30 20:23:58 | 显示全部楼层
不过我还是个本科生
发表于 2007-4-14 00:54:15 | 显示全部楼层
jinli888ca版主介绍下自己吧
发表于 2007-4-29 11:17:04 | 显示全部楼层
有些公司还是会有的吧感觉
版主在国外吗?为什么用英语发帖?
发表于 2007-12-18 17:22:11 | 显示全部楼层
版主嘛~很厉害!
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-20 01:35 , Processed in 0.040150 second(s), 8 queries , Gzip On, Redis On.
