在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 5842|回复: 5
socencounter8.1安装问题
发表于 2012-2-3 13:35:52 | 显示全部楼层 |阅读模式
各位大大好,本人linux新手,在redhat as4里已经装了ic5141,现在在装socencounter8.1时候出现了这个问题,请问下有什么解决方法呢?Starting up InstallScape in GUI mode
DISPLAY environment variable is set to :0.0
If you do not see the InstallScape console
window or the it seems to be hanging then kill this
process.
Set your DISPLAY environment variable to a proper
value and manually start InstallScape by typing:
/ins/iscape/bin/iscape.sh /mnt/hgfs/share/SOCBase/CDROM1:::/soc
Initializing InstallScape using JVM at /ins/iscape/runtime/LNX86/bin/java. This might take some time...
Xlib: connection to ":0.0" refused by server
Xlib: No protocol specified
Exception in thread "main" java.lang.InternalError: Can't connect to X11 window server using ':0.0' as the value of the DISPLAY variable.
        at sun.awt.X11GraphicsEnvironment.initDisplay(Native Method)
        at sun.awt.X11GraphicsEnvironment.access$000(X11GraphicsEnvironment.java:53)
        at sun.awt.X11GraphicsEnvironment$1.run(X11GraphicsEnvironment.java:142)        at java.security.AccessController.doPrivileged(Native Method)
        at sun.awt.X11GraphicsEnvironment.<clinit>(X11GraphicsEnvironment.java:131)
        at java.lang.Class.forName0(Native Method)
        at java.lang.Class.forName(Class.java:164)
        at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(GraphicsEnvironment.java:68)
        at sun.awt.X11.XToolkit.<clinit>(XToolkit.java:96)
        at java.awt.Toolkit$2.run(Toolkit.java:821)
        at java.awt.Toolkit.getDefaultToolkit(Toolkit.java:804)
        at com.khanpur.installer.gui.InstallerUI.main(InstallerUI.java:85)
 楼主| 发表于 2012-2-3 14:20:22 | 显示全部楼层
重启一遍就没了。。。
发表于 2012-3-12 14:04:16 | 显示全部楼层
两者的相互影响谁能说一下啊?
发表于 2012-11-11 11:03:26 | 显示全部楼层
学习一下,正准备安装,谢谢分享!
发表于 2012-12-3 17:06:29 | 显示全部楼层
今天也遇到了同样的问题,请指点~
发表于 2016-9-1 22:05:34 | 显示全部楼层
能给我发一下安装包吗?非常感谢
GMT+8, 2024-3-29 18:45 , Processed in 0.029136 second(s), 8 queries , Gzip On, Redis On.
