在使用EDT压缩 scan chain时,采用了testkompress 生成EDTip和综合,在生成test pattern时,出现了error,Error: Scan chain chain1 blocked at gate /Scaler_top_edt_i/Scaler_top_edt_compactor_i (35522) after tracing 0 cells. (T3-1)
以下是运行的log,求达人解答:
/home/shaoqingtju/DFT/mgc_home.ixe/bin/testkompress edt_out/VFC_edt_top_gate.v -verilog -library lib.atpg -dofile VFC_pt_gen.do -logfile results/VFC_pt_gen.log -replace -nogui
// TestKompress v8.2007_2.10 Wed May 23 01:19:16 GMT 2007
// Copyright 2001-2007 Mentor Graphics Corporation
// All Rights Reserved.
// THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION WHICH
// IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION OR ITS LICENSORS AND IS
// SUBJECT TO LICENSE TERMS.
// This product is covered by one or more of the following U.S. patents:
// 5,991,909; 6,327,687; 6,353,842; 6,539,409; 6,543,020; 6,557,129; 6,874,109.
// Foreign patents pending.
// Mentor Graphics software executing under x86 Linux.
// 32 bit version
// Host: localhost.localdomain (1 x 3.2 GHz, 1011 MB RAM, 1983 MB Swap)
// Compiling library ...
// Reading DFT Library file lib.atpg
// Finished reading file lib.atpg
// Reading Verilog Netlist ...
// Reading Verilog file edt_out/VFC_edt_top_gate.v
// Finished reading file edt_out/VFC_edt_top_gate.v
// Warning: Following modules are undefined:
// GTECH_NOT
// GTECH_BUF
// GTECH_AND2
// GTECH_OR2
// SELECT_OP
// **SEQGEN**
// GTECH_XOR2
// Use "add black box -auto" to treat these as black boxes
// Warning: 591 cases: Unused net in DFT library model
// Warning: 138 cases: Undriven net in netlist module
// Warning: 106 cases: Primary input driven by another signal
// Warning: 389 cases: Net in netlist not connected
// Warning: 21 cases: Undefined module pin assumed to be output
// Warning: 7 cases: Undefined module pin assumed to be input
// Note: Invoke with '-load_warnings' to see detailed library and netlist load warnings
// command: add black box -auto
// command: dofile edt_out/VFC_edt.dofile
// command: set edt instances -edt_logic_top Scaler_top_edt_i
// Found edt_logic_top at path: "/Scaler_top_edt_i".
// command: set edt instances -decompressor Scaler_top_edt_decompressor_i
// Found decompressor at path: "/Scaler_top_edt_i/Scaler_top_edt_decompressor_i".
// command: set edt instances -compactor Scaler_top_edt_compactor_i
// Found compactor at path: "/Scaler_top_edt_i/Scaler_top_edt_compactor_i".
// command: add scan groups grp1 edt_out/VFC_edt.testproc
// command: add scan chains -internal chain1 grp1 /Scaler_top_i/Data_in[0] /Scaler_top_i/R_out[0]
// command: add scan chains -internal chain2 grp1 /Scaler_top_i/Data_in[1] /Scaler_top_i/R_out[1]
// command: add scan chains -internal chain3 grp1 /Scaler_top_i/Data_in[2] /Scaler_top_i/R_out[2]
// command: add scan chains -internal chain4 grp1 /Scaler_top_i/Data_in[3] /Scaler_top_i/R_out[3]
// command: add scan chains -internal chain5 grp1 /Scaler_top_i/Data_in[4] /Scaler_top_i/R_out[4]
// command: add scan chains -internal chain6 grp1 /Scaler_top_i/Data_in[5] /Scaler_top_i/R_out[5]
// command: add scan chains -internal chain7 grp1 /Scaler_top_i/Data_in[6] /Scaler_top_i/R_out[6]
// command: add scan chains -internal chain8 grp1 /Scaler_top_i/Data_in[7] /Scaler_top_i/R_out[7]
// command: add scan chains -internal chain9 grp1 /Scaler_top_i/Data_in[8] /Scaler_top_i/G_out[0]
// command: add scan chains -internal chain10 grp1 /Scaler_top_i/Data_in[9] /Scaler_top_i/G_out[1]
// command: add scan chains -internal chain11 grp1 /Scaler_top_i/Data_in[10] /Scaler_top_i/G_out[2]
// command: add scan chains -internal chain12 grp1 /Scaler_top_i/Data_in[11] /Scaler_top_i/G_out[3]
// command: add scan chains -internal chain13 grp1 /Scaler_top_i/Data_in[12] /Scaler_top_i/G_out[4]
// command: add scan chains -internal chain14 grp1 /Scaler_top_i/Data_in[13] /Scaler_top_i/G_out[5]
// command: add scan chains -internal chain15 grp1 /Scaler_top_i/Data_in[14] /Scaler_top_i/G_out[6]
// command: add scan chains -internal chain16 grp1 /Scaler_top_i/Data_in[15] /Scaler_top_i/G_out[7]
// command: add clocks 0 RST
// command: add clocks 0 VGA_IN_DATA_CLK
// command: add clocks 0 Clk_most
// command: add clocks 0 out_pix_clk
// command: add clocks 0 Sysclk
// command: add clocks 0 scan_set
// command: add clocks 0 edt_clock
// command: add pin constraints test_en C1
// command: add pin constraints edt_clock C0
// command: set edt -channels 4 -bypass_logic on -pipeline_logic_levels_in_compactor 2 -longest_chain_range 9 350 -ip_version 3 -decompressor_size 32 -injectors_per_channel 4 -scan_chains 16
// command: set edt pins update Href
// command: set edt pins scan_en scan_en
// command: set edt pins bypass Vref
// command: set edt pins input_channel 1 Data_in[16]
// command: set edt pins output_channel 1 B_out[0]
// command: set edt pins input_channel 2 Data_in[17]
// command: set edt pins output_channel 2 B_out[1]
// command: set edt pins input_channel 3 Data_in[18]
// command: set edt pins output_channel 3 B_out[2]
// command: set edt pins input_channel 4 Data_in[19]
// command: set edt pins output_channel 4 B_out[3]
// command: set pattern type -sequential 2
// Settings : -RAM_sequential OFF
// -SEQuential 2
// -MULtiple_load OFF
// -CLOck_po ON
// command: set system mode atpg
// Warning: Rule FN1 violation occurs 527 times
// Warning: Rule FN2 violation occurs 48 times
// Flattening process completed, design_cells=30639 library_primitives=127947 blackbox_tie=3729 sim_gates=108756 PIs=55 POs=29 cpu time=0.48 sec.
// Begin circuit learning analyses.
// Equivalent gates=1650 classes=688 CPU time=0.20 sec.
// Learned gate functions: #BUFs=75 #INVs=27 #XORs=1100 #MUXs=1094
// Learned relationships: #EQ_MUXs=2
// Learned tied gates: #TIED_ORs=2
// Learning activity limit exceeded: static learning process was truncated.
// Learning completed, implications=34217, tied_gates=3024, CPU time=0.12 sec.
// 20 wired_gates are modeled as WIRE gates.
// Begin scan chain identification process, memory elements = 5590.
// Reading group test procedure file edt_out/VFC_edt.testproc.
// Simulating load/unload procedure in grp1 test procedure file.
// Error: Scan chain chain1 blocked at gate /Scaler_top_edt_i/Scaler_top_edt_compactor_i (35522) after tracing 0 cells. (T3-1)
// Error: Scan chain chain2 blocked at gate /Scaler_top_edt_i/Scaler_top_edt_compactor_i (35523) after tracing 0 cells. (T3-2)
// Error: Scan chain chain3 blocked at gate /Scaler_top_edt_i/Scaler_top_edt_compactor_i (35524) after tracing 0 cells. (T3-3)
// Error: Scan chain chain4 blocked at gate /Scaler_top_edt_i/Scaler_top_edt_compactor_i (35525) after tracing 0 cells. (T3-4)
// Error: Scan chain chain5 blocked at gate /Scaler_top_edt_i/Scaler_top_edt_compactor_i (35526) after tracing 0 cells. (T3-5)
// Error: Scan chain chain6 blocked at gate /Scaler_top_edt_i/Scaler_top_edt_compactor_i (35527) after tracing 0 cells. (T3-6)
// Error: Scan chain chain7 blocked at gate /Scaler_top_edt_i/Scaler_top_edt_compactor_i (35528) after tracing 0 cells. (T3-7)
// Error: Scan chain chain8 blocked at gate /Scaler_top_edt_i/Scaler_top_edt_compactor_i (35529) after tracing 0 cells. (T3-8)
// Error: Scan chain chain9 blocked at gate /Scaler_top_edt_i/Scaler_top_edt_compactor_i (35530) after tracing 0 cells. (T3-9)
// Error: Scan chain chain10 blocked at gate /Scaler_top_edt_i/Scaler_top_edt_compactor_i (35531) after tracing 0 cells. (T3-10)
// Error: Scan chain chain11 blocked at gate /Scaler_top_edt_i/Scaler_top_edt_compactor_i (35532) after tracing 0 cells. (T3-11)
// Error: Scan chain chain12 blocked at gate /Scaler_top_edt_i/Scaler_top_edt_compactor_i (35533) after tracing 0 cells. (T3-12)
// Error: Scan chain chain13 blocked at gate /Scaler_top_edt_i/Scaler_top_edt_compactor_i (35534) after tracing 0 cells. (T3-13)
// Error: Scan chain chain14 blocked at gate /Scaler_top_edt_i/Scaler_top_edt_compactor_i (35535) after tracing 0 cells. (T3-14)
// Error: Scan chain chain15 blocked at gate /Scaler_top_edt_i/Scaler_top_edt_compactor_i (35536) after tracing 0 cells. (T3-15)
// Error: Scan chain chain16 blocked at gate /Scaler_top_edt_i/Scaler_top_edt_compactor_i (35577) after tracing 0 cells. (T3-16)
// Error: Rules checking unsuccessful, cannot exit SETUP mode.
// 'DOFile VFC_pt_gen.do' aborted at line 4
// command: exit |
