在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 18002|回复: 22
急!!vcs200912安装好后DVE启动不了。。是怎么回事呢,谢谢!!
发表于 2011-10-17 19:07:59 | 显示全部楼层 |阅读模式
installer v2.0scl 10.9.3虚拟机上装的Red Hat Enterprise Linux Server release 5.4
vcs 200912
没装过啥中文输入法(另外怎么查看已装好的??)
【vcs命令可以,但是当输入dve的时候会报错,如下:】
License server does not support feature VT_Visual
This feature has expired, or has not yet started or is
greater than the highest version.
Please contact VCS Customer Support at 1-800-verilog for more information.
Failed to obtain license...
Note: Use +vcs+lic+wait ( or -licwait <minute> or -licqueue  in Unified Use Model ) to queue for license
【这是怎么回事呢?请求知道的能解答一下。我的.bashrc文件设置如下】
#lmgrd
export PATH="/home/suwon/eda/synopsys/scl/linux/bin:"$PATH
#start synopsys license using lmgrd
alias lmli2="lmgrd -c /home/suwon/eda/synopsys/license/synopsys.dat -l ~/syn_lic.log"
#setenv VCS_ARCH_OVERRIDE linux
#vcs-mx
export PATH="/home/suwon/eda/synopsys/vcs200912/bin:"$PATH
#Set Home Directory
export SYNOPSYS="/home/suwon/eda/synopsys"
export VCS_HOME="/home/suwon/eda/synopsys/vcs200912"
#SNPSLMD_LICENSE_FILE
export SNPSLMD_LICENSE_FILE=27000@localhost
【而且貌似virsim也不能用,当输入vcs -RPP时,会有以下报错:(这个是次要的,主要想用DVE的)】
Please contact VCS Customer Support at 1-800-VERILOG for more information.
[suwon@localhost I2c]$ vcs -RPP
VirSim is being deprecated. It will become unavailable in future releases.
The VCS switches -RI, -RIG, and -RPP will become obsolete and will not be supported after this release.
Please migrate to DVE. Please contact Synopsys support for more details.
/home/suwon/eda/synopsys/vcs200912/gui/virsim/linux/bin/virsim.exe: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
Note: Execution of /home/suwon/eda/synopsys/vcs200912/gui/virsim/bin/virsim exited with code 127
 楼主| 发表于 2011-10-17 19:09:48 | 显示全部楼层
可以跑仿真和dump波形文件,但是看不了啊。。。
发表于 2011-10-18 01:17:10 | 显示全部楼层
说得很清楚了呀: error while loading shared libraries: libstdc++.so.5
找不到这个lib…
google个rpm包回头装上再试试看。
 楼主| 发表于 2011-10-20 10:50:22 | 显示全部楼层
不支持,license?为啥其他人可以用呢
发表于 2011-11-2 11:14:17 | 显示全部楼层
不知道 你这个问题解决了没有,我也遇到这个问题,不能运行DVE。
 楼主| 发表于 2011-11-3 19:40:58 | 显示全部楼层
已解决VT_Visual license 问题。方法如下,希望对其他人有所帮助
在EFA LicGen 0.4b\packs下的Synopsys.src中加入VT_Visual即可,再按照之前的license生成方法重新生成synopsys.dat,即可。必要时需要重新启动计算机或虚拟机才可用。
PACKAGE EFA_Synopsys_16 snpslmd 2019.12 0 \
COMPONENTS="TestManager \
TestSim \
Ultra37000 \
VANTIS \
VCSCompiler_Net \
VCSDebugger_Net \
VCSPostProcDebugger_Net \
VCSRuntime_Net \
VCSTools_Net \
VT_Visual \
VDesktop-Debug \
VDesktop-GUI \
VDesktop-VCDTrans \
VDesktop-VHDL \
VDesktop-Verilog \
顺便总结一下vcs安装过程中可能遇到的问题:
另外如果还存在这个问题:关于dve启动有界面,但是没有任何菜单显示的,可以参考网上的帖子,解决方法是卸载scim中文输入法,如果安装的话。可以选装兼容性好的其他中文输入法。
还有一个问题就是virsim界面启动不了的问题(命令VCS -RPP &),出现段错误 $CMD "$@"
virsim, 段错误,网上也有帖子,解决办法:
cd /usr/X11R16
mkdir lib (原来没有就mkdir,否则不动)
cd lib
ln -s /usr/share/X11
详见http://bbs.eetop.cn/thread-275469-1-1.html
至于这个问题error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
,用yum安装一下即可,网上也有相关帖子。可能有时yum命令用不了,也参考网上帖子,不作详述。(问题好多啊。。。。)
下面将我生成vcs license的步骤文档,以及相关文件一并上传,非常感谢网友的无私奉献~~
上传文件中的Synopsys.src已被我增加VT_Visual。
 楼主| 发表于 2011-11-3 19:44:43 | 显示全部楼层
附件 虚拟机Linux系统中安装SYNOPSYS工具图解教程.docx (2.04 MB, 下载次数: 430 )
EFA LicGen 0.4b.rar (665.84 KB, 下载次数: 376 )
synopsys.SSS.keygen.zip (612.97 KB, 下载次数: 273 )
发表于 2011-12-3 14:06:15 | 显示全部楼层
虚拟机Linux系统中安装SYNOPSYS工具图解教程.docx 这个文档怎么下不下来啊?
 楼主| 发表于 2011-12-6 19:25:41 | 显示全部楼层
可以下的
发表于 2012-5-24 15:25:31 | 显示全部楼层
果然牛x,一改就能用vt visual了
GMT+8, 2024-3-29 17:22 , Processed in 0.035067 second(s), 9 queries , Gzip On, Redis On.
