这是设计源文件
library ieee;
use ieee.std_logic_1164.all;
entity shifter_ent is
port(data: in std_logic_vector(3 downto 0);
load,clk,enable : in std_logic;
mode:in std_logic_vector(1 downto 0);
output: out std_logic_vector(3 downto 0));
end shifter_ent;
architecture shifter_arch of shifter_ent is
signal internal_output : std_logic_vector(3 downto 0);
begin
process(clk)
begin
if(clk='1' and clk'event) then
if(enable='0') then
if(load='0') then
internal_output<=data;
else
case mode is
when "00" => internal_output<=internal_output(2 downto 0) & '0';
when "01" => internal_output<='0' & internal_output(3 downto 1);
when "11" => internal_output<=internal_output(2 downto 0) &internal_output(3);
when "10" => internal_output<=internal_output(0) &internal_output(3 downto 1);
when others => internal_output<="0000";
end case;
end if;
else
end if;
end if;
end process;
output<=internal_output;
end shifter_arch;
----------------------------------------------------- 这是测试平台
library ieee;
package shifter_package is
constant cycle : time :=50 ns ;
signal sig_data : std_logic_vector(3 downto 0);
signal sig_mode : std_logic_vector(1 downto 0);
signal sig_output_before_shifter : std_logic_vector(3 downto 0);
signal sig_output_after_shifter : std_logic_vector(3 downto 0);
procedure load_data(
signal load : out std_logic;
signal data : out std_logic_vector(3 downto 0);
signal mode : out std_logic_vector(1 downto 0));
procedure check_data(
end shifter_package;
package body shifter_package is
procedure check_data (
signal mode : out std_logic_vector(1 downto 0)) is
begin
mode<=sig_mode;
if(sig_mode="00") then
if(sig_output_after_shifter/=sig_output_before_shifter(2 downto 0)&'0') then
assert false
report"Error detected in shift left"
severity warning;
end if;
elsif(sig_mode="01")then
if(sig_output_after_shifter/='0'&sig_output_before_shifter(3 downto 1)) then
assert false
report"Error detected in shift right"
severity warning;
end if;
elsif(sig_mode= "10")then
if(sig_output_after_shifter/=sig_output_before_shifter(0)&sig_output_before_shifter(3 downto 1)) then
assert false
report"Error detected in shift barrel right "
severity warning;
end if;
elsif(sig_mode= "11" ) then
if(sig_output_after_shifter/=sig_output_before_shifter(2 downto 0)&sig_output_before_shifter(3 )) then
assert false
report "Error detected in shift barrel left"
severity warning;
end if;
end if;
end check_data;
signal data: out std_logic_vector(3 downto 0);
signal mode : out std_logic_vector(1 downto 0);
signal load : out std_logic) is
begin
data<=sig_data;
mode<=sig_mode;
load<='1';
wait for cycle ;
load<='0';
wait for cycle;
load<='1';
wait for cycle;
end load_data;
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY shifter_ent_vhd_tst IS
END shifter_ent_vhd_tst;
ARCHITECTURE shifter_ent_arch OF shifter_ent_vhd_tst IS
-- constants
-- signals
SIGNAL clk : STD_LOGIC;
SIGNAL data : STD_LOGIC_VECTOR(3 DOWNTO 0);
SIGNAL enable : STD_LOGIC;
SIGNAL load : STD_LOGIC;
SIGNAL mode : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL output : STD_LOGIC_VECTOR(3 DOWNTO 0);
COMPONENT shifter_ent
PORT (
clk : IN STD_LOGIC;
data : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
enable : IN STD_LOGIC;
load : IN STD_LOGIC;
mode : IN STD_LOGIC_VECTOR(1 DOWNTO 0);
output : OUT STD_LOGIC_VECTOR(3 DOWNTO 0)
END COMPONENT;
BEGIN
i1 : shifter_ent
PORT MAP (
-- list connections between master ports and signals
clk => clk,
data => data,
enable => enable,
load => load,
mode => mode,
output => output
clk<= not clk after cycle/2;
always : PROCESS
-- optional sensitivity list
-- variable declarations
BEGIN
enable<='0'; --启动移位器
sig_data<="1010"; ----将数据“1010”载入移位器
sig_mode<="00";
wait for cycle;
load_data(load,data,mode);
for i in 0 to 6 loop --左移
sig_output_before_shifter<=output;
wait for cycle;
sig_output_after_shifter<=output;
wait for cycle;
check_data(mode);
end loop;
sig_mode<="01";
wait for cycle;
for i in 0 to 6 loop --右移
wait for cycle;
wait for cycle;
check_data(mode);
end loop;
-- code executes for every event on sensitivity list
WAIT;
END PROCESS always;
END shifter_ent_arch;
这个设计在quartus中是对的,测试平台在quartus自动调用modelsim出现了错误,我不知道这是为什么,向各位好友求教。
错误为: ** Error: E:/exercise/x/simulation/modelsim/shifter_ent.vhd(61): Procedure "load_data" declared at line 9 has no body.
# ** Error: E:/exercise/x/simulation/modelsim/shifter_ent.vhd(61): Vhdl Compiler exiting
# ** Error: E:/modelsim.altera/modelsim_ae/win32aloem/vcom failed. |
