在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 111030|回复: 89
[求助] (lmgrd) Failed to open the TCP port number in the license.
发表于 2011-9-18 14:41:04 | 显示全部楼层 |阅读模式
请问各位大哥在破解synopsys的软件时遇到(lmgrd) Failed to open the TCP port number in the license.该怎么处理呢?
[root@localhost Desktop]# lmlis
2:23:47 (lmgrd) -----------------------------------------------
2:23:47 (lmgrd)   Please Note:
2:23:47 (lmgrd)
2:23:47 (lmgrd)   This log is intended for debug purposes only.
2:23:47 (lmgrd)   In order to capture accurate license
2:23:47 (lmgrd)   usage data into an organized repository,
2:23:47 (lmgrd)   please enable report logging. Use Macrovision's
2:23:47 (lmgrd)   software license administration  solution,
2:23:47 (lmgrd)   FLEXnet Manager, to  readily gain visibility
2:23:47 (lmgrd)   into license usage data and to create
2:23:47 (lmgrd)   insightful reports on critical information like
2:23:47 (lmgrd)   license availability and usage. FLEXnet Manager
2:23:47 (lmgrd)   can be fully automated to run these reports on
2:23:47 (lmgrd)   schedule and can be used to track license
2:23:47 (lmgrd)   servers and usage across a heterogeneous
2:23:47 (lmgrd)   network of servers including Windows NT, Linux
2:23:47 (lmgrd)   and UNIX. Contact Macrovision at
2:23:47 (lmgrd)   www.macrovision.com for more details on how to
2:23:47 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
2:23:47 (lmgrd)   for your enterprise.
2:23:47 (lmgrd)
2:23:47 (lmgrd)
2:23:47 (lmgrd)
2:23:47 (lmgrd) The license server manager (lmgrd) running as root:
2:23:47 (lmgrd)
This is a potential security problem
2:23:47 (lmgrd)
and is not recommended.
[root@localhost Desktop]#  2:23:47 (lmgrd) Failed to open the TCP port number in the license.
谢谢!
 楼主| 发表于 2011-9-19 19:39:32 | 显示全部楼层
我按Synopsys® Common Licensing Administration Guide上说的做了,但还是没有解决!
 楼主| 发表于 2011-9-19 19:40:50 | 显示全部楼层
发表于 2011-10-31 17:38:49 | 显示全部楼层
同问。。不知道楼主解决了没。。
发表于 2011-11-23 14:16:30 | 显示全部楼层
我也不知道
发表于 2011-11-23 22:03:29 | 显示全部楼层
看一下license文件第一行的hostname和portnumber,跟本机的是不是能对上。。
一般hostname填localhost应该就ok了。
portnumber一般用不用修改。
发表于 2011-12-16 13:59:11 | 显示全部楼层
你如果运行了其他的license,或者运行了该版本的license,可能已经打开这个端口,关掉license,重新打开应该可以解决问题(lmdown)
发表于 2012-1-14 14:27:28 | 显示全部楼层
   灰常正确,谢谢!!!
发表于 2012-2-16 15:10:03 | 显示全部楼层
回复 8# xhwubai
    还没解决掉,头疼啊,求指导
发表于 2012-3-2 16:11:20 | 显示全部楼层
回复  xhwubai
     还没解决掉,头疼啊,求指导
pylon 发表于 2012-2-16 15:10
    你好  我也是这个问题  加我QQ交流下吧  511644215
GMT+8, 2024-3-29 13:27 , Processed in 0.034112 second(s), 8 queries , Gzip On, Redis On.
