在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: zhuzhzh
RTL级最强验证工具spyglass
 楼主| 发表于 2011-8-28 14:47:58 | 显示全部楼层
回复 28# tdscdma22
你全部解压缩就行了,在bin下面有spyglass这个程序
把$SPYGLASS_HOME/bin加入path就可以了
发表于 2011-8-29 20:16:09 | 显示全部楼层
楼主:
    你的系统是什么?我的是red head enterprise linux5,按照你说的,不行?
发表于 2011-9-4 19:53:52 | 显示全部楼层
回复 1# zhuzhzh
   太强了,感谢lz
发表于 2011-9-19 14:17:34 | 显示全部楼层
MARK
这个比较新,有空再研究
发表于 2011-9-19 21:18:00 | 显示全部楼层
..............................................no coco Orz
发表于 2011-9-19 22:40:51 | 显示全部楼层
下載這個好傷錢 QQ
发表于 2011-9-20 00:19:29 | 显示全部楼层
不好意思我照你所說設好$PATH後跑SPYGLASS,他出現了error:
[serve@localhost test]$ spyglass
INFO [SPG#1044]: Running in interactive mode...
It is recommended to set environment variable ATRENTA_LICENSE_FILE for faster license checkout.
Can't load '/eda/SpyGlass-4.4.0/SPYGLASS_HOME/auxi/tkgui-new/Linux2/projectManager.so' for module projectManager: /eda/SpyGlass-4.4.0/SPYGLASS_HOME/lib/libtclgui-Linux2.so: undefined symbol: Tcl_VerifyChecksum at /eda/SpyGlass-4.4.0/SPYGLASS_HOME/lib/multi-perl/bin/../lib/5.8.3/i686-linux-thread-multi/DynaLoader.pm line 229.
at /eda/SpyGlass-4.4.0/SPYGLASS_HOME/auxi/tkgui-new//spywizprojectmanager.pl line 4
        main:IE_handler('Can\'t load \'/eda/SpyGlass-4.4.0/SPYGLASS_HOME/auxi/tkgui-ne...') called at /eda/SpyGlass-4.4.0/SPYGLASS_HOME/auxi/tkgui-new//spywizprojectmanager.pl line 4
        main::BEGIN() called at /eda/SpyGlass-4.4.0/SPYGLASS_HOME/auxi/tkgui-new//projectManager.pm line 4
        eval {...} called at /eda/SpyGlass-4.4.0/SPYGLASS_HOME/auxi/tkgui-new//projectManager.pm line 4
        require spywizprojectmanager.pl called at /eda/SpyGlass-4.4.0/SPYGLASS_HOME/auxi/tkgui-new//spywizinit.pl line 26
        require spywizinit.pl called at /eda/SpyGlass-4.4.0/SPYGLASS_HOME/auxi/tkgui-new/spygui.pl line 2133
BEGIN failed--compilation aborted at /eda/SpyGlass-4.4.0/SPYGLASS_HOME/auxi/tkgui-new//spywizprojectmanager.pl line 4.
Compilation failed in require at /eda/SpyGlass-4.4.0/SPYGLASS_HOME/auxi/tkgui-new//spywizinit.pl line 26.
Compilation failed in require at /eda/SpyGlass-4.4.0/SPYGLASS_HOME/auxi/tkgui-new/spygui.pl line 2133.
這是哪邊有問題嗎
发表于 2011-9-20 01:28:40 | 显示全部楼层
謝謝樓主的說明
发表于 2011-9-21 00:42:32 | 显示全部楼层
THANK VERY MUCH
发表于 2011-9-29 23:56:00 | 显示全部楼层
这个没尝试过,先mark下
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-24 19:06 , Processed in 0.027394 second(s), 7 queries , Gzip On, Redis On.
