坛子上有人发过这本书,不过是4个包,现整理成一个包的,重新发出来。
LabVIEW Digital Signal Processing: and Digital Communications [Hardcover]
Editorial Reviews Product Description LabVIEW Digital Signal Processing teaches engineers how to use the graphical programming language to create virtual instruments to handle to most sophisticated dsp applications. From basic filters to complex sampling mechanisms to signal generators, LabVIEW virtual instruments (VIs) can make DSP work faster and much less expensive – a particular boon to the many engineers working on cutting edge communications systems.
From the Back Cover Create sophisticated DSP virtual instruments with LabVIEW
Take full advantage of all the digital signal processing capabilities LabVIEW has to offer with help from this hands-on tutorial. Readers will learn, step-by-step, how to use this revolutionary graphical development environment to build flexible and scalable digital signal acquisition, measurement analysis, and data presentation applications.
From basic filters to complex sampling mechanisms to signal generators, LabVIEW virtual instruments (VIs) enable rapid and inexpensive digital signal processing. Ideal for engineers working on cutting-edge communication systems, this detailed learning guide offers solutions for creating applications that interface with real-world signals, analyzing data for meaningful information, and sharing results.
Comprehensive coverage includes: - LabVIEW Fourier tools
- Designing with built-in filtering routines
- Optimizing and improving speed
- IQ modulation
- Time and frequency synchronization
- Evaluating system performance
HANDLE EVEN THE MOST COMPLEX DSP APPLICATIONS
Getting started * Digital signal processing and LabVIEW: How do they fit together? * Signal acquisition * Building blocks * Spectral analysis * Designing and using digital filters * Multirate processing * Building a communication system * Generating signals * Demodulation
Product Details
