在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
EETOP诚邀模拟IC相关培训讲师 创芯人才网--重磅上线啦!
查看: 1833|回复: 0
[原创] 軍工宇航級晶振
发表于 2011-6-30 12:03:55 | 显示全部楼层 |阅读模式
我們提供如下軍工級晶體振盪器。歡迎諸位客戶隨時聯繫。) M+ P) }- Z* N, P3 c8 T7 w: E
; y( ?" O  n4 o: A
溫補晶振(TCXO)
10MHz,5V, Sine 10kohm/10F, +/-0.5PPM, -40~+85'C,帶壓控,SMD7x5
12.8MHz,3.3V, HCMOS 15pF, +/-1PPM, -40~+85'C,帶壓控,SMD7x51 h8 `9 l; y* m2 l$ c
13MHz,3.3V, HCMOS 15pF, +/-1PPM, -40~+85'C,帶壓控,SMD7x5
16.384MHz,3.3V, HCMOS 15pF, +/-1PPM, -40~+85'C,帶壓控,SMD7x5
19.44MHz,3.3V, HCMOS 15pF, +/-1PPM, -40~+85'C,帶壓控,SMD7x5
20MHz,3.3V, HCMOS 15pF, +/-1PPM, -40~+85'C,帶壓控,SMD7x58 S2 G6 m; X" E- Z6 P+ Z1 d3 H$ x5 C0 B
20MHz,3.3V, HCMOS 15pF, +/-0.28PPM, -40~+85'C,帶壓控,SMD7x5
40MHz,3.3V, HCMOS 15pF, +/-0.28PPM, -40~+85'C,帶壓控,SMD7x5
10MHz,3.3V, HCMOS 15pF, +/1PPM, -40~+85'C,帶壓控,SMD5x3.2+ }) w! T% i/ t) ~* u
16.384MHz,3.3V, HCMOS 15pF, +/1PPM, -40~+85'C,帶壓控,SMD5x3.2
19.2MHz,3.3V, HCMOS 15pF, +/1PPM, -40~+85'C,帶壓控,SMD5x3.2, R, `6 Q( w: u" X! w
20MHz,3.3V, HCMOS 15pF, +/1PPM, -40~+85'C,帶壓控,SMD5x3.2* \& `( k: i0 h# d
32.768MHz,3.3V, HCMOS 15pF, +/1PPM, -40~+85'C,帶壓控,SMD5x3.2
50MHz,3.3V, HCMOS 15pF, +/1PPM, -40~+85'C,帶壓控,SMD5x3.2
軍工級TCXO(定制)
10~80MHz, 3.3V/5V, HCMOS/Sine, ±1PPM(-20!+70°), ±3PPM(-40~+85°C), DIP14/SMD, MIL-PRF-55310 Level B# j9 j/ F) q0 {! k
宇航級TCXO(定制)" x$ j& R. n5 O! E) h6 o
2~150MHz, 5~15V, Sine,  ±2PPM(-20!+70°), ±4PPM(-40~+85°C), 100kRads, 32x20x7.6mm, 24Pin
恒溫晶振(OCXO,軍工宇航級,需訂制)' A# D) l* m9 ], b! V: T% A- j
Frequency: 80~125MHz(典型頻率100MHz,、120MHz)
Supply voltage: 12V, 15V. e& n2 E5 _& s3 O0 U  _
Output wave: Sine 50ohm
Frequency Stability: ±5E-7
Operating Temperature range: -40~+85°C
Phase noise: -135dBc/Hz@100Hz  -163dBc/Hz@1kHz (for 100MHz)3 m  M( W5 ^, _) u2 g
                         -132dBc/Hz@100Hz  -160dBc/Hz@1kHz  (for 120MHz)
Aging: ±0.5ppm/1st year, ±2ppm/10 year
Vibration: Mil-STD-202G method 204 condition A: sinus 10-500Hz 10g
Shock: Mil-STD-202G method 213 condition A: half-sine 50g, 11ms& z1 r% G4 y6 i1 X
Package: 51x51x26mm   d2 Z6 W0 d2 h1 e1 i
QQ: 3 5 8 5 4 1 1 4 2  手機:1 3 9 2 2 8 4 6 4 6 5
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-20 17:12 , Processed in 0.018206 second(s), 8 queries , Gzip On, Redis On.
