在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: 陈涛
[转贴] 后端面试--每日一题(014)
发表于 2012-2-6 10:49:33 | 显示全部楼层
过来学习一下
发表于 2012-2-14 15:34:08 | 显示全部楼层
学习中。
发表于 2015-8-10 20:23:07 | 显示全部楼层
摘录一段解释
Buffers versus inverters
As input goes into a buffer, the input of the first stage inverter, it only drives the output stage inverter with no wire. Therefore, buffer has a transition time recovery benefit to clock signals.  If a slower transition gets feed into an inverter, the input slow transition will also affect the output transition time directly.  This will cause more skew and jitters in the clock tree, especially, in the high level of clock tree, where long wire is predominant.
When the entire clock tree uses buffers only, at rise clock edge, all clock nets need to be charged up.  VDD power net needs to provide the charge required to raise the entire clock nets. For inverters, input signal will switch in the opposite direction as the output.  Therefore, when using inverters, the simultaneous switching power noise will be reduced.
发表于 2015-10-25 13:08:02 | 显示全部楼层
还是不懂为何inverter不利于skew的调整和branch的重新连接,而buffer就便于作此修改
发表于 2015-10-25 22:45:06 | 显示全部楼层
发表于 2015-10-26 12:01:42 | 显示全部楼层
回复 13# 真我个性
这个解释好精辟!
发表于 2015-11-1 22:18:52 | 显示全部楼层
感谢分享
发表于 2015-11-4 11:53:06 | 显示全部楼层
是不是因为inverter 的话必须保证是双数的地方才能动的原因呢?
buffer tree 随便哪里都行,但是inverter 必须保证不是奇数个的地方
发表于 2019-9-29 13:56:45 | 显示全部楼层
#18 我觉得有理。
发表于 2021-6-20 09:39:30 | 显示全部楼层
Kevin.Chou 发表于 2015-10-25 13:08
还是不懂为何inverter不利于skew的调整和branch的重新连接,而buffer就便于作此修改 ...
inv插就得插一对儿,buffer一个就行了
GMT+8, 2024-3-29 01:50 , Processed in 0.026859 second(s), 6 queries , Gzip On, Redis On.
