在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2716|回复: 1
[讨论] system verilog的array的问题, 欢迎来讨论.
发表于 2011-4-8 17:10:02 | 显示全部楼层 |阅读模式
在标准的12.4.2中:
Elements of dynamic arrays, queues, and associative arrays that are passed by reference may get removed
from the array or the array may get resized before the called function or task completes. The specific array
element passed by reference shall continue to exist within the scope of the called tasks or functions until they
complete. Changes made to the values of array elements by the called task or function shall not be visible
outside the scope of those tasks or functions if those array elements were removed from the array before the
changes were made. These references shall be called outdated references.
那如果变成了outdated reference会怎么样?????
还有, 我怎么样直接传参数给一个"queue of string"
例如, 定义一个functionAAA, 参数为string的queue类型sq[$]
virtual function void AAA (string sq [$])
endfunction
调用这个function的时候, 如果我写
AAA({"SSS"});
他报错说:
formal and actual do not have assignment compatible data types (expecting datatype compatible with 'queue of string' but found 'packed array' instead).
我应该怎么写?
发表于 2011-4-11 15:38:50 | 显示全部楼层
同问。
请高手来解答。
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-19 03:18 , Processed in 0.022833 second(s), 8 queries , Gzip On, Redis On.
