在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 100863|回复: 145
[求助] rail to rail 输出级用到的悬浮电流镜的作用是什么?怎么工作的?
发表于 2010-12-27 16:22:23 | 显示全部楼层 |阅读模式
悬浮电流镜难道就是作为传输电阻,给输出级m25和m26管偏置电压的吗?
那这个偏置稳定吗?静态时,m19和m20管的电流需要相等吗?
如果驱动1K电阻负载,这个运放是开环用吗?
发表于 2010-12-27 21:42:35 | 显示全部楼层
谢谢分享!!
发表于 2010-12-28 09:10:06 | 显示全部楼层
这么复杂,没见过!!!
发表于 2010-12-28 20:52:04 | 显示全部楼层
可以参考一下这篇文章
abbr_5617ec2a3aeb98b69587e0b1e0d7ec76.pdf
925.31 KB, 下载次数: 2438 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-12-28 23:59:12 | 显示全部楼层
这貌似是个挺常见的电路
 楼主| 发表于 2010-12-29 09:06:33 | 显示全部楼层
发表于 2010-12-29 23:36:18 | 显示全部楼层
谢谢分享!
发表于 2010-12-30 07:29:46 | 显示全部楼层
No, the current through M19 and M20 are not necessarily equal.
But, you have the freedom to make the current roughly the same in your design.
These two devices are used to bias the output M25 and M26 devices.
VG of M25 is set at VDDA - VGS_M21 - VGS_M22 + VGS_M20.  (approximately 1 "diode" drop from power.)
VG of M26 is set at 0 V + VGS_M23 + VGS_M24 - VGS_M19. (approxaimately 1 "diode" drop above ground.)
DC analysis
Assuming balanced inputs,
The current through M16, I(M16) = Ib4 - 0.5 * Ib1
I(M19) + I(M20) = I(M16)
I(M19) is mirrored from Ib8.  I(M19) = (W_M19 / W_M23) * Ib8 (assuming same lengths for M23 and M19)
I(M20) is mirrored from Ib5.  I(M20) = (W_M20 / W_M22) * Ib5 (assumping same lengths for M20 and M22)
Additional notes
Usually M25 and M26 output directly drives off-chip (i.e., they are large devices) and are subject to ESD design rule.
So are M19, M20, M22 & M23 subject to ESD rule, since we want good VTH tracking.  (They are small devices.)
Yes, this OpAmp is able to drive 1 KOhm resistive load.
 楼主| 发表于 2010-12-30 10:06:24 | 显示全部楼层
But, you have the freedom to make th ...
fhchen2002 发表于 2010-12-30 07:29
    悬浮电流镜偏置电流不准吧,难道要求不高吗?只要让19和20管导通就行了吗?
  这个Vth跟踪特性不好吧?体效应影响明显,要是三极管就好了
发表于 2010-12-30 23:23:38 | 显示全部楼层
thanks for patience~~
GMT+8, 2025-2-27 20:56 , Processed in 0.024786 second(s), 6 queries , Gzip On, Redis On.
