查看: 27694|回复: 86
[资料] 小数分频频率综合器——Perrott大师全套论文(十分经典)
发表于 2010-11-28 23:50:28 | 显示全部楼层 |阅读模式
小数分频频率综合器——MIT Perrott大师全套论文以及他的相关教程,做频率综合器必看,同时给出LNA全套论文的连接:http://bbs.eetop.cn/thread-276923-1-1.html
M.Z. Straayer, M.H. Perrott, "A 10-bit 20MHz 38mW 950MHz CT ΣΔ ADC with a 5-bit noise-shaping VCO-based Quantizer and DEM circuit in 0.13u CMOS," IEEE VLSI Circuits Symp., Jun. 2007, pp. 246-247. PDF
B.M. Helal, M.Z. Straayer, G-Y Wei, M.H. Perrott, "A Low Jitter 1.6 GHz Multiplying DLL Utilizing a Scrambling Time-to-Digital Converter and Digital Correlation," IEEE VLSI Circuits Symp., Jun. 2007, pp. 166-167. PDF
M.H. Perrott, Y. Huang, R.T. Baird, B.W. Garlepp, D. Pastorello, E.T. King, Q. Yu, D.B. Kasha, P. Steiner, L. Zhang, J. Hein, B. Del Signore, "A 2.5 Gb/s Multi-Rate 0.25μm CMOS Clock and Data Recovery Circuit Utilizing a Hybrid Analog/Digital Loop Filter and All-Digital Referenceless Frequency Acquisition," IEEE J. Solid-State Circuits, vol. 41, Dec. 2006, pp. 2930-2944. PDF
M. Park, J-W Kim, F. Kaetner, M.H. Perrott, "An Optical-Electrical Sub-Sampling Receiver Employing Continuous-Time ΣΔ Modulation," ESSCIRC 2006 Dig. Tech. Papers, Sep. 2006, pp. 182-185. PDF
C-M Hsu, C.Y. Lau, M.H. Perrott, "A Delay-Locked Loop using a Synthesizer-Based Phase Shifter for 3.2 Gb/s Chip-to-Chip Communication," ESSCIRC 2006 Dig. Tech. Papers, Sep. 2006, pp. 460-463. PDF
M.H. Perrott, Y. Huang, R.T. Baird, B.W. Garlepp, L. Zhang, J.P. Hein, "A 2.5 Gb/s Multi-Rate 0.25μm CMOS CDR Utilizing a Hybrid Analog/Digital Loop Filter," ISSCC 2006 Dig. Tech. Papers, Feb. 2006, pp. 1276-1285. PDF
S.E. Meninger, M.H. Perrott, "A 1-MHZ Bandwidth 3.6-GHz 0.18-um CMOS Fractional-N Synthesizer Utilizing a Hybrid PFD/DAC Structure for Reduced Broadband Phase Noise," IEEE J. Solid-State Circuits, vol. 41, pp. 966-980, Apr. 2006. PDF
E.A. Crain, M.H. Perrott, "A 3.125 Gb/s Limit Amplifier in CMOS with 42 dB Gain and 1us Offset Compensation," IEEE J. Solid-State Circuits, vol. 41, pp. 443-451, Feb. 2006. PDF
S.E. Meninger, M.H. Perrott, "A Dual Band 1.8GHz/900MHz, 750kb/s GMSK Transmitter Utilizing a Hybrid PFD/DAC Structure for Reduced Broadband Phase Noise," IEEE VLSI Circuits Symp., Jun. 2005. PDF
S.E. Meninger, M.H. Perrott, "Bandwidth Extension of Low Noise Fractional-N Synthesizers," Radio Frequency Integrated Circuits (RFIC) Symposium 2005, Jun. 2005. PDF
E. Crain, M. Perrott, "A 3.125Gb/s Limit Amplifier with 42dB Gain and 1μs Offset Compensation in 0.18um CMOS," in ISSCC 2005 Dig. Tech. Papers, Feb. 2005, pp. 232-233, 595. PDF
J. Kim, F. X. Kärtner, M. H. Perrott, "Femtosecond synchronization of radio frequency signals with optical pulse trains," Optics Letters, vol. 29, Issue 17, pp. 2076-2078, Sep. 2004. PDF
E.A. Crain, M.H. Perrott, "A numerical Design Approach for High-Speed, Differential, Resistor-Loaded, CMOS Amplifiers," IEEE International Symposium on Circuits and Systems (ISCAS '04), May 2004. PDF
S.E. Meninger, M.H. Perrott, "A fractional- N frequency synthesizer architecture utilizing a mismatch compensated PFD/DAC structure for reduced quantization-induced phase noise," IEEE Trans. Circuits Syst. II, vol. 50, pp. 839-849, Nov. 2003. PDF
C.Y. Lau, M.H. Perrott, "Phase Locked Loop Design at the Transfer Function Level Based on a Direct Closed Loop Realization Algorithm", Design Automation Conference (DAC), Jun. 2003, pp. 526-531. PDF
M.H. Perrott, M.D. Trott, C.G. Sodini, "A modeling approach for Σ-Δ fractional-N frequency synthesizers allowing straightforward noise analysis," IEEE J. Solid-State Circuits, vol. 37, pp. 1028-1038, Aug. 2002. PDF
M.H. Perrott, "Behavioral simulation of fractional-N frequency synthesizers and other PLL circuits," IEEE Design & Test of Computers, vol. 19, pp. 74-83, Jul. 2002. PDF
M.H. Perrott, "Fast and Accurate Behavioral Simulation of Fractional-N Synthesizers and other PLL/DLL Circuits", Design Automation Conference (DAC), Jun. 2002, pp 498-503. PDF
M.H. Perrott, T.L. Tewksbury, C.G. Sodini, "A 27-mW CMOS fractional-N synthesizer using digital compensation for 2.5-Mb/s GFSK modulation," IEEE J. Solid-State Circuits, vol. 32, pp. 2048-2060, Dec. 1997. PDF
M.H. Perrott, T.L. Tewksbury, C.G. Sodini, "A 27mW CMOS fractional-N synthesizer/modulator IC," in ISSCC 1997 Dig. Tech. Papers, Feb. 1997, pp. 366-367, 487. PDF
Theses Supervised
S.E. Meninger, "Low Phase Noise, High Bandwidth Frequency Synthesis Techniques," May 2005. PDF
S. Kuo, "Linearization of a Pulse Width Modulated Power Amplifier," June 2004. PDF
E.A. Crain, "Fast Offset Compensation for a 10 Gbps Limit Amplifier," May 2004. PDF
O.T. Ogunnika, "A Simple Transformer-Based Resonator Architecture for Low Phase Noise LC Oscillators," October 2003. PDF
B.P. Ginsburg, "A 1.6-3.2 GHz, High Phase Accuracy Quadrature Phase Locked Loop," June 2003. PDF
N.A. Drego, "A Low-Skew, Low-Jitter Receiver Circuit for On-Chip Optical Clock Distribution," June 2003. PDF
Perrott全套论文.part5.rar
2.01 MB, 下载次数: 714 , 下载积分: 资产 -2 信元, 下载支出 2 信元
part5
Perrott全套论文.part1.rar
4.29 MB, 下载次数: 765 , 下载积分: 资产 -3 信元, 下载支出 3 信元
part1
Perrott全套论文.part2.rar
4.29 MB, 下载次数: 728 , 下载积分: 资产 -3 信元, 下载支出 3 信元
part2
Perrott全套论文.part3.rar
4.29 MB, 下载次数: 736 , 下载积分: 资产 -3 信元, 下载支出 3 信元
part3
Perrott全套论文.part4.rar
4.29 MB, 下载次数: 738 , 下载积分: 资产 -3 信元, 下载支出 3 信元
part4
 楼主| 发表于 2010-11-29 00:14:43 | 显示全部楼层
回复 1# yxxjtu
居然没人下,太可惜,把具体内容标上,以示含金量:
Theses Supervised
发表于 2010-11-29 00:16:49 | 显示全部楼层
还没我下的多。
发表于 2010-11-29 09:33:52 | 显示全部楼层
呵呵,谢谢楼主
发表于 2010-11-29 10:00:31 | 显示全部楼层
学习电路  谢楼主了
发表于 2010-11-29 11:26:39 | 显示全部楼层
下来看看,谢谢。
发表于 2010-11-29 19:21:03 | 显示全部楼层
看看!!!!!
发表于 2010-12-31 10:50:00 | 显示全部楼层
谢谢分享啊
发表于 2011-2-5 13:28:26 | 显示全部楼层
dddddddddddddddddd
发表于 2011-2-16 10:36:27 | 显示全部楼层
thanks
GMT+8, 2025-12-30 05:36 , Processed in 0.028191 second(s), 6 queries , Gzip On, Redis On.
