查看: 3818|回复: 4
[资料] CDMA资料2
发表于 2010-9-17 10:55:21 | 显示全部楼层 |阅读模式
Mobile Fading Channels
Elvino S. Sousa
Department of Electrical Engineering
University of Toronto
Mobile Fading Channels.pdf
231.79 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2010-9-17 10:57:36 | 显示全部楼层
The Rake Receiver
E. S. Sousa
Dept. of ECE, University of Toronto
The Rake receiver in a modern digital implementation of a CDMA receiver has a structure
that is similar to the structure shown in Fig. 1.
The Rake Receiver.pdf
58.59 KB, 下载次数: 1 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2010-9-17 10:58:57 | 显示全部楼层
Wireless Communication Systems
Elvino S. Sousa
Dept. of Electrical and Computer Engineering
1 Introduction
Wireless communications networks to provide telephone service to mobile users have been rapidly developed starting
in the early eighties. Beginning with the first generation analog systems which provide voice service we are now on
the verge of the standardization of third generation systems which will have the capability to offer multimedia services.
The most fundamental concepts in the development of economically viable wireless telecommunication networks
are the concepts of frequency re-use and accurate transmitter power control which allows the use of a relatively
small amount of radio spectrum to serve a large population of mobile users in some population area such as a city.
The key issue in the development of these systems has been the maximization of the capacity of the system in terms
of the number of users that can be served per base station per unit of bandwidth. Due to the limitation in technology
the first generation systems were analog and as a result of propagation impairments they used a relatively inefficient
modulation technique - wideband FM. As a result of the rapid success of these systems there was a strong push for the
design of second generation systems. The main objective for this development in North America was the capacity
issue - where the capacity limit of the early systems was quickly reached in cities such as Chicago and Los Angeles.
A goal of 10 times the capacity of the analog system was set for the second generation systems in North America.
These systems also had to maintain downward compatibility with the analog system. In Europe the second generation
systems were motivated by the need to develop a pan-European system which would work with the same hand terminal
in all the countries of Europe. The second generation system was also designed to operate in a new frequency
band - hence downward compatibility with the older first generation systems was not necessary.
Wireless Communication Systems.pdf
380.55 KB, 下载次数: 1 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-12-2 14:42:38 | 显示全部楼层
有没有原理及PCB啊
发表于 2010-12-21 09:25:26 | 显示全部楼层
very good
GMT+8, 2025-12-27 14:30 , Processed in 0.020244 second(s), 6 queries , Gzip On, Redis On.
