在刚开始CTS设置clock common options后,出现一些waring
waring:cell port PO2W/PAD with unknow direction,assumed as input direction
waring:cell port PO2W/I with unknow direction,assumed as input direction
waring:cell port PIW/PAD with unknow direction,assumed as input direction
waring:cell port PIW/C with unknow direction,assumed as input direction
waring: i0: PAD is an implicit ignore pin since it is an non-clock pin
waring: i1: PAD is an implicit ignore pin since it is an non-clock pin
我用的SMIC18工艺,其中PO2W PIW 分别是所用的输出信号PAD、输入信号PAD,
i0,i1是连接两个时钟信号的PAD的实例名
