在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 16576|回复: 18
[原创] altera的NIOS开发大全,英文
发表于 2010-6-23 20:21:56 | 显示全部楼层 |阅读模式
NIOS开发的全部文档,空间绝后。列表如下
DocumentDescription
Nios II Handbooks
Embedded Design Handbook[/url]Design guides describing best practices when designing with Altera embedded solutions. Contains information on hardware and software development and verification for new and experienced users.
Nios II Processor Reference Handbook[/url]Primary reference for the Nios II processor hardware: Introduction to the Nios II processor for new users, hardware architecture, and instruction set.
Nios II Software Developer's Handbook[/url]Primary reference for programming the Nios II processor: Introduction to Nios II software development for new users, hardware abstraction layer (HAL), writing programs, writing device drivers, RTOS, Ethernet, and advanced programming topics.
Quartus II Handbook, Volume 4: SOPC Builder[/url]Complete reference for SOPC Builder, the system integration tool used to create Nios II hardware designs.
Quartus II Handbook, Volume 5: Embedded Peripherals[/url]Description of Altera-provided peripherals that support the Nios II processor.
Hardware and System Development
Nios II Hardware Development Tutorial[/url]How to create a Nios II processor system from scratch.
Nios II Custom Instruction User Guide[/url]All aspects of implementing custom instruction hardware and software. Includes a tutorial and design example.
Nios II Flash Programmer User Guide[/url]All aspects of programming flash using the Nios II IDE flash programmer, including how to program flash on custom boards.
DDR and DDR2 SDRAM Controller Compiler User Guide[/url]Complete reference on creating and using Altera DDR & DDR2 SDRAM controller cores, including details on using SOPC Builder to instantiate a controller for the DDR SDRAM on the Nios Development Board, Cyclone II Edition.
System Console User Guide[/url]Documentation for system console utilities that support low-level, hardware debugging of SOPC Builder systems.
Using Nios II Tightly Coupled Memory Tutorial[/url]How to instantiate on-chip tightly-coupled memories with the Nios II processor for fast memory access time.
Creating Multiprocessor Nios II Systems Tutorial[/url]How to create a system with multiple Nios II processors and use the mutex component to coordinate processors.
Using Nios II Floating-Point Custom Instructions[/url]How to add floating-point instructions to the Nios II processor and compile software for them.
AN 548: Nios II Compact Configuration System for Cyclone III Application Note[/url]An example of a compact Nios II processor system you can use to manage configuration from flash memory containing multiple FPGA configuration images.
AN 527: Implementing an LCD Controller Application Note[/url]How to create your own LCD module for your embedded design.
AN458: Alternate Nios II Boot Methods Application Note[/url]How to boot your Nios II system, use the default Nios II bootloader, and customize the bootloader.
AN446: Debugging Nios II Systems with the SignalTap II Logic Analyzer Application Note[/url]How to use the SignalTap® II Logic Analyzer and the Nios II SignalTap plug-in to debug your embedded system.
AN440: Accelerating Nios II Networking Applications Application Note[/url]How to achieve optimum Ethernet performance with Nios II, including an Ethernet reference design using Nios II, the TSE MAC core, the SG-DMA component, and the NicheStack® TCP/IP Stack - Nios II Edition.
AN391: Profiling Nios II Systems Application Note[/url]How to profile your Nios II system to discover potential areas for performance optimizations.
AN351: Simulating Nios II Embedded Processor Designs Application Note[/url]How to simulate Nios II processor designs using the ModelSim simulator.
AN350: Upgrading Nios Processor Systems to the Nios II Processor Application Note[/url]How to upgrade first-generation Nios processor systems to use the Nios II processor.
AN346: Using the Nios Development Board Configuration Controller Reference Designs Application Note[/url]Reference for using the configuration controller reference design delivered with the Nios development boards.
Avalon Interface Specifications[/url]Reference for Avalon interface behaviors.
Nios II Performance Benchmarks[/url]Performance and resource usage data for the Nios II processor and peripherals.
Software Development
Nios II IDE Help[/url]Reference for using the features of the Nios II IDE. This content is available as one PDF document, or as individual topics within the Nios II IDE help system. After starting the IDE, on the Help menu click Help Contents to view the topics.
SOPC Builder HelpReference for using the features of SOPC Builder. This content is available within the SOPC Builder help system. After starting SOPC Builder, on the Help menu click Help.
Nios II Software Development TutorialHow to create, compile, debug, and run a C/C++ program using the Nios II IDE. This tutorial is available within the Nios II IDE help system.
AN459: Guidelines for Developing a Nios II HAL Device Driver Application Note[/url]Explains the anatomy of a HAL device driver and how to create and debug one for a Nios II component.
AN429: Remote Configuration Over Ethernet with the Nios II Processor Application Note[/url]Describes a methodology for implementing remote configuration with the Nios II processor.
Using the MicroC/OS-II RTOS with the Nios II Processor Tutorial[/url]How to create a new software application based on the MicroC/OS-II real-time operating system (RTOS).
Using the NicheStack TCP/IP Stack Nios II Edition Tutorial[/url]How to create a new software application based on the NicheStack TCP/IP Stack - Nios II Edition.
Using the GNU Compiler Collection (GCC)[/url]Complete reference for the Nios II compiler tool-chain. Below are links to the main Nios II processor-specific content:
  • Altera Nios II Options[/url]
  • [Altera Nios II Built-in Functions[/url]
  • Machine Constraints for asm Operands[/url]
Newlib ANSI C standard library documentation[/url]Complete reference of the Newlib implementation of the C standard library.
Other GNU documentationDocumentation for all the GNU tools:
  • Altera Nios II Dependent Features[/url])
  • Linker[/url]
  • GNU Profiler[/url]
  • Binutils[/url]
  • [BFD[/url]
  • The C Pre-Processor[/url]
  • GDB - The GNU debugger[/url]
  • Libstdc++[/url]
Documentation for all the GNU tools installed with the Nios II EDS is available in <Nios II EDS install path>/documents/gnu-tools.
Micrium HomepageFurther information on the MicroC/OS-II RTOS distributed with the Nios II EDS.
C-to-Hardware Acceleration
Nios II C2H Compiler User Guide[/url]Complete reference for the Nios II C-to-Hardware Acceleration (C2H) Compiler, including getting started guide.
Accelerating Nios II Systems with the C2H Compiler Tutorial[/url]Beginning instructions on how to accelerate algorithms using the Nios II C2H Compiler.
AN531: Reducing Power with Hardware Accelerators Application Note[/url]An example of using parallel algorithms to reduce power consumption in embedded systems implemented in FPGAs.
[AN417: Accelerating Functions with the C2H Compiler: Scatter-Gather DMA with Checksum Application Note[/url]An example of accelerating a software function using the C2H Compiler.
Development Kits and Boards
Nios II Development Kit Getting Started User Guide[/url]Getting started instructions for Nios II development kit owners. Describes how to set up your Nios II development board and install the Nios II development software.
[Nios II Development Kit Documentation[/url]Documentation describing the features and devices of Nios II development kits, including reference manuals, schematics, and board layout files.
Related News and Information
Embedded News and EventsInformation about new releases, application notes, reference designs, and upcoming industry events.
Embedded Processing Resource CenterA comprehensive list of Altera embedded products and support resources.
 楼主| 发表于 2010-6-23 21:06:34 | 显示全部楼层
1# xuer_1975
one_click_niosII_docs_9_0.part71.rar
776.04 KB, 下载次数: 14 , 下载积分: 资产 -2 信元, 下载支出 2 信元
one_click_niosII_docs_9_0.part01.rar
1.96 MB, 下载次数: 26 , 下载积分: 资产 -2 信元, 下载支出 2 信元
one_click_niosII_docs_9_0.part02.rar
1.96 MB, 下载次数: 25 , 下载积分: 资产 -2 信元, 下载支出 2 信元
one_click_niosII_docs_9_0.part03.rar
1.96 MB, 下载次数: 24 , 下载积分: 资产 -2 信元, 下载支出 2 信元
one_click_niosII_docs_9_0.part04.rar
1.96 MB, 下载次数: 23 , 下载积分: 资产 -2 信元, 下载支出 2 信元
one_click_niosII_docs_9_0.part05.rar
1.96 MB, 下载次数: 19 , 下载积分: 资产 -2 信元, 下载支出 2 信元
one_click_niosII_docs_9_0.part06.rar
1.96 MB, 下载次数: 15 , 下载积分: 资产 -2 信元, 下载支出 2 信元
one_click_niosII_docs_9_0.part07.rar
1.96 MB, 下载次数: 29 , 下载积分: 资产 -2 信元, 下载支出 2 信元
one_click_niosII_docs_9_0.part08.rar
1.96 MB, 下载次数: 22 , 下载积分: 资产 -2 信元, 下载支出 2 信元
one_click_niosII_docs_9_0.part09.rar
1.96 MB, 下载次数: 11 , 下载积分: 资产 -2 信元, 下载支出 2 信元
one_click_niosII_docs_9_0.part10.rar
one_click_niosII_docs_9_0.part11.rar
one_click_niosII_docs_9_0.part12.rar
1.96 MB, 下载次数: 9 , 下载积分: 资产 -2 信元, 下载支出 2 信元
one_click_niosII_docs_9_0.part13.rar
1.96 MB, 下载次数: 8 , 下载积分: 资产 -2 信元, 下载支出 2 信元
one_click_niosII_docs_9_0.part14.rar
one_click_niosII_docs_9_0.part15.rar
1.96 MB, 下载次数: 7 , 下载积分: 资产 -2 信元, 下载支出 2 信元
one_click_niosII_docs_9_0.part16.rar
one_click_niosII_docs_9_0.part17.rar
one_click_niosII_docs_9_0.part18.rar
one_click_niosII_docs_9_0.part19.rar
one_click_niosII_docs_9_0.part20.rar
one_click_niosII_docs_9_0.part21.rar
one_click_niosII_docs_9_0.part22.rar
one_click_niosII_docs_9_0.part23.rar
one_click_niosII_docs_9_0.part24.rar
one_click_niosII_docs_9_0.part25.rar
one_click_niosII_docs_9_0.part26.rar
one_click_niosII_docs_9_0.part27.rar
one_click_niosII_docs_9_0.part28.rar
one_click_niosII_docs_9_0.part29.rar
one_click_niosII_docs_9_0.part30.rar
one_click_niosII_docs_9_0.part31.rar
1.96 MB, 下载次数: 6 , 下载积分: 资产 -2 信元, 下载支出 2 信元
one_click_niosII_docs_9_0.part32.rar
one_click_niosII_docs_9_0.part33.rar
one_click_niosII_docs_9_0.part34.rar
one_click_niosII_docs_9_0.part35.rar
one_click_niosII_docs_9_0.part36.rar
one_click_niosII_docs_9_0.part37.rar
one_click_niosII_docs_9_0.part38.rar
one_click_niosII_docs_9_0.part39.rar
one_click_niosII_docs_9_0.part40.rar
one_click_niosII_docs_9_0.part41.rar
one_click_niosII_docs_9_0.part42.rar
one_click_niosII_docs_9_0.part43.rar
1.96 MB, 下载次数: 10 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2010-6-23 21:08:25 | 显示全部楼层
未完待续,呵呵,网络太慢了。
 楼主| 发表于 2010-6-23 21:10:25 | 显示全部楼层
太慢了
 楼主| 发表于 2010-6-23 21:13:25 | 显示全部楼层
未完待续,请继续收
one_click_niosII_docs_9_0.part49.rar
one_click_niosII_docs_9_0.part50.rar
one_click_niosII_docs_9_0.part44.rar
one_click_niosII_docs_9_0.part45.rar
one_click_niosII_docs_9_0.part46.rar
one_click_niosII_docs_9_0.part47.rar
one_click_niosII_docs_9_0.part48.rar
 楼主| 发表于 2010-6-23 21:15:27 | 显示全部楼层
后边还有
one_click_niosII_docs_9_0.part51.rar
发表于 2010-6-24 12:57:51 | 显示全部楼层
太好了!谢谢!
 楼主| 发表于 2010-6-24 20:23:00 | 显示全部楼层
好像传完了
776.04 KB, 下载次数: 7 , 下载积分: 资产 -2 信元, 下载支出 2 信元
one_click_niosII_docs_9_0.part52.rar
one_click_niosII_docs_9_0.part53.rar
one_click_niosII_docs_9_0.part54.rar
one_click_niosII_docs_9_0.part55.rar
one_click_niosII_docs_9_0.part56.rar
one_click_niosII_docs_9_0.part57.rar
one_click_niosII_docs_9_0.part58.rar
one_click_niosII_docs_9_0.part59.rar
one_click_niosII_docs_9_0.part60.rar
one_click_niosII_docs_9_0.part61.rar
one_click_niosII_docs_9_0.part62.rar
one_click_niosII_docs_9_0.part63.rar
one_click_niosII_docs_9_0.part64.rar
one_click_niosII_docs_9_0.part65.rar
one_click_niosII_docs_9_0.part66.rar
one_click_niosII_docs_9_0.part67.rar
one_click_niosII_docs_9_0.part68.rar
one_click_niosII_docs_9_0.part69.rar
one_click_niosII_docs_9_0.part70.rar
 楼主| 发表于 2010-6-24 20:26:55 | 显示全部楼层
终于发完了,第一次发贴,压的包太小了,以后注意,呵呵
发表于 2010-8-5 09:39:25 | 显示全部楼层
不容易啊。。。。
GMT+8, 2024-4-25 18:59 , Processed in 0.040231 second(s), 9 queries , Gzip On, Redis On.
