在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
返回列表 发新帖
楼主: kuloloo
[求助] ERROR:Pack:1107 - Unable to combine the following symbols into a single IOB
发表于 2012-11-5 17:41:45 | 显示全部楼层
求解啊
发表于 2014-3-26 19:53:06 | 显示全部楼层
这个顶一下,我现在也遇到这样的问题,希望楼主不吝赐教!
发表于 2014-3-27 15:16:53 | 显示全部楼层
看下Console里面Errors详细解释,应该会指出某个管脚分配的问题
发表于 2015-4-9 22:47:20 | 显示全部楼层
楼主是不是将差分时钟输入到DCM,同时又将此差分时钟驱动其余器件,如DDR等?
发表于 2015-4-15 10:05:33 | 显示全部楼层
回复 1# kuloloo
楼主你好,我最近也出现过这种问题,就是在使用aurora核的时候。报错如下:希望帮忙解决一下
Pack:1107 - Pack was unable to combine the symbols listed below into a
   single IOB component because the site type selected is not compatible.
   Further explanation:
   The component type is determined by the types of logic and the properties and
   configuration of the logic it contains. In this case an IO component of type
   IOB was chosen because the IO contains symbols and/or properties consistent
   with input, output, or bi-directional usage and contains no other symbols or
   properties that require a more specific IO component type. Please double
   check that the types of logic elements and all of their relevant properties
   and configuration options are compatible with the physical site type of the
   constraint.
   Summary:
   Symbols involved:
PAD symbol "GTPD0_P" (Pad Signal = GTPD0_P)
DIFFAMP symbol "IBUFDS/IBUFDS" (Output Signal = GTPD0_left_i)
   Component type involved: IOB
   Site Location involved: A10
   Site Type involved: IPAD
Mapping completed.
See MAP report file "aurora_8b10b_v5_3_example_design_map.mrp" for details.
Problem encountered during the packing phase.
发表于 2015-7-15 12:36:24 | 显示全部楼层
同问。。。。。
发表于 2016-7-4 13:21:48 | 显示全部楼层
回复 8# falloutmx
   我也是这个问题,时钟进来给DCM了,这个怎么回事呢,谢谢了。
发表于 2016-7-6 20:03:38 | 显示全部楼层
good material
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-24 11:53 , Processed in 0.030426 second(s), 8 queries , Gzip On, Redis On.
