不知道为什么。。。。 不能仿verilog a的文件。 调用了.va 文件。 软件应该没问题,因为仿真其他的(不调用va的sp文件)都可以出结果的。 调用的.va也是没问题的,因为是软件自带的代码。下面是编译结果。
****** HSPICE -- A-2007.09 32-BIT (Aug 28 2007) 10:01:25 06/01/2010 winnt
Copyright (C) 2007 Synopsys, Inc. All Rights Reserved.
Unpublished-rights reserved under US copyright laws.
This program is protected by law and is subject to the
terms and conditions of the license agreement found in:
D:\Program Files\hspice2\license.txt
Use of this program is your acceptance to be bound by this
license agreement. HSPICE is the trademark of Synopsys, Inc.
Input File: e:\veriloga\mem2\resistor.sp
lic:
lic: FLEXlm: v8.5b
lic: USER: Administrator HOSTNAME: cybertro-6ef6c0
lic: HOSTID: "002564d50ad0 005056c00001 005056c00008" PID: 7656
lic: Using FLEXlm license file:
lic: D:\Program Files\hspice2\hspice200709.lic
lic: Checkout 1 hspice; Encryption code: AD47C1C891DA5D596A45
lic: License/Maintenance for hspice will expire on 31-dec-2020/2007.9
lic: NODE LOCKED license on hostid "002564d50ad0 005056c00001 005056c00008"
lic:
Init: read install configuration file: D:\Program Files\hspice2\meta.cfg
Init: hspice initialization file: D:\Program Files\hspice2\hspice.ini
During .hdl command processing, loading Verilog-A modules from
'e:\veriloga\mem2\resistor.va'.
hsp-vacomp:
hsp-vacomp: Invoking the Verilog-A compiler for 'resistor.va'
hsp-vacomp: lic:
hsp-vacomp: lic: FLEXlm: v8.5b
hsp-vacomp: lic: USER: Administrator HOSTNAME: cybertro-6ef6c0
hsp-vacomp: lic: HOSTID: "002564d50ad0 005056c00001 005056c00008" PID: 10984
hsp-vacomp: lic: Using FLEXlm license file:
hsp-vacomp: lic: D:\Program Files\hspice2\hspice200709.lic
hsp-vacomp: lic: Checkout 1 hspiceva; Encryption code: AD47C1C891DA5D596A45
hsp-vacomp: lic: License/Maintenance for hspiceva will expire on 31-dec-2020/2007.9
hsp-vacomp: lic: NODE LOCKED license on hostid "002564d50ad0 005056c00001 005056c00008"
hsp-vacomp: lic:
hsp-vacomp: Synopsys HSPICE Verilog-A Compiler Version 1.46.071907.
hsp-vacomp: Copyright (C) 2005 Synopsys, Inc. All Rights Reserved.
hsp-vacomp:
hsp-vacomp: lic: Release hspiceva token(s)
** error **
During Verilog-A Device processing:
CML file does not exist
'C:\Documents and Settings\Administrator\hsp-model-cache\1.46\e\\veriloga\mem2\\lib.win32\resistor.cml'
***** job aborted
lic: Release hspice token(s)
谢谢了! 这是为什么呢。。。。 |
