楼主: ggzhuq
[求助] 关于DC license 问题
发表于 2015-2-12 16:42:42 | 显示全部楼层
同问啊!
发表于 2015-3-18 06:45:51 | 显示全部楼层
    scl 11.9  +  最新软件, 也遇到这个问题,软件也不能启动。
   但是,scl 11.9 + 旧的软件,可以正常启动。
发表于 2015-5-1 21:52:42 | 显示全部楼层
我也遇到相同的问题,同问?
发表于 2015-5-20 14:06:05 | 显示全部楼层
i also have the same problem
发表于 2015-6-24 18:50:57 | 显示全部楼层
Integrity check report for license file "synopsys_sea3.dat".
Report generated on 24-Jun-2015 (SCL_11.9)
Checking the integrity of the license file....
Valid SSS feature found. INVALID license file fingerprint.
You have added 3 new features to this file.
All revenue keys ("SN=RK:..." on feature line) have been excluded.
Licensed to mammoth//ZWT 2006
Siteid: <No Site Id>, Server Hostid: 000c29991fc4, Issued on: N/A
License file integrity check FAILED!
This is an INVALID license file. You SHOULD NOT use this license file.
Please use the license file as received from Synopsys, Inc.
发表于 2015-8-27 20:55:21 | 显示全部楼层
同样遇该问题,求解
发表于 2015-9-6 06:55:44 | 显示全部楼层
本版回帖需要审核,您的帖子将在通过审核后显示
回复 支持 0 反对 1
发表于 2015-12-17 19:06:43 | 显示全部楼层
一样的问题啊
发表于 2016-2-12 18:21:41 | 显示全部楼层
I met the same issue (invalid fingerprint)
tested combination:
Centos7 + SCL 11.9 + newSynopsysLicMaker
Centos7 + SCL 11.5 + newSynopsysLicMaker
发表于 2016-3-30 00:33:59 | 显示全部楼层
I have the Same & problem, CENTOS7 + at The the SCL 11.9. Anyone Find the Solution?
My Support Person Told Me that We SHOULD Not the RUN SSSVERIFY the ON The License that We created. So, We Will try to Finish the install Today, Setup The Environment and See if it works.
GMT+8, 2025-11-2 22:13 , Processed in 0.018582 second(s), 5 queries , Gzip On, Redis On.
