LSI全球研发中心在徐汇区顶级写字楼(周边房价六七万吧),标准美资企业,Fabless大公司,工作环境优秀,团队气氛友好,团结向上,薪水也很不错,有较多出国培训机会,向上空间大,对职业生涯大有裨益,进来还发股票(最近)。如果有意,请发送简历到lowpowerdesign@hotmail.com.
顺便提一下内推和猎头。公司的每招聘猎头推荐的人才都要一定的费用,而内推却没有。同时,公司相关部门是有成本考核指标的。所以内推的录用率高。同时,把简历给猎头,简历的安全系数不高,送到老板手里就麻烦了:)本来这些东西我不想说的,因为这个版上猎头不少。不过貌似这是“众人皆知的秘密”.
这个职位是内推,可以提高您的录用几率,而且简历安全系数高啊,你懂的......
Mixed-Signal至少3年经验,Digital engineer,layout 2年经验以上--英语也要不错,能跟老美沟通
具体要求详见下面。
Analog/Mixed Signal Design Engineer(Now 3 Positions!!!)
- Design high speed analog and mixed-signal integrated circuits within custom chips for the
hard disk drive industry
- Work directly with customers to determine system requirements, write specifications and
guide customers in the use of pre-amplifier products
- Use high speed electronic characterization equipment to evaluate and debug the
functionality of the design once the part is fabricated in silicon
- Provide technical leadership through all phases of product development including test,
yield, characterization, reliability analysis, qualification and release to manufacturing
- Degree in Electrical Engineering (or related field), MS required, Ph.D. preferred
- Minimum three to five years experience in discrete, transistor level analog circuit design
- Experience with analog and mixed signal IC product design, integration and verification is
required
- Strong physical layout knowledge and parasitic component understanding essential
- Process and device physics knowledge critical
- Proven skills using electronic measurement equipment in a lab environment
- Expertise in applied magnetism and recording a strong plus
Digital Engineer要求就不详细贴出来,一般都能符合
Custom Layout Engineer
You will join a cross-functional team responsible for developing
leading edge high-speed magneto electronic read/write IC products that ultimately achieve
high volume production.
- Layout high speed analog and mixed-signal custom chips for the hard disk drive industry
- Work directly with a team of engineers to determine floor plan, routing and I/O
requirements for preamp IC's
- Perform IC design rule and connectivity verification and drive products through mask
release flows.
- Contribute to methodology improvements to increase layout and verification efficiency.
PREFERRED EXPERIENCE:
- Bachelor's degree in Electrical Engineering (or related field) or equivalent experience
- Minimum three to five years experience in custom analog IC physical design
- Experience with schematic-driven layout, floor planning, chip level routing, design for
manufacturing and design rule and connectivity verification is required
- Experience using Cadence virtuoso XL and VCAR router preferred
- Familiarity with both analog and digital layout tools and flows, circuit design concepts and
IC manufacturing processes desired |
